Issue syncing centos-8-stream appstream repository
Successfully sync repository
Output:
{“pulp_tasks”=>
[{“exception”=>nil,
“task_type”=>“pulp.server.managers.repo.sync.sync”,
“_href”=>"/pulp/api/v2/tasks/0644bc8e-fa7a-429d-b930-ad8b1cc899ef/",
“task_id”=>“0644bc8e-fa7a-429d-b930-ad8b1cc899ef”,
“tags”=>
[“pulp:repository:4e133d48-ca95-4cd6-9234-33718e880889”,
“pulp:action:sync”],
“finish_time”=>“2022-11-02T20:58:45Z”,
“ns"=>“task_status”,
“start_time”=>“2022-11-02T20:51:39Z”,
“traceback”=>
“Traceback (most recent call last):\n” +
" File “/usr/lib/python2.7/site-packages/celery/app/trace.py”, line 367, in trace_task\n" +
" R = retval = fun(*args, **kwargs)\n" +
" File “/usr/lib/python2.7/site-packages/pulp/server/async/tasks.py”, line 686, in call\n" +
" return super(Task, self).call(*args, **kwargs)\n" +
" File “/usr/lib/python2.7/site-packages/pulp/server/async/tasks.py”, line 108, in call\n" +
" return super(PulpTask, self).call(*args, **kwargs)\n" +
" File “/usr/lib/python2.7/site-packages/celery/app/trace.py”, line 622, in protected_call\n" +
" return self.run(*args, **kwargs)\n" +
" File “/usr/lib/python2.7/site-packages/pulp/server/controllers/repository.py”, line 851, in sync\n" +
" raise pulp_exceptions.PulpExecutionException((‘Importer indicated a failed response’))\n” +
“PulpExecutionException: Importer indicated a failed response\n”,
“spawned_tasks”=>,
“progress_report”=>
{“yum_importer”=>
{“content”=>
{“items_total”=>0,
“state”=>“FINISHED”,
“error_details”=>,
“details”=>
{“rpm_total”=>0, “rpm_done”=>0, “drpm_total”=>0, “drpm_done”=>0},
“size_total”=>0,
“size_left”=>0,
“items_left”=>0},
“comps”=>{“state”=>“NOT_STARTED”},
“purge_duplicates”=>{“state”=>“NOT_STARTED”},
“distribution”=>
{“items_total”=>0,
“error_details”=>,
“items_left”=>0},
“modules”=>
{“state”=>“FAILED”, “error”=>“expected a character buffer object”},
“errata”=>{“state”=>“NOT_STARTED”},
“metadata”=>{“state”=>“FINISHED”}}},
“queue”=>“reserved_resource_worker-1@10-222-43-159.ssnc-corp.cloud.dq2”,
“state”=>“error”,
“worker_name”=>“reserved_resource_worker-1@10-222-43-159.ssnc-corp.cloud”,
“result”=>nil,
“error”=>
{“code”=>“PLP0000”,
“data”=>{},
“description”=>“Importer indicated a failed response”,
“sub_errors”=>},
“_id”=>{"$oid"=>“6362d85b0e8fb7dc92494a41”},
“id”=>“6362d85b0e8fb7dc92494a41”}],
“contents_changed”=>true,
“poll_attempts”=>{“total”=>47, “failed”=>1}}
Exception:
Katello::Errors::PulpError: PLP0000: Importer indicated a failed response
Backtrace:
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/pulp/abstract_async_task.rb:122:in block in external_task=' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/pulp/abstract_async_task.rb:120:in
each’
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/pulp/abstract_async_task.rb:120:in external_task=' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/pulp/repository/sync.rb:28:in
external_task=’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action/polling.rb:100:in poll_external_task_with_rescue' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action/polling.rb:22:in
run’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action/cancellable.rb:14:in run' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/pulp/abstract_async_task.rb:45:in
run’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:563:in block (3 levels) in execute_run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware/stack.rb:27:in
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware.rb:19:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware.rb:32:in
run’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware/stack.rb:23:in call' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware/stack.rb:27:in
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware.rb:19:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/middleware/remote_action.rb:16:in
block in run’
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/middleware/remote_action.rb:40:in block in as_remote_user' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/models/katello/concerns/user_extensions.rb:21:in
cp_config’
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/middleware/remote_action.rb:27:in as_cp_user' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/middleware/remote_action.rb:39:in
as_remote_user’
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/middleware/remote_action.rb:16:in run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware/stack.rb:23:in
call’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware/stack.rb:27:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware.rb:19:in
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/rails_executor_wrap.rb:14:in block in run' /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/execution_wrapper.rb:87:in
wrap’
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/rails_executor_wrap.rb:13:in run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware/stack.rb:23:in
call’
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action/progress.rb:31:in with_progress_calculation' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action/progress.rb:17:in
run’
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware.rb:19:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/middleware/keep_locale.rb:11:in
block in run’
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/middleware/keep_locale.rb:22:in with_locale' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/middleware/keep_locale.rb:11:in
run’
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware.rb:19:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_request_id.rb:15:in
block in run’
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_request_id.rb:49:in restore_current_request_id' /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_request_id.rb:15:in
run’
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware.rb:19:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_timezone.rb:15:in
block in run’
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_timezone.rb:44:in restore_curent_timezone' /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_timezone.rb:15:in
run’
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware.rb:19:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_user.rb:15:in
block in run’
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_user.rb:44:in restore_curent_user' /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_user.rb:15:in
run’
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware.rb:19:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_taxonomies.rb:15:in
block in run’
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_taxonomies.rb:45:in restore_current_taxonomies' /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_taxonomies.rb:15:in
run’
pass’
run’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware/stack.rb:23:in call' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware/world.rb:31:in
execute’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:562:in block (2 levels) in execute_run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:561:in
catch’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:561:in block in execute_run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:475:in
block in with_error_handling’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:475:in catch' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:475:in
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:556:in execute_run' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:285:in
execute’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:18:in block (2 levels) in execute' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/execution_plan/steps/abstract.rb:167:in
with_meta_calculation’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:17:in block in execute' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:32:in
open_action’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:16:in execute' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/director.rb:93:in
execute’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors/parallel/worker.rb:15:in block in on_message' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors.rb:12:in
run_user_code’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors/parallel/worker.rb:14:in on_message' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/context.rb:46:in
on_envelope’
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/executes_context.rb:7:in on_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/abstract.rb:25:in
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/actor.rb:106:in on_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/abstract.rb:25:in
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/awaits.rb:15:in on_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/abstract.rb:25:in
pass’
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/sets_results.rb:14:in on_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/actor.rb:47:in
block in on_envelope’
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/actor.rb:59:in with_backtrace' /opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/actor.rb:47:in
on_envelope’
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/abstract.rb:25:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/buffer.rb:38:in
process_envelope’
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/buffer.rb:31:in process_envelopes?' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/buffer.rb:20:in
on_envelope’
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/abstract.rb:25:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/termination.rb:55:in
on_envelope’
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/abstract.rb:25:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/removes_child.rb:10:in
on_envelope’
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/abstract.rb:25:in pass' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/behaviour/sets_results.rb:14:in
on_envelope’
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/core.rb:162:in process_envelope' /opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/core.rb:96:in
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/core.rb:119:in block (2 levels) in schedule_execution' /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/concurrent-ruby-1.1.4/lib/concurrent/synchronization/mutex_lockable_object.rb:41:in
block in synchronize’
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/concurrent-ruby-1.1.4/lib/concurrent/synchronization/mutex_lockable_object.rb:41:in synchronize' /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/concurrent-ruby-1.1.4/lib/concurrent/synchronization/mutex_lockable_object.rb:41:in
synchronize’
/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.4.1/lib-edge/concurrent/actor/core.rb:116:in block in schedule_execution' /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/concurrent-ruby-1.1.4/lib/concurrent/executor/serialized_execution.rb:18:in
call’
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/concurrent-ruby-1.1.4/lib/concurrent/executor/serialized_execution.rb:96:in work' /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/concurrent-ruby-1.1.4/lib/concurrent/executor/serialized_execution.rb:77:in
block in call_job’
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/concurrent-ruby-1.1.4/lib/concurrent/executor/ruby_thread_pool_executor.rb:348:in run_task' /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/concurrent-ruby-1.1.4/lib/concurrent/executor/ruby_thread_pool_executor.rb:337:in
block (3 levels) in create_worker’
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/concurrent-ruby-1.1.4/lib/concurrent/executor/ruby_thread_pool_executor.rb:320:in loop' /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/concurrent-ruby-1.1.4/lib/concurrent/executor/ruby_thread_pool_executor.rb:320:in
block (2 levels) in create_worker’
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/concurrent-ruby-1.1.4/lib/concurrent/executor/ruby_thread_pool_executor.rb:319:in catch' /opt/theforeman/tfm-ror52/root/usr/share/gems/gems/concurrent-ruby-1.1.4/lib/concurrent/executor/ruby_thread_pool_executor.rb:319:in
block in create_worker’
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context’
