Hello, I currently encounter an issue with the name resolution via node.rb
(foreman version 1.9)
We currently use the "external_node_v2.rb" in the
/usr/share/foreman-installer as the "/etc/puppet/node.rb' ('I think it's
done by default during the installation of foreman, I'm not sure because it
wasn't me who installed it).
The issue is that the name resolution works manually with
"/etc/puppet/node.rb hostname.example.com", or with the puppet agent
installed on server with a little of facts.
But when the server have a lot of facts information (like an hypervisor
with more than 10K lines), puppetagent give us an: "Error 400 on SERVER:
Failed when searching for node puppetUnix.localdomain: Failed to find
puppetUnix.localdomain via exec: Execution of '/etc/puppet/node.rb
puppetUnix.localdomain' returned 1".
Like you can see, our host is an unix host, so it's not due to the format,
nor a permissions issue (verified on each *.yaml file).
Does anyone has ever had this problem on a server with a lot of facts data?
I'm guessing you are hitting a timeout on your puppet master executing the
node scrip? can you look at foreman logs while this happens? if thats the
case, you can add a timeout settings (that is used at
https://github.com/theforeman/puppet-foreman/blob/master/files/external_node_v2.rb#L44)
Ohad
On Wed, Jun 15, 2016 at 10:14 PM, Dam Olivier wrote:
“Foreman users” group.
Yes you are right, it's a timeout issue.
We already have the timeout set on the script, and when i modify the "10"
(replaced by 20, 30 and 40), We have a "Timeout::Error".
I don't understand why we have this error because two weeks ago it was
working on the hosts.
Le jeudi 16 juin 2016 10:37:01 UTC+2, ohad a écrit :
>> node.rb (foreman version 1.9)
>> format, nor a permissions issue (verified on each *.yaml file).
>> data?
> Ohad
>> "Foreman users" group.
>> Visit this group at https://groups.google.com/group/foreman-users.
