Issue installing foreman 3.4 with katello 4.6. Please advise for clean install.
Clean installation after uninstalling previous foreman 3.3 installation (without katello)
CENTOS 8 STREAM
Need to get rid of existing installation/configuration (foreman 3.3) and install foreman 3.4 with katello 4.6 fresh but encountering below error while using 3.4 quickstart for installation =
https://docs.theforeman.org/3.4/Quickstart/index-katello.html#
[root@sjc-foreman-it it_tools]# foreman-installer --scenario katello
2022-09-23 11:04:42 [NOTICE] [root] Loading installer configuration. This will take some time.
2022-09-23 11:04:46 [NOTICE] [root] Running installer with log based terminal output at level NOTICE.
2022-09-23 11:04:46 [NOTICE] [root] Use -l to set the terminal output log level to ERROR, WARN, NOTICE, INFO, or DEBUG. See --full-help for definitions.
2022-09-23 11:04:53 [NOTICE] [configure] Starting system configuration.
2022-09-23 11:05:05 [NOTICE] [configure] 250 configuration steps out of 1382 steps complete.
2022-09-23 11:05:09 [NOTICE] [configure] 500 configuration steps out of 1384 steps complete.
2022-09-23 11:05:12 [NOTICE] [configure] 750 configuration steps out of 1390 steps complete.
2022-09-23 11:05:13 [NOTICE] [configure] 1000 configuration steps out of 1393 steps complete.
2022-09-23 11:05:34 [ERROR ] [configure] '/usr/sbin/foreman-rake db:migrate' returned 1 instead of one of [0]
2022-09-23 11:05:34 [ERROR ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]/returns: change from 'notrun' to ['0'] failed: '/usr/sbin/foreman-rake db:migrate' returned 1 instead of one of [0]
2022-09-23 11:05:44 [NOTICE] [configure] 1250 configuration steps out of 1393 steps complete.
2022-09-23 11:05:57 [NOTICE] [configure] System configuration has finished.
[root@sjc-foreman-it gems]# foreman-rake db:migrate
== 20131014225132 AddUsersFields: migrating ===================================
-- add_column(:users, :helptips_enabled, :boolean, {:default=>true})
-> 0.0018s
-- add_column(:users, :hidden, :boolean, {:default=>false, :null=>false})
-> 0.0007s
-- add_column(:users, :page_size, :integer, {:default=>25, :null=>false})
-> 0.0007s
-- add_column(:users, :disabled, :boolean, {:default=>false})
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
PG::DuplicateColumn: ERROR: column "disabled" of relation "users" already exists
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:49:in `exec'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:49:in `block (2 levels) in execute'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:48:in `block in execute'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/abstract_adapter.rb:696:in `block (2 levels) in log'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/abstract_adapter.rb:695:in `block in log'
/usr/share/gems/gems/activesupport-6.1.6.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/abstract_adapter.rb:687:in `log'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:47:in `execute'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/abstract/schema_statements.rb:611:in `add_column'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/postgresql/schema_statements.rb:398:in `add_column'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:929:in `block in method_missing'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:897:in `block in say_with_time'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:897:in `say_with_time'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:918:in `method_missing'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration/compatibility.rb:211:in `add_column'
/usr/share/gems/gems/katello-4.6.0.rc2/db/migrate/20131014225132_add_users_fields.rb:6:in `change'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:867:in `exec_migration'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:851:in `block (2 levels) in migrate'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:850:in `block in migrate'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:462:in `with_connection'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:849:in `migrate'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1037:in `migrate'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1329:in `block in execute_migration_in_transaction'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1380:in `block in ddl_transaction'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `block in transaction'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/abstract/transaction.rb:319:in `block in within_new_transaction'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/abstract/transaction.rb:317:in `within_new_transaction'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `transaction'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/transactions.rb:209:in `transaction'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1380:in `ddl_transaction'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1328:in `execute_migration_in_transaction'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1302:in `each'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1302:in `migrate_without_lock'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1251:in `block in migrate'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1401:in `block in with_advisory_lock'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1416:in `block in with_advisory_lock_connection'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1416:in `with_advisory_lock_connection'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1397:in `with_advisory_lock'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1251:in `migrate'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1086:in `up'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/migration.rb:1061:in `migrate'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/tasks/database_tasks.rb:237:in `migrate'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/railties/databases.rake:92:in `block (3 levels) in <top (required)>'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/railties/databases.rake:90:in `each'
/usr/share/gems/gems/activerecord-6.1.6.1/lib/active_record/railties/databases.rake:90:in `block (2 levels) in <top (required)>'
/usr/share/gems/gems/rake-13.0.1/exe/rake:27:in `<top (required)>'
Caused by:
ActiveRecord::StatementInvalid: PG::DuplicateColumn: ERROR: column "disabled" of relation "users" already exists
Caused by:
Tasks: TOP => db:migrate
It seem @katello extends User model with disabled column and then drops that, such column was though introduced in core in Foreman 2.2. So if the DB is migrated without Katello first and Katello is later installed, it will cause problems. This is already reported as Bug #30269: Adding Katello and migrating the database after having already migrated Foreman results in an error - Katello - Foreman from two years ago. If this is a fresh install, you should install both Foreman and Katello at the same time. The right solution would probably be dropping the disabled column from the migrations (they are from year 2013 and 2015, these are unsupported version of Katello, so we don’t have to care of versioning there)
iballou
September 27, 2022, 6:36pm
4
If you’re truly creating a fresh install, you should be able to work around this with RAILS_ENV=production foreman-rake db:drop and then RAILS_ENV=production foreman-rake db:create. Then you can re-run the foreman-installer.
