I’m trying to build automated, image based VM provisioning in virtualized network environment built around (virtual) pfSense firewall appliance. I would like to integrate Foreman with DHCP (isc_dhcpd) and DNS services (bind) provided by pfSense appliance. At the moment, image provisioning fails at the finish template phase because Foreman fails to SSH to a provisioned VM’s. The foreman-proxy service is integrated with pfSense DHCP server via OMAPI and SSHFS file system:
/var/dhcpd/etc/dhcpd.conf (on pfSense firewall)
omapi-port 7911;
key omapi_key {
algorithm HMAC-MD5;
secret "secret";
# ls -la /mnt/pfsense_dhcpd/etc/ (on Foreman server)
total 24
drwxr-xr-x 1 dhcpd _dhcp 512 Dec 13 23:39 .
drwxr-xr-x 1 root root 512 Dec 12 03:48 ..
-rw-r--r-- 1 dhcpd _dhcp 2675 Dec 13 23:39 dhcpd.conf
# ls -la /mnt/pfsense_dhcpd/var/db/ (on Foreman server)
total 92
drwxr-xr-x 1 dhcpd _dhcp 512 Dec 14 19:39 .
drwxr-xr-x 1 dhcpd _dhcp 512 Nov 5 18:47 ..
-rw-r--r-- 1 dhcpd _dhcp 44493 Dec 14 20:26 dhcpd.leases
The “foreman-proxy” user can read and write from/to DHCPD config files
# sudo -u foreman-proxy grep 7911 /mnt/pfsense_dhcpd/etc/dhcpd.conf
omapi-port 7911;
# sudo -u foreman-proxy echo "#TEST" >> /mnt/pfsense_dhcpd/var/db/dhcpd.leases
# sudo -u foreman-proxy grep "#TEST" /mnt/pfsense_dhcpd/var/db/dhcpd.leases
#TEST
/etc/foreman-proxy/settings.d/dhcp.yml (on Foreman server)
:enabled: true
:use_provider: dhcp_isc
:server: 10.15.0.1
/etc/foreman-proxy/settings.d/dhcp_isc.yml (on Foreman server)
:config: /mnt/pfsense_dhcpd/etc/dhcpd.conf
:leases: /mnt/pfsense_dhcpd/var/db/dhcpd.leases
:key_name: omapi_key
:key_secret: secret
:omapi_port: 7911
My Foreman DHCP integration works BUT up to some extent so far… Foreman provides unassigned IP
for new VM, but no static DHCP mapping gets created on the DHCP server (verified many times). No errors are reported to foreman-proxy log (see below ). Therefore after a new VM starts - it gets a whatever random IP and Foreman fails to SSH to it.
2019-12-14T19:55:25 13a0a078 [I] Started GET /dhcp/10.20.0.0/unused_ip from=10.20.0.10&to=10.20.0.254
2019-12-14T19:55:27 13a0a078 [I] Finished GET /dhcp/10.20.0.0/unused_ip with 200 (2012.16 ms)
2019-12-14T20:01:41 17c2abd5 [I] Started POST /dhcp/10.20.0.0
2019-12-14T20:01:41 17c2abd5 [I] Finished POST /dhcp/10.20.0.0 with 200 (6.68 ms)
A static DHCP mappings gets created
Katello 3.13 - clean install, not upgrade
Relevant DHCPD log server lines
Dec 14 20:01:52 inf-pfsense-01.rbx.nc.supersolid.net dhcpd: DHCPREQUEST for 10.20.0.138 from 00:50:56:b7:3f:62 via vmx1.200
Dec 14 20:01:52 inf-pfsense-01.rbx.nc.supersolid.net dhcpd: DHCPACK on 10.20.0.138 to 00:50:56:b7:3f:62 (hostname) via vmx1.200
Dec 14 20:01:52 inf-pfsense-01.rbx.nc.supersolid.net dhcpd: reuse_lease: lease age 0 (secs) under 25% threshold, reply with unaltered, existing lease for 10.20.0.138
Dec 14 20:01:52 inf-pfsense-01.rbx.nc.supersolid.net dhcpd: DHCPDISCOVER from 00:50:56:b7:3f:62 (hostname) via vmx1.200
Dec 14 20:01:52 inf-pfsense-01.rbx.nc.supersolid.net dhcpd: DHCPOFFER on 10.20.0.138 to 00:50:56:b7:3f:62 (hostname) via vmx1.200
Dec 14 20:01:52 inf-pfsense-01.rbx.nc.supersolid.net dhcpd: DHCPREQUEST for 10.20.0.138 (10.20.0.1) from 00:50:56:b7:3f:62 (hostname) via vmx1.200
Dec 14 20:05:45 inf-pfsense-01.rbx.nc.supersolid.net dhcpd: DHCPREQUEST for 10.20.0.138 from 00:50:56:b7:3f:62 (hostname) via vmx1.200
Dec 14 20:05:45 inf-pfsense-01.rbx.nc.supersolid.net dhcpd: DHCPACK on 10.20.0.138 to 00:50:56:b7:3f:62 (hostname) via vmx1.200
