theforeman factor of the window displays information about clients not
hoping to get help with a problem. Log to look as follows.
"invalid byte sequence in UTF-8 (ArgumentError)"
puppet server's /var/lib/puppet/yaml/facts/ information is stored in the
folder that corresponds to the client's problem instead of looking at that
puppet show can not process brings some strange characters like the foreman.
foreman version of the 1.4 version and the Korean version of Windows. (The
same is true in version 1.3)
I really appreciate the help you give.
For more information, log is as follows:
Started POST "/api/hosts/facts" for 1.1.1.101 at 2013-12-20 12:00:21 +0900
Processing by Api::V2::HostsController#facts as JSON
Parameters: {"facts"=>"[FILTERED]", "certname"=>"shcha", "name"=>"shcha",
"apiv"=>"v2", "host"=>{"facts"=>"[FILTERED]", "certname"=>"shcha",
"name"=>"shcha"}}
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/core_ext/object/blank.rb:105:in
=~' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/core_ext/object/blank.rb:105:in
blank?' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/core_ext/object/blank.rb:21:in
present?'
/usr/share/foreman/app/services/fact_importer.rb:79:in block in normalize' /usr/share/foreman/app/services/fact_importer.rb:79:in
keep_if'
/usr/share/foreman/app/services/fact_importer.rb:79:in normalize' /usr/share/foreman/app/services/fact_importer.rb:19:in
initialize'
/usr/share/foreman/app/models/host/base.rb:81:in new' /usr/share/foreman/app/models/host/base.rb:81:in
importFacts'
/usr/share/foreman/app/models/host/managed.rb:375:in importHostAndFacts' /usr/share/foreman/app/controllers/api/v2/hosts_controller.rb:176:in
facts'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/implicit_render.rb:4:in
send_action' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/base.rb:167:in
process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rendering.rb:10:in
process_action' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/callbacks.rb:18:in
block in process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:450:in
block (3 levels) in _run__3241607684631692225__process_action__4250161371273684050__callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:215:in
block in _conditional_callback_around_4863'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:326:in
around' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:310:in
_callback_around_769'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:214:in
_conditional_callback_around_4863' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:427:in
block (2 levels) in
block in _conditional_callback_around_4862' /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:33:in
clear_thread'
_conditional_callback_around_4862' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:404:in
block in
block in _conditional_callback_around_4861' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:326:in
around'
_callback_around_13' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:214:in
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:403:in
_run__3241607684631692225__process_action__4250161371273684050__callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:405:in
__run_callback'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:385:in
_run_process_action_callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:81:in
run_callbacks'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/callbacks.rb:17:in
process_action' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rescue.rb:29:in
process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:30:in
block in process_action' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications.rb:123:in
block in instrument'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications/instrumenter.rb:20:in
instrument' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications.rb:123:in
instrument'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:29:in
process_action' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/params_wrapper.rb:207:in
process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/railties/controller_runtime.rb:18:in
process_action' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/base.rb:121:in
process'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/rendering.rb:45:in
process' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal.rb:203:in
dispatch'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rack_delegation.rb:14:in
dispatch' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal.rb:246:in
block in action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:73:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:73:in
dispatch'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:36:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/mapper.rb:42:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:68:in
block in call' /opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:56:in
each'
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:600:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/apipie-rails-0.0.23/lib/apipie/static_dispatcher.rb:56:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/best_standards_support.rb:17:in
call'
