I am testing foreman and trying to get it to work with chef (chef server version is 11.12)
no chef facts / reports uploaded to foreman
chef-client runs ok on the node, but foreman displays the following error:
2019-04-02T12:06:14 [W|app|4470d5d5] Action failed
ActiveRecord::NotNullViolation: PG::NotNullViolation: ERROR: null value in column "fact_name_id" violates not-null constraint
DETAIL: Failing row contains (431, null, null, 7, 2019-04-02 12:06:14.357153, 2019-04-02 12:06:14.357153).
: INSERT INTO "fact_values" ("host_id", "updated_at", "created_at") VALUES ($1, $2, $3) RETURNING "id"
extended log output is below.
foreman 1.21
smart_proxy_chef (0.2.0)
on the chef clients: chef_handler_foreman (0.2.0)
foreman chef proxy configuration:
:enabled: true
:chef_authenticate_nodes: true
:chef_server_url: https://chef-server.example.com
:chef_smartproxy_clientname: foreman
:chef_smartproxy_privatekey: /etc/foreman-proxy/foreman.pem
:chef_ssl_verify: false
chef-client client.rb file:
log_level :info
log_location STDOUT
chef_server_url ‘https://chef-server.example.com’
ssl_verify_mode :verify_none
validation_client_name ‘chef-validator’
validation_key ‘/etc/chef/chef-validator.pem’
node_name ‘opvitlinfor001.example.com’
require ‘chef_handler_foreman’
foreman_server_options :url => ‘https://opvitlinfor001.vitc-linux.visma.com:8443’
foreman_facts_upload true
foreman_reports_upload 'true,2 ’
foreman_enc true
2019-04-02T12:06:00 [I|app|f4655b1b] Started GET "/node/adm-acp-td936.example.com?format=yml" for 10.55.9.27 at 2019-04-02 12:06:00 +0000
2019-04-02T12:06:00 [I|app|f4655b1b] Processing by HostsController#externalNodes as YML
2019-04-02T12:06:00 [I|app|f4655b1b] Parameters: {"name"=>"adm-acp-td936.example.com", "host"=>{}}
2019-04-02T12:06:00 [D|app|f4655b1b] Examining client certificate to extract dn and sans
2019-04-02T12:06:00 [D|app|f4655b1b] Client sent certificate with subject 'opvitlinfor001.example.com' and subject alt names '["opvitlinfor001.example.com", "puppet", "puppet.example.com"]'
2019-04-02T12:06:00 [D|app|f4655b1b] Verifying request from ["opvitlinfor001.example.com", "puppet", "puppet.example.com"] against ["opvitlinfor001.example.com"]
2019-04-02T12:06:00 [D|app|f4655b1b] Current user set to foreman_api_admin (admin)
2019-04-02T12:06:00 [I|app|f4655b1b] Rendering text template
2019-04-02T12:06:00 [I|app|f4655b1b] Rendered text template (0.0ms)
2019-04-02T12:06:00 [I|app|f4655b1b] Completed 200 OK in 175ms (Views: 0.4ms | ActiveRecord: 33.0ms)
2019-04-02T12:06:10 [I|app|4470d5d5] Started POST "/api/hosts/facts" for 10.55.9.27 at 2019-04-02 12:06:10 +0000
2019-04-02T12:06:10 [I|app|4470d5d5] Processing by Api::V2::HostsController#facts as JSON
2019-04-02T12:06:10 [I|app|4470d5d5] Parameters: {"name"=>"adm-acp-td936.example.com", "facts"=>"[FILTERED]", "apiv"=>"v2", "host"=>{"name"=>"adm-acp-td936.example.com"}}
2019-04-02T12:06:10 [D|app|4470d5d5] Examining client certificate to extract dn and sans
2019-04-02T12:06:10 [D|app|4470d5d5] Client sent certificate with subject 'opvitlinfor001.example.com' and subject alt names '["opvitlinfor001.example.com", "puppet", "puppet.example.com"]'
2019-04-02T12:06:10 [D|app|4470d5d5] Verifying request from ["opvitlinfor001.example.com", "puppet", "puppet.example.com"] against ["opvitlinfor001.example.com"]
2019-04-02T12:06:10 [D|app|4470d5d5] Current user set to foreman_api_admin (admin)
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/postgresql_adapter.rb:603:in `async_exec'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/postgresql_adapter.rb:603:in `block (2 levels) in exec_no_cache'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/postgresql_adapter.rb:602:in `block in exec_no_cache'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:579:in `block (2 levels) in log'
/opt/rh/rh-ruby25/root/usr/share/ruby/monitor.rb:226:in `mon_synchronize'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:578:in `block in log'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:569:in `log'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/postgresql_adapter.rb:601:in `exec_no_cache'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/postgresql_adapter.rb:590:in `execute_and_clear'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:81:in `exec_query'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:117:in `exec_insert'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:115:in `exec_insert'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:149:in `insert'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/query_cache.rb:21:in `insert'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/persistence.rb:187:in `_insert_record'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/persistence.rb:733:in `_create_record'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/counter_cache.rb:184:in `_create_record'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/locking/optimistic.rb:70:in `_create_record'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/attribute_methods/dirty.rb:137:in `_create_record'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/callbacks.rb:346:in `block in _create_record'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:132:in `run_callbacks'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:816:in `_run_create_callbacks'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/callbacks.rb:346:in `_create_record'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/timestamp.rb:102:in `_create_record'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/persistence.rb:704:in `create_or_update'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/callbacks.rb:342:in `block in create_or_update'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:816:in `_run_save_callbacks'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/callbacks.rb:342:in `create_or_update'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/persistence.rb:308:in `save!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/validations.rb:52:in `save!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:315:in `block in save!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:387:in `block in with_transaction_returning_status'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:252:in `transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:212:in `transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:385:in `with_transaction_returning_status'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:315:in `save!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/suppressor.rb:48:in `save!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/associations/collection_association.rb:375:in `insert_record'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/associations/has_many_association.rb:36:in `insert_record'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/associations/collection_association.rb:361:in `block (2 levels) in _create_record'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/associations/collection_association.rb:458:in `replace_on_target'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/associations/collection_association.rb:282:in `add_to_target'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/associations/collection_association.rb:360:in `block in _create_record'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/associations/collection_association.rb:134:in `block in transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/associations/collection_association.rb:133:in `transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/associations/collection_association.rb:358:in `_create_record'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/associations/has_many_association.rb:123:in `_create_record'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/associations/association.rb:186:in `create!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/associations/collection_proxy.rb:366:in `create!'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_chef-0.8.1/app/models/foreman_chef/fact_importer.rb:67:in `add_fact'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_chef-0.8.1/app/models/foreman_chef/fact_importer.rb:60:in `block in add_missing_facts'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_chef-0.8.1/app/models/foreman_chef/fact_importer.rb:32:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_chef-0.8.1/app/models/foreman_chef/fact_importer.rb:32:in `add_missing_facts'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_chef-0.8.1/app/models/foreman_chef/fact_importer.rb:27:in `add_new_facts'
/usr/share/foreman/app/services/fact_importer.rb:61:in `block in import!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:254:in `block in transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:239:in `block in within_new_transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:236:in `within_new_transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:254:in `transaction'
/usr/share/foreman/app/services/fact_importer.rb:58:in `import!'
/usr/share/foreman/app/models/host/base.rb:147:in `block in import_facts'
/usr/share/foreman/app/services/foreman/telemetry_helper.rb:27:in `telemetry_duration_histogram'
/usr/share/foreman/app/models/host/base.rb:146:in `import_facts'
/usr/share/foreman/app/models/host/managed.rb:320:in `import_facts'
/usr/share/foreman/app/controllers/api/v2/hosts_controller.rb:288:in `facts'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/base.rb:194:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rendering.rb:30:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/usr/share/foreman/app/controllers/api/v2/base_controller.rb:163:in `disable_json_root'
/opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.7.1/lib/audited/sweeper.rb:14:in `around'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/callbacks.rb:41:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rescue.rb:22:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/base.rb:134:in `process'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/rendering.rb:32:in `process'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal.rb:191:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal.rb:252:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/mapper.rb:48:in `serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:35:in `each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:35:in `serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:840:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/static_dispatcher.rb:65:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/extractor/recorder.rb:137:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/tempfile_reaper.rb:15:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/etag.rb:25:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/conditional_get.rb:38:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/head.rb:12:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:232:in `context'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:226:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:98:in `run_callbacks'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/rack/logger.rb:38:in `call_app'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/rack/logger.rb:28:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/method_override.rb:22:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/runtime.rb:22:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/sendfile.rb:111:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-6.0.0/lib/secure_headers/middleware.rb:13:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/urlmap.rb:68:in `block in call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `call'
2019-04-02T12:06:14 [I|app|4470d5d5] Rendering api/v2/errors/standard_error.json.rabl within api/v2/layouts/error_layout
2019-04-02T12:06:14 [I|app|4470d5d5] Rendered api/v2/errors/standard_error.json.rabl within api/v2/layouts/error_layout (0.4ms)
2019-04-02T12:06:14 [I|app|4470d5d5] Completed 500 Internal Server Error in 3622ms (Views: 1.0ms | ActiveRecord: 304.2ms)
2019-04-02T12:06:14 [I|app|7d010f2f] Started POST "/api/reports" for 10.55.9.27 at 2019-04-02 12:06:14 +0000
2019-04-02T12:06:14 [I|app|7d010f2f] Processing by Api::V2::ReportsController#create as JSON
2019-04-02T12:06:14 [I|app|7d010f2f] Parameters: {"report"=>"[FILTERED]", "apiv"=>"v2"}
2019-04-02T12:06:14 [D|app|7d010f2f] Examining client certificate to extract dn and sans
2019-04-02T12:06:14 [D|app|7d010f2f] Client sent certificate with subject 'opvitlinfor001.example.com' and subject alt names '["opvitlinfor001.example.com", "puppet", "puppet.example.com"]'
2019-04-02T12:06:14 [D|app|7d010f2f] Verifying request from ["opvitlinfor001.example.com", "puppet", "puppet.example.com"] against ["opvitlinfor001.example.com"]
2019-04-02T12:06:14 [D|app|7d010f2f] Current user set to foreman_api_admin (admin)
2019-04-02T12:06:14 [D|app|7d010f2f] Processing report: {"host"=>"adm-acp-td936.example.com", "reported_at"=>"2019-04-02 12:06:02 +0000", "status"=>{"applied"=>1, "restarted"=>1, "failed"=>0, "failed_restarts"=>0, "skipped"=>0, "pending"=>0}, "metrics"=>{"resources"=>{"total"=>4}, "time"=>{"apt_package"=>0.058870121, "template"=>0.007326711, "service"=>1.117910203}}, "logs"=>[{"log"=>{"sources"=>{"source"=>"apt_package[ntp_package]"}, "messages"=>{"message"=>"[:install]"}, "level"=>"debug"}}, {"log"=>{"sources"=>{"source"=>"template[/etc/ntp.conf]"}, "messages"=>{"message"=>"create"}, "level"=>"debug"}}, {"log"=>{"sources"=>{"source"=>"service[ntp]"}, "messages"=>{"message"=>"[:enable, :restart]"}, "level"=>"notice"}}, {"log"=>{"sources"=>{"source"=>"service[ntp]"}, "messages"=>{"message"=>"[:enable, :restart]"}, "level"=>"notice"}}, {"log"=>{"sources"=>{"source"=>"Chef"}, "messages"=>{"message"=>"run"}, "level"=>"notice"}}]}
2019-04-02T12:06:14 [D|dyn|7d010f2f] ExecutionPlan 0b2000f0-18bb-4d97-b0fd-560f737194a0 pending >> planning
2019-04-02T12:06:14 [D|dyn|7d010f2f] Step 0b2000f0-18bb-4d97-b0fd-560f737194a0: 1 pending >> running in phase Plan Actions::ForemanChef::Host::Update
2019-04-02T12:06:14 [D|dyn|7d010f2f] Step 0b2000f0-18bb-4d97-b0fd-560f737194a0: 1 running >> success in phase Plan Actions::ForemanChef::Host::Update
2019-04-02T12:06:14 [D|dyn|7d010f2f] ExecutionPlan 0b2000f0-18bb-4d97-b0fd-560f737194a0 planning >> planned
2019-04-02T12:06:14 [I|app|7d010f2f] Scanning report with: Foreman::PuppetReportScanner
2019-04-02T12:06:14 [D|app|7d010f2f] Changes after scanning: {"host_id"=>[nil, 7], "reported_at"=>[nil, Tue, 02 Apr 2019 12:06:02 UTC +00:00], "status"=>[nil, 65], "metrics"=>[nil, "---\nresources: !ruby/hash:ActiveSupport::HashWithIndifferentAccess\n total: 4\ntime: !ruby/hash:ActiveSupport::HashWithIndifferentAccess\n apt_package: 0.058870121\n template: 0.007326711\n service: 1.117910203\n"]}
2019-04-02T12:06:14 [D|dyn|7d010f2f] ExecutionPlan a70cc0d8-5244-4cd9-8849-23492e9eae1c pending >> planning
2019-04-02T12:06:14 [D|dyn|7d010f2f] Step a70cc0d8-5244-4cd9-8849-23492e9eae1c: 1 pending >> running in phase Plan Actions::ForemanChef::Host::Update
2019-04-02T12:06:14 [D|dyn|7d010f2f] Step a70cc0d8-5244-4cd9-8849-23492e9eae1c: 1 running >> success in phase Plan Actions::ForemanChef::Host::Update
2019-04-02T12:06:14 [D|dyn|7d010f2f] ExecutionPlan a70cc0d8-5244-4cd9-8849-23492e9eae1c planning >> planned
2019-04-02T12:06:14 [D|dyn|7d010f2f] ExecutionPlan 912b9aac-389d-4200-8241-5e38316c94de pending >> planning
2019-04-02T12:06:14 [D|dyn|7d010f2f] Step 912b9aac-389d-4200-8241-5e38316c94de: 1 pending >> running in phase Plan Actions::ForemanChef::Host::Update
2019-04-02T12:06:15 [D|dyn|7d010f2f] Step 912b9aac-389d-4200-8241-5e38316c94de: 1 running >> success in phase Plan Actions::ForemanChef::Host::Update
2019-04-02T12:06:15 [D|dyn|7d010f2f] ExecutionPlan 912b9aac-389d-4200-8241-5e38316c94de planning >> planned
2019-04-02T12:06:15 [I|app|7d010f2f] Imported report for adm-acp-td936.example.com in 421.8 ms, status refreshed in 205.0 ms
2019-04-02T12:06:15 [I|app|7d010f2f] Rendering api/v2/reports/create.json.rabl
2019-04-02T12:06:15 [I|app|7d010f2f] Rendered api/v2/reports/create.json.rabl (12.4ms)
2019-04-02T12:06:15 [D|app|7d010f2f] Body: {"metrics":{"resources":{"total":4},"time":{"apt_package":0.058870121,"template":0.007326711,"service":1.117910203}},"created_at":"2019-04-02 12:06:14 UTC","updated_at":"2019-04-02 12:06:14 UTC","id":257,"host_id":7,"host_name":"adm-acp-td936.example.com","reported_at":"2019-04-02 12:06:02 UTC","status":{"applied":1,"restarted":1,"failed":0,"failed_restarts":0,"skipped":0,"pending":0},"logs":[{"level":"debug","source":{"source":"apt_package[ntp_package]"},"message":{"message":"[:install]"}},{"level":"debug","source":{"source":"template[/etc/ntp.conf]"},"message":{"message":"create"}},{"level":"notice","source":{"source":"service[ntp]"},"message":{"message":"[:enable, :restart]"}},{"level":"notice","source":{"source":"service[ntp]"},"message":{"message":"[:enable, :restart]"}},{"level":"notice","source":{"source":"Chef"},"message":{"message":"run"}}],"summary":"Modified"}
2019-04-02T12:06:15 [I|app|7d010f2f] Completed 201 Created in 653ms (Views: 11.0ms | ActiveRecord: 37.4ms)
can you please help me out with the configuration? let me know if any other information regarding my environment would help.
