Hello everybody,
I have been working with Foreman for a few weeks. Now I would like to provision VMs via VMware.
Since the DHCP servers are running Windows and I do not have access to these systems, I can’t use PXE to deploy systems.
So I have the “bootdisk” plugin installed and the “Compute Resource” configured.
Here are some details to our environment:
OS: CentOS 7.6.1810
Foreman-Version: 1.20.1
Foreman-Bootdisk-Plugin: 14.0.0
As Compute-Resource we use VMware vCenter:
VMware vCenter Server: 6.0.0
ESXi-Version: 6.0.0
If I now create a new host (Deploy on VMware) and choose “Boot disk based” as the provisioning method, the VM will be created in the vCenter for a short time and deleted then again.
The error message in the web UI is “Failed to upload ISO image for instance …: NoPermission”
Log output in /var/log/foreman/production.log:
2019-01-15T15:12:19 [W|app|a8967] Failed to upload ISO image for instance lucia-sturdy.domain.tld: NoPermission: Die Berechtigung zur Durchführung dieses Vorgangs wurde verweigert.
RbVmomi::Fault: NoPermission: Die Berechtigung zur Durchführung dieses Vorgangs wurde verweigert.
/opt/theforeman/tfm/root/usr/share/gems/gems/rbvmomi-1.10.0/lib/rbvmomi/connection.rb:63:in `parse_response'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbvmomi-1.10.0/lib/rbvmomi/connection.rb:92:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbvmomi-1.10.0/lib/rbvmomi/basic_types.rb:213:in `_call'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbvmomi-1.10.0/lib/rbvmomi/basic_types.rb:76:in `block (2 levels) in init'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbvmomi-1.10.0/lib/rbvmomi/vim/Folder.rb:10:in `find'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbvmomi-1.10.0/lib/rbvmomi/vim/Folder.rb:96:in `traverse'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbvmomi-1.10.0/lib/rbvmomi/vim/ServiceInstance.rb:11:in `find_datacenter'
/opt/theforeman/tfm/root/usr/share/gems/gems/fog-vsphere-2.3.0/lib/fog/vsphere/requests/compute/get_datacenter.rb:18:in `get_raw_datacenter'
/opt/theforeman/tfm/root/usr/share/gems/gems/fog-vsphere-2.3.0/lib/fog/vsphere/requests/compute/upload_iso.rb:22:in `upload_iso'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_bootdisk-14.0.0/app/models/concerns/foreman_bootdisk/compute_resources/vmware.rb:31:in `iso_upload'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_bootdisk-14.0.0/app/models/concerns/foreman_bootdisk/orchestration/compute.rb:42:in `bootdisk_upload_iso'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_bootdisk-14.0.0/app/models/concerns/foreman_bootdisk/orchestration/compute.rb:60:in `setIsoImage'
/usr/share/foreman/app/models/concerns/orchestration.rb:222:in `execute'
/usr/share/foreman/app/models/concerns/orchestration.rb:145:in `block in process'
/usr/share/foreman/app/models/concerns/orchestration.rb:137:in `each'
/usr/share/foreman/app/models/concerns/orchestration.rb:137:in `process'
/usr/share/foreman/app/models/concerns/orchestration.rb:44:in `around_save_orchestration'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:816:in `_run_save_callbacks'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/callbacks.rb:342:in `create_or_update'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/persistence.rb:275:in `save'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/validations.rb:46:in `save'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:310:in `block (2 levels) in save'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:387:in `block in with_transaction_returning_status'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:254:in `block in transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:239:in `block in within_new_transaction'
/opt/rh/rh-ruby25/root/usr/share/ruby/monitor.rb:226:in `mon_synchronize'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:236:in `within_new_transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:254:in `transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:212:in `transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:385:in `with_transaction_returning_status'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:310:in `block in save'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:325:in `rollback_active_record_state!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:309:in `save'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/suppressor.rb:44:in `save'
/usr/share/foreman/app/models/concerns/foreman/sti.rb:26:in `save'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.14.3/app/models/foreman_tasks/concerns/action_triggering.rb:27:in `block in save'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.14.3/app/models/foreman_tasks/concerns/action_triggering.rb:114:in `dynflow_task_wrap'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.14.3/app/models/foreman_tasks/concerns/action_triggering.rb:27:in `save'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.14.3/app/models/foreman_tasks/concerns/action_triggering.rb:127:in `dynflow_task_wrap'
/usr/share/foreman/app/controllers/hosts_controller.rb:104:in `create'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/base.rb:194:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rendering.rb:30:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.7.1/lib/audited/sweeper.rb:14:in `around'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/callbacks.rb:41:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rescue.rb:22:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/base.rb:134:in `process'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/rendering.rb:32:in `process'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal.rb:191:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal.rb:252:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:35:in `each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:35:in `serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:840:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/static_dispatcher.rb:65:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/extractor/recorder.rb:137:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/tempfile_reaper.rb:15:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/etag.rb:25:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/conditional_get.rb:38:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/head.rb:12:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:232:in `context'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:226:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:98:in `run_callbacks'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/rack/logger.rb:38:in `call_app'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/rack/logger.rb:28:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.9.1/lib/katello/prevent_json_parsing.rb:12:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/method_override.rb:22:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/runtime.rb:22:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/sendfile.rb:111:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-6.0.0/lib/secure_headers/middleware.rb:13:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/urlmap.rb:68:in `block in call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `call'
2019-01-15T15:12:19 [W|app|a8967] Rolling back due to a problem: [#<Orchestration::Task:0x00007fd3133c5918 @name="Upload ISO image to datastore for lucia-sturdy.domain.tld", @id="Upload ISO image to datastore for lucia-sturdy.domain.tld", @status="failed", @priority=6, @action=[#<Host::Managed id: nil, name: "lucia-sturdy.domain.tld", last_compile: nil, last_report: nil, updated_at: nil, created_at: nil, root_pass: "$5$PeGm8UEPIHuiOozr$bPKMSMNR/evaBBusAHVlNaXX96hI54...", architecture_id: 1, operatingsystem_id: 5, environment_id: 2, ptable_id: 99, medium_id: 1, build: true, comment: "", disk: "", installed_at: nil, model_id: nil, hostgroup_id: 3, owner_id: 5, owner_type: "User", enabled: true, puppet_ca_proxy_id: 1, managed: true, use_image: nil, image_file: nil, uuid: "50281206-5384-dbfc-104a-81d0c5e16d31", compute_resource_id: 1, puppet_proxy_id: 1, certname: nil, image_id: nil, organization_id: 1, location_id: 2, type: "Host::Managed", otp: nil, realm_id: nil, compute_profile_id: 1, provision_method: "bootdisk", grub_pass: "$6$e6xwxMK6xRPwbIAq$YSZ08Ptl06V0KqEjdGn1vfBJRF3Ay....", global_status: 0, lookup_value_matcher: "fqdn=lucia-sturdy.domain.tld", pxe_loader: "iPXE Chain BIOS", initiated_at: nil, build_errors: nil>, :setIsoImage], @created=1547561537.0639434, @timestamp=2019-01-15 14:12:19 UTC>]
2019-01-15T15:12:19 [I|app|a8967] Removing Compute instance for lucia-sturdy.domain.tld
The ISO image is created successful (/tmp/systemd-private-396b32ec9a144d0584b7938d286b7733-httpd.service-WgekRz/tmp/d20190115-21976-1dcosmd/lucia-sturdy.domain.tld.iso).
The account for the “Compute Resource” has admin rights in VMware. With the vSphere client I can upload ISO images with this account.
Can somebody help me or give me a hint? If you need more details or logs, let me know.
Many thanks, Stefan.
