Description:
I encountered an issue while reinstalling the foreman-installer-katello package on my system. The installation process fails during the execution of the %post scriptlet due to the following error:
/usr/share/ruby/open3.rb:221:in `spawn': No such file or directory - facter (Errno::ENOENT)
from /usr/share/ruby/open3.rb:221:in `popen_run'
from /usr/share/ruby/open3.rb:102:in `popen3'
from /usr/share/ruby/open3.rb:289:in `capture3'
from /usr/share/gems/gems/kafo-7.6.0/lib/kafo/base_context.rb:39:in `run_command'
from /usr/share/gems/gems/kafo-7.6.0/lib/kafo/base_context.rb:29:in `facts'
from /usr/share/gems/gems/kafo-7.6.0/lib/kafo/base_context.rb:6:in `facts'
from /etc/foreman-installer/scenarios.d/foreman-proxy-content.migrations/200630000120-disable-pulp-2-el8.rb:1:in `block (2 levels) in load_migrations'
Analysis:
- Root Cause:
- The error indicates that the
facterbinary is missing from the system. - The
%postscriptlet relies onfacterto gather system facts, and its absence causes the script to fail.
- Implications:
- The installation completes with warnings, but essential post-installation configurations are not applied.
- This could lead to misconfigured or incomplete functionality of
foreman-installer-katello.
Steps to Reproduce:
- Run:
dnf reinstall foreman-installer-katello
- Observe the error during the execution of the
%postscriptlet.
Solution:
- Install
facter:
- Verify if
facteris installed:
which facter
- If not, install it using:
dnf install rubygem-facter.noarch
- Reinstall the Package (if needed):
- If the issue persists, consider a clean reinstall:
dnf remove foreman-installer-katello
dnf install foreman-installer-katello
Environment Details:
- Operating System: Red Hat EL 9
- Katello Version: 4.15
- Foreman Installer: 3.13
foreman-installer-katello.log (7.1 KB)
