A few month ago I have installed foreman 3.8 + katello 4.10 and can provision new Hosts without any problem.
Now I am trying to use the BMC to remotely control power of bare metal Hosts.
In CLI mode I can control the power of the Hosts with ipmitool:
ipmitool -I lanplus -U xxx -H 192.168.xxx.xxx chassis
I would like to remotely control the power with foreman GUI or hammer. I created an IPMI subnet and added a BMC interface type on the Host within the IMPI subnet.
The foreman-installer has been run with the options :
-foreman-proxy-bmc true --foreman-proxy-bmc-default-provider ipmitool
When I try with hammer, I have:
# hammer host status --id 4
Power operations are not enabled on this host.
On the GUI when I list the Hosts, the power button in front of the Host is inactive. When I do “Select Action/Change Power State” nothing happens when I select a power state even though I have a message “Success”.
The configuration files look good. I have read a few topics on the forum about the same error message but didn’t find a solution.
How could I debug the problem ? What should I check ?
Is there anyone using the bmc feature successfully ?
Christophe
PS: this is my first post. Sorry if the formatting is not good.
