Issue creating KVMs with libvirtd
When attempting to provision a new VM on a libvirtd compute resource, the following error message is seen:
  • Failed to create a compute MYHOSTNAME (Libvirt) instance tina-zerkle.mydomain.com: Error saving the server: Call to virDomainDefineXML failed: unknown procedure: 350
Foreman 1.19.0
libvirt.x86_64 0.10.2-64.el6
Libvirtd error:
2018-10-12 09:28:07.022+0000: 2529: error : virNetServerProgramDispatchCall:392 : unknown procedure: 350
Foreman log:
2018-10-12T10:28:06 [I|app|3c00e] Adding Compute instance for tina-zerkle.mydomain.com
2018-10-12T10:28:07 [W|app|3c00e] Unhandled Libvirt error
Fog::Errors::Error: Error saving the server: Call to virDomainDefineXML failed: unknown procedure: 350
/opt/theforeman/tfm/root/usr/share/gems/gems/fog-libvirt-0.4.1/lib/fog/libvirt/models/compute/server.rb:68:in `rescue in save'
/opt/theforeman/tfm/root/usr/share/gems/gems/fog-libvirt-0.4.1/lib/fog/libvirt/models/compute/server.rb:60:in `save'
/usr/share/foreman/app/models/compute_resources/foreman/model/libvirt.rb:153:in `create_vm'
/usr/share/foreman/app/models/concerns/orchestration/compute.rb:86:in `setCompute'
/usr/share/foreman/app/models/concerns/orchestration.rb:222:in `execute'
/usr/share/foreman/app/models/concerns/orchestration.rb:145:in `block in process'
/usr/share/foreman/app/models/concerns/orchestration.rb:137:in `each'
/usr/share/foreman/app/models/concerns/orchestration.rb:137:in `process'
/usr/share/foreman/app/models/concerns/orchestration.rb:44:in `around_save_orchestration'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/callbacks.rb:117:in `block in run_callbacks'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/callbacks.rb:135:in `run_callbacks'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/callbacks.rb:827:in `_run_save_callbacks'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/callbacks.rb:336:in `create_or_update'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/persistence.rb:129:in `save'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/validations.rb:44:in `save'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/attribute_methods/dirty.rb:35:in `save'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/transactions.rb:308:in `block (2 levels) in save'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/transactions.rb:384:in `block in with_transaction_returning_status'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/connection_adapters/abstract/database_statements.rb:235:in `block in transaction'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/connection_adapters/abstract/transaction.rb:194:in `block in within_new_transaction'
/opt/rh/rh-ruby24/root/usr/share/ruby/monitor.rb:214:in `mon_synchronize'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/connection_adapters/abstract/transaction.rb:191:in `within_new_transaction'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/connection_adapters/abstract/database_statements.rb:235:in `transaction'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/transactions.rb:210:in `transaction'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/transactions.rb:381:in `with_transaction_returning_status'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/transactions.rb:308:in `block in save'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/transactions.rb:323:in `rollback_active_record_state!'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/transactions.rb:307:in `save'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/suppressor.rb:42:in `save'
/usr/share/foreman/app/models/concerns/foreman/sti.rb:26:in `save'
/usr/share/foreman/app/controllers/hosts_controller.rb:104:in `create'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal/basic_implicit_render.rb:4:in `send_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/abstract_controller/base.rb:186:in `process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal/rendering.rb:30:in `process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/callbacks.rb:108:in `block in run_callbacks'
/opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.7.1/lib/audited/sweeper.rb:14:in `around'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/abstract_controller/callbacks.rb:19:in `process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal/rescue.rb:20:in `process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/notifications.rb:166:in `block in instrument'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/notifications/instrumenter.rb:21:in `instrument'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/notifications.rb:166:in `instrument'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal/params_wrapper.rb:252:in `process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activerecord-5.1.6/lib/active_record/railties/controller_runtime.rb:22:in `process_action'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/abstract_controller/base.rb:124:in `process'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionview-5.1.6/lib/action_view/rendering.rb:30:in `process'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal.rb:189:in `dispatch'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_controller/metal.rb:253:in `dispatch'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/routing/route_set.rb:31:in `serve'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/journey/router.rb:50:in `block in serve'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/journey/router.rb:33:in `each'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/journey/router.rb:33:in `serve'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/routing/route_set.rb:844:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.9/lib/apipie/static_dispatcher.rb:65:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.9/lib/apipie/extractor/recorder.rb:136:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.9/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/etag.rb:25:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/conditional_get.rb:38:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/head.rb:12:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/session/abstract/id.rb:232:in `context'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/session/abstract/id.rb:226:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/cookies.rb:613:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/callbacks.rb:97:in `run_callbacks'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/callbacks.rb:24:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.6/lib/rails/rack/logger.rb:36:in `call_app'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.6/lib/rails/rack/logger.rb:26:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/remote_ip.rb:79:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/request_id.rb:25:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/method_override.rb:22:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/runtime.rb:22:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.6/lib/active_support/cache/strategy/local_cache_middleware.rb:27:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/executor.rb:12:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/actionpack-5.1.6/lib/action_dispatch/middleware/static.rb:125:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/sendfile.rb:111:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-5.0.5/lib/secure_headers/middleware.rb:13:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.6/lib/rails/engine.rb:522:in `call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.6/lib/rails/railtie.rb:185:in `public_send'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/railties-5.1.6/lib/rails/railtie.rb:185:in `method_missing'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/urlmap.rb:68:in `block in call'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/urlmap.rb:53:in `each'
/opt/theforeman/tfm-ror51/root/usr/share/gems/gems/rack-2.0.3/lib/rack/urlmap.rb:53:in `call'
2018-10-12T10:28:07 [W|app|3c00e] Failed to create a compute MYHOSTNAME (Libvirt) instance tina-zerkle.mydomain.com: Error saving the server: Call to virDomainDefineXML failed: unknown procedure: 350
Hello, the Foreman stacktrace does not tell anything, you need to dig on the libvirtd side. Looks like there is something configured which does not work well with our input parameters.
Hi Izap,
It appears libvirt is complaining about a particular procedure that Foreman is trying to invoke:
Is there anyway to break down the request to understand more about what it might be? I’ve tested it against two separate libvirt hypervisors with the same result. Are you able to test a libvirt compute resource yourself with Foreman 19 and confirm it’s working?
https://github.com/vagrant-libvirt/vagrant-libvirt/issues/716 indicates this error is due to newer client libraries than the libvirt server you’re using.
Thanks Stephen, that makes sense.
So it looks as though Foreman (or at least the underlying fog-libvirt) is expecting the hypervisor to always support virDomainDefineXML which obviously isn’t the case.
For reference this Foreman instance is running on RHEL 7.4 and the hypervisor is an up-to-date RHEL 6.10.
I’ve tested Foreman 11 on a different RHEL7 instance which was able to successfully create VMs on RHEL6 hypervisors. So at some point between Foreman 11 and 19 the libvirt-fog Gem(?) changed to a version that broke compatibility, which now means that Foreman won’t work with CentOS / RHEL 6 hypervisors.
Should this be recorded as a bug?
Yes, I think so - if you wouldn’t mind filing a bug at https://projects.theforeman.org/projects/foreman/issues/new, we can take a look
https://projects.theforeman.org/issues/25202
I’ve closed the redmine issue as I thought this is issue of libvirt itself, but this thread shows it’s more like problem in libvirt-fog. However I suggest to report in for fog project rather than foreman.
Can’t believe this issue is was closed with “we have dropped support of EL6 about two years ago, this includes EL6 hypervisor”… RHEL6 isn’t EOL until late 2020. That’s just lazy.
Pardon me, but Foreman community does the best. We can’t fix all bugs, it is matter of priorization. However if you provide more details, some debugging and insights maybe you increase the chance that we actually find a solution together. So far, the bug report is one of these “it does not work, fix it”.
Moreover, if you need long term support do not use libvirt hypervisor but RHEV (oVirt) which has a stable API for a very long time. We do support that, libvirt is mostly recommended and used by us for testing.
Apples and oranges, RHEL6 lifecycle is irrelevant, we are talking about Foreman support cycle which is very much different.
The best part is this is most likely not a bug for Foreman project but for fog-libvirt project. These are different folks, try complaining there maybe you will have better luck.
For what it’s worth, even Red Hat itself has dropped support for running Satellite on RHEL 6. There are many features in EL7 that we use and rely on. Attempting to backport this has no real benefit and just wastes time we can spend on improving other services.
We can also turn it around: not upgrading your (Foreman) servers is just lazy.
