Issue with Subsciption and importing a Manifest
When importing a manifest to Foreman there is a 500 error being thrown from candlepin
“Runtime Error Cannot invoke "java.lang.Boolean.booleanValue()" because "this.managed" is null at org.candlepin.model.Pool.isManaged:1,333”
This seems to cause my Katello instance to not even open the manifest import dialog when i hit the “Import a manifest to begin” button, instead it just reloads the subscription page
The subscription menu loads and importing a manifest is possible
Foreman 3.12
Katello 4.14
Rocky 8.10 - fully updated
2024-10-15T09:48:41 [E|app|209a4ed0] ActionView::Template::Error: Katello::Resources::Candlepin::Pool: 500 Internal Server Error {"displayMessage":"Runtime Error Cannot invoke \"java.lang.Boolean.booleanValue()\" because \"this.managed\" is null at org.candlepin.model.Pool.isManaged:1,333","requestUuid":"7cb78777-fe4d-424c-aead-5ae7ce679fbf"} (GET /candlepin/pools/8ae460a6694876e901694945d6c300a3)
 209a4ed0 | /usr/share/gems/gems/rest-client-2.1.0/lib/restclient/abstract_response.rb:249:in `exception_with_response'
 209a4ed0 | /usr/share/gems/gems/rest-client-2.1.0/lib/restclient/abstract_response.rb:129:in `return!'
 209a4ed0 | /usr/share/gems/gems/rest-client-2.1.0/lib/restclient/request.rb:836:in `process_result'
 209a4ed0 | /usr/share/gems/gems/rest-client-2.1.0/lib/restclient/request.rb:743:in `block in transmit'
 209a4ed0 | /usr/share/ruby/net/http.rb:933:in `start'
 209a4ed0 | /usr/share/gems/gems/rest-client-2.1.0/lib/restclient/request.rb:727:in `transmit'
 209a4ed0 | /usr/share/gems/gems/rest-client-2.1.0/lib/restclient/request.rb:163:in `execute'
 209a4ed0 | /usr/share/gems/gems/rest-client-2.1.0/lib/restclient/request.rb:63:in `execute'
 209a4ed0 | /usr/share/gems/gems/rest-client-2.1.0/lib/restclient/resource.rb:51:in `get'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/lib/katello/http_resource.rb:98:in `issue_request'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/lib/katello/http_resource.rb:49:in `block (2 levels) in singleton class'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/lib/katello/resources/candlepin/pool.rb:21:in `find'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/models/katello/glue/candlepin/pool.rb:31:in `candlepin_data'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/models/katello/glue/candlepin/pool.rb:98:in `import_lazy_attributes'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/models/katello/glue/candlepin/pool.rb:9:in `block (2 levels) in included'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/lib/katello/lazy_accessor.rb:118:in `instance_eval'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/lib/katello/lazy_accessor.rb:118:in `run_initializer'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/lib/katello/lazy_accessor.rb:97:in `lazy_attribute_get'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/lib/katello/lazy_accessor.rb:44:in `block (2 levels) in lazy_accessor'
 209a4ed0 | /usr/share/ruby/delegate.rb:83:in `method_missing'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/helpers.rb:16:in `data_object_attribute'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/builder.rb:145:in `attribute'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/builder.rb:116:in `block in compile_settings'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/builder.rb:115:in `each'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/builder.rb:115:in `compile_settings'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/builder.rb:55:in `block in to_hash'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/builder.rb:253:in `cache_results'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/builder.rb:51:in `to_hash'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/engine.rb:91:in `to_hash'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/engine.rb:51:in `block in render'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/engine.rb:392:in `cache_results'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/engine.rb:50:in `render'
 209a4ed0 | /usr/share/foreman/config/initializers/rabl_init.rb:48:in `render'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/builder.rb:129:in `block in merge_engines_into_result'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/builder.rb:121:in `each'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/builder.rb:121:in `merge_engines_into_result'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/builder.rb:57:in `block in to_hash'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/multi_builder.rb:27:in `map'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/multi_builder.rb:27:in `to_a'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/engine.rb:93:in `to_hash'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/builder.rb:126:in `block (2 levels) in merge_engines_into_result'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/builder.rb:125:in `each'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/builder.rb:125:in `block in merge_engines_into_result'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/engine.rb:104:in `to_dumpable'
 209a4ed0 | /usr/share/gems/gems/rabl-0.16.1/lib/rabl/engine.rb:113:in `to_json'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/views/katello/api/v2/subscriptions/index.json.rabl:3:in `__usr_share_gems_gems_katello________app_views_katello_api_v__subscriptions_index_json_rabl___1962849606638479595_18611540'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/base.rb:247:in `public_send'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/base.rb:247:in `_run'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/template.rb:154:in `block in render'
 209a4ed0 | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/notifications.rb:205:in `instrument'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/template.rb:345:in `instrument_render_template'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/template.rb:152:in `render'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/renderer/template_renderer.rb:61:in `block (2 levels) in render_template'
 209a4ed0 | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/notifications.rb:203:in `block in instrument'
 209a4ed0 | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
 209a4ed0 | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/notifications.rb:203:in `instrument'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/renderer/template_renderer.rb:56:in `block in render_template'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/renderer/template_renderer.rb:71:in `block in render_with_layout'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/renderer/template_renderer.rb:70:in `render_with_layout'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/renderer/template_renderer.rb:55:in `render_template'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/renderer/template_renderer.rb:11:in `render'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/renderer/renderer.rb:61:in `render_template_to_object'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/renderer/renderer.rb:29:in `render_to_object'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/rendering.rb:117:in `block in _render_template'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/base.rb:273:in `in_rendering_context'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/rendering.rb:116:in `_render_template'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/streaming.rb:218:in `_render_template'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/rendering.rb:103:in `render_to_body'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/rendering.rb:52:in `render_to_body'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/renderers.rb:142:in `render_to_body'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/abstract_controller/rendering.rb:25:in `render'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/rendering.rb:36:in `render'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/instrumentation.rb:46:in `block (2 levels) in render'
 209a4ed0 | /usr/share/ruby/benchmark.rb:308:in `realtime'
 209a4ed0 | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/core_ext/benchmark.rb:14:in `ms'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/instrumentation.rb:46:in `block in render'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/instrumentation.rb:86:in `cleanup_view_runtime'
 209a4ed0 | /usr/share/gems/gems/activerecord-6.1.7.8/lib/active_record/railties/controller_runtime.rb:34:in `cleanup_view_runtime'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/instrumentation.rb:45:in `render'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/lib/katello/api/v2/rendering.rb:45:in `respond_with_template'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/lib/katello/api/v2/rendering.rb:63:in `respond_with_template_collection'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/lib/katello/api/v2/rendering.rb:76:in `try_specific_collection_template'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/lib/katello/api/v2/rendering.rb:11:in `respond_for_index'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/controllers/katello/concerns/api/api_controller.rb:81:in `respond'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/controllers/katello/api/v2/subscriptions_controller.rb:66:in `block (2 levels) in index'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/mime_responds.rb:214:in `respond_to'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/controllers/katello/api/v2/subscriptions_controller.rb:40:in `index'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/abstract_controller/base.rb:228:in `process_action'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/rendering.rb:30:in `process_action'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
 209a4ed0 | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/callbacks.rb:117:in `block in run_callbacks'
 209a4ed0 | /usr/share/foreman/app/controllers/concerns/foreman/controller/timezone.rb:10:in `set_timezone'
 209a4ed0 | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/callbacks.rb:126:in `block in run_callbacks'
 209a4ed0 | /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in `clear_thread'
 209a4ed0 | /usr/share/foreman/app/controllers/concerns/foreman/controller/topbar_sweeper.rb:12:in `set_topbar_sweeper_controller'
 209a4ed0 | /usr/share/gems/gems/audited-5.7.0/lib/audited/sweeper.rb:16:in `around'
 209a4ed0 | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/callbacks.rb:137:in `run_callbacks'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/abstract_controller/callbacks.rb:41:in `process_action'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/rescue.rb:22:in `process_action'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/instrumentation.rb:33:in `process_action'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/params_wrapper.rb:249:in `process_action'
 209a4ed0 | /usr/share/gems/gems/activerecord-6.1.7.8/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/app/controllers/katello/concerns/api/api_controller.rb:46:in `process_action'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/abstract_controller/base.rb:165:in `process'
 209a4ed0 | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/rendering.rb:39:in `process'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal.rb:190:in `dispatch'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal.rb:254:in `dispatch'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/routing/route_set.rb:33:in `serve'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/routing/mapper.rb:19:in `block in <class:Constraints>'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/routing/mapper.rb:49:in `serve'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/journey/router.rb:50:in `block in serve'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/journey/router.rb:32:in `each'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/journey/router.rb:32:in `serve'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/routing/route_set.rb:842:in `call'
 209a4ed0 | /usr/share/gems/gems/railties-6.1.7.8/lib/rails/engine.rb:539:in `call'
 209a4ed0 | /usr/share/gems/gems/railties-6.1.7.8/lib/rails/railtie.rb:207:in `public_send'
 209a4ed0 | /usr/share/gems/gems/railties-6.1.7.8/lib/rails/railtie.rb:207:in `method_missing'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/routing/mapper.rb:20:in `block in <class:Constraints>'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/lib/katello/middleware/organization_created_enforcer.rb:18:in `call'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/lib/katello/middleware/event_daemon.rb:10:in `call'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/static.rb:24:in `call'
 209a4ed0 | /usr/share/gems/gems/apipie-dsl-2.6.2/lib/apipie_dsl/static_dispatcher.rb:67:in `call'
 209a4ed0 | /usr/share/gems/gems/apipie-rails-1.4.2/lib/apipie/static_dispatcher.rb:74:in `call'
 209a4ed0 | /usr/share/foreman/lib/foreman/middleware/libvirt_connection_cleaner.rb:9:in `call'
 209a4ed0 | /usr/share/foreman/lib/foreman/middleware/telemetry.rb:10:in `call'
 209a4ed0 | /usr/share/gems/gems/apipie-rails-1.4.2/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
 209a4ed0 | /usr/share/gems/gems/rack-2.2.9/lib/rack/tempfile_reaper.rb:15:in `call'
 209a4ed0 | /usr/share/gems/gems/rack-2.2.9/lib/rack/etag.rb:27:in `call'
 209a4ed0 | /usr/share/gems/gems/rack-2.2.9/lib/rack/conditional_get.rb:27:in `call'
 209a4ed0 | /usr/share/gems/gems/rack-2.2.9/lib/rack/head.rb:12:in `call'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/http/permissions_policy.rb:22:in `call'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/http/content_security_policy.rb:19:in `call'
 209a4ed0 | /usr/share/foreman/lib/foreman/middleware/logging_context_session.rb:22:in `call'
 209a4ed0 | /usr/share/gems/gems/rack-2.2.9/lib/rack/session/abstract/id.rb:266:in `context'
 209a4ed0 | /usr/share/gems/gems/rack-2.2.9/lib/rack/session/abstract/id.rb:260:in `call'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/cookies.rb:697:in `call'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
 209a4ed0 | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/callbacks.rb:98:in `run_callbacks'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
 209a4ed0 | /usr/share/gems/gems/railties-6.1.7.8/lib/rails/rack/logger.rb:37:in `call_app'
 209a4ed0 | /usr/share/gems/gems/railties-6.1.7.8/lib/rails/rack/logger.rb:28:in `call'
 209a4ed0 | /usr/share/gems/gems/sprockets-rails-3.5.2/lib/sprockets/rails/quiet_assets.rb:17:in `call'
 209a4ed0 | /usr/share/foreman/lib/foreman/middleware/logging_context_request.rb:11:in `call'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/request_id.rb:26:in `call'
 209a4ed0 | /usr/share/gems/gems/katello-4.14.0/lib/katello/prevent_json_parsing.rb:12:in `call'
 209a4ed0 | /usr/share/gems/gems/rack-2.2.9/lib/rack/method_override.rb:24:in `call'
 209a4ed0 | /usr/share/gems/gems/rack-2.2.9/lib/rack/runtime.rb:22:in `call'
 209a4ed0 | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/executor.rb:14:in `call'
 209a4ed0 | /usr/share/gems/gems/rack-2.2.9/lib/rack/sendfile.rb:110:in `call'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/ssl.rb:77:in `call'
 209a4ed0 | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/host_authorization.rb:142:in `call'
 209a4ed0 | /usr/share/gems/gems/secure_headers-6.7.0/lib/secure_headers/middleware.rb:11:in `call'
 209a4ed0 | /usr/share/gems/gems/rack-2.2.9/lib/rack/urlmap.rb:74:in `block in call'
 209a4ed0 | /usr/share/gems/gems/rack-2.2.9/lib/rack/urlmap.rb:58:in `each'
 209a4ed0 | /usr/share/gems/gems/rack-2.2.9/lib/rack/urlmap.rb:58:in `call'
 209a4ed0 | /usr/share/gems/gems/puma-6.4.2/lib/puma/configuration.rb:272:in `call'
 209a4ed0 | /usr/share/gems/gems/puma-6.4.2/lib/puma/request.rb:100:in `block in handle_request'
 209a4ed0 | /usr/share/gems/gems/puma-6.4.2/lib/puma/thread_pool.rb:378:in `with_force_shutdown'
 209a4ed0 | /usr/share/gems/gems/puma-6.4.2/lib/puma/request.rb:99:in `handle_request'
 209a4ed0 | /usr/share/gems/gems/puma-6.4.2/lib/puma/server.rb:464:in `process_client'
 209a4ed0 | /usr/share/gems/gems/puma-6.4.2/lib/puma/server.rb:245:in `block in run'
 209a4ed0 | /usr/share/gems/gems/puma-6.4.2/lib/puma/thread_pool.rb:155:in `block in spawn_thread'
 209a4ed0 | /usr/share/gems/gems/logging-2.4.0/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2024-10-15T09:48:41 [I|app|209a4ed0] Completed 500 Internal Server Error in 133ms (Views: 0.2ms | ActiveRecord: 65.6ms | Allocations: 44287)
2024-10-15T09:48:41 [E|app|06d2840b] Katello::HttpErrors::BadRequest: The manifest doesn't exist on console.redhat.com. Please create and import a new manifest.
 06d2840b | /usr/share/gems/gems/katello-4.14.0/app/controllers/katello/api/v2/api_controller.rb:263:in `rescue in check_upstream_connection'
 06d2840b | /usr/share/gems/gems/katello-4.14.0/app/controllers/katello/api/v2/api_controller.rb:260:in `check_upstream_connection'
 06d2840b | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/callbacks.rb:427:in `block in make_lambda'
 06d2840b | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/callbacks.rb:198:in `block (2 levels) in halting'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/abstract_controller/callbacks.rb:34:in `block (2 levels) in <module:Callbacks>'
 06d2840b | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/callbacks.rb:199:in `block in halting'
 06d2840b | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/callbacks.rb:512:in `block in invoke_before'
 06d2840b | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/callbacks.rb:512:in `each'
 06d2840b | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/callbacks.rb:512:in `invoke_before'
 06d2840b | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/callbacks.rb:115:in `block in run_callbacks'
 06d2840b | /usr/share/foreman/app/controllers/concerns/foreman/controller/timezone.rb:10:in `set_timezone'
 06d2840b | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/callbacks.rb:126:in `block in run_callbacks'
 06d2840b | /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in `clear_thread'
 06d2840b | /usr/share/foreman/app/controllers/concerns/foreman/controller/topbar_sweeper.rb:12:in `set_topbar_sweeper_controller'
 06d2840b | /usr/share/gems/gems/audited-5.7.0/lib/audited/sweeper.rb:16:in `around'
 06d2840b | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/callbacks.rb:137:in `run_callbacks'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/abstract_controller/callbacks.rb:41:in `process_action'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/rescue.rb:22:in `process_action'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
 06d2840b | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/notifications.rb:203:in `block in instrument'
 06d2840b | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
 06d2840b | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/notifications.rb:203:in `instrument'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/instrumentation.rb:33:in `process_action'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal/params_wrapper.rb:249:in `process_action'
 06d2840b | /usr/share/gems/gems/activerecord-6.1.7.8/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
 06d2840b | /usr/share/gems/gems/katello-4.14.0/app/controllers/katello/concerns/api/api_controller.rb:46:in `process_action'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/abstract_controller/base.rb:165:in `process'
 06d2840b | /usr/share/gems/gems/actionview-6.1.7.8/lib/action_view/rendering.rb:39:in `process'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal.rb:190:in `dispatch'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_controller/metal.rb:254:in `dispatch'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/routing/route_set.rb:33:in `serve'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/routing/mapper.rb:19:in `block in <class:Constraints>'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/routing/mapper.rb:49:in `serve'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/journey/router.rb:50:in `block in serve'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/journey/router.rb:32:in `each'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/journey/router.rb:32:in `serve'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/routing/route_set.rb:842:in `call'
 06d2840b | /usr/share/gems/gems/railties-6.1.7.8/lib/rails/engine.rb:539:in `call'
 06d2840b | /usr/share/gems/gems/railties-6.1.7.8/lib/rails/railtie.rb:207:in `public_send'
 06d2840b | /usr/share/gems/gems/railties-6.1.7.8/lib/rails/railtie.rb:207:in `method_missing'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/routing/mapper.rb:20:in `block in <class:Constraints>'
 06d2840b | /usr/share/gems/gems/katello-4.14.0/lib/katello/middleware/organization_created_enforcer.rb:18:in `call'
 06d2840b | /usr/share/gems/gems/katello-4.14.0/lib/katello/middleware/event_daemon.rb:10:in `call'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/static.rb:24:in `call'
 06d2840b | /usr/share/gems/gems/apipie-dsl-2.6.2/lib/apipie_dsl/static_dispatcher.rb:67:in `call'
 06d2840b | /usr/share/gems/gems/apipie-rails-1.4.2/lib/apipie/static_dispatcher.rb:74:in `call'
 06d2840b | /usr/share/foreman/lib/foreman/middleware/libvirt_connection_cleaner.rb:9:in `call'
 06d2840b | /usr/share/foreman/lib/foreman/middleware/telemetry.rb:10:in `call'
 06d2840b | /usr/share/gems/gems/apipie-rails-1.4.2/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
 06d2840b | /usr/share/gems/gems/rack-2.2.9/lib/rack/tempfile_reaper.rb:15:in `call'
 06d2840b | /usr/share/gems/gems/rack-2.2.9/lib/rack/etag.rb:27:in `call'
 06d2840b | /usr/share/gems/gems/rack-2.2.9/lib/rack/conditional_get.rb:27:in `call'
 06d2840b | /usr/share/gems/gems/rack-2.2.9/lib/rack/head.rb:12:in `call'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/http/permissions_policy.rb:22:in `call'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/http/content_security_policy.rb:19:in `call'
 06d2840b | /usr/share/foreman/lib/foreman/middleware/logging_context_session.rb:22:in `call'
 06d2840b | /usr/share/gems/gems/rack-2.2.9/lib/rack/session/abstract/id.rb:266:in `context'
 06d2840b | /usr/share/gems/gems/rack-2.2.9/lib/rack/session/abstract/id.rb:260:in `call'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/cookies.rb:697:in `call'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
 06d2840b | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/callbacks.rb:98:in `run_callbacks'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
 06d2840b | /usr/share/gems/gems/railties-6.1.7.8/lib/rails/rack/logger.rb:37:in `call_app'
 06d2840b | /usr/share/gems/gems/railties-6.1.7.8/lib/rails/rack/logger.rb:28:in `call'
 06d2840b | /usr/share/gems/gems/sprockets-rails-3.5.2/lib/sprockets/rails/quiet_assets.rb:17:in `call'
 06d2840b | /usr/share/foreman/lib/foreman/middleware/logging_context_request.rb:11:in `call'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/request_id.rb:26:in `call'
 06d2840b | /usr/share/gems/gems/katello-4.14.0/lib/katello/prevent_json_parsing.rb:12:in `call'
 06d2840b | /usr/share/gems/gems/rack-2.2.9/lib/rack/method_override.rb:24:in `call'
 06d2840b | /usr/share/gems/gems/rack-2.2.9/lib/rack/runtime.rb:22:in `call'
 06d2840b | /usr/share/gems/gems/activesupport-6.1.7.8/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/executor.rb:14:in `call'
 06d2840b | /usr/share/gems/gems/rack-2.2.9/lib/rack/sendfile.rb:110:in `call'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/ssl.rb:77:in `call'
 06d2840b | /usr/share/gems/gems/actionpack-6.1.7.8/lib/action_dispatch/middleware/host_authorization.rb:142:in `call'
 06d2840b | /usr/share/gems/gems/secure_headers-6.7.0/lib/secure_headers/middleware.rb:11:in `call'
 06d2840b | /usr/share/gems/gems/rack-2.2.9/lib/rack/urlmap.rb:74:in `block in call'
 06d2840b | /usr/share/gems/gems/rack-2.2.9/lib/rack/urlmap.rb:58:in `each'
 06d2840b | /usr/share/gems/gems/rack-2.2.9/lib/rack/urlmap.rb:58:in `call'
 06d2840b | /usr/share/gems/gems/puma-6.4.2/lib/puma/configuration.rb:272:in `call'
 06d2840b | /usr/share/gems/gems/puma-6.4.2/lib/puma/request.rb:100:in `block in handle_request'
 06d2840b | /usr/share/gems/gems/puma-6.4.2/lib/puma/thread_pool.rb:378:in `with_force_shutdown'
 06d2840b | /usr/share/gems/gems/puma-6.4.2/lib/puma/request.rb:99:in `handle_request'
 06d2840b | /usr/share/gems/gems/puma-6.4.2/lib/puma/server.rb:464:in `process_client'
 06d2840b | /usr/share/gems/gems/puma-6.4.2/lib/puma/server.rb:245:in `block in run'
 06d2840b | /usr/share/gems/gems/puma-6.4.2/lib/puma/thread_pool.rb:155:in `block in spawn_thread'
 06d2840b | /usr/share/gems/gems/logging-2.4.0/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2024-10-15T09:48:41 [I|app|06d2840b] Completed 400 Bad Request in 594ms (Views: 0.2ms | ActiveRecord: 2.2ms | Allocations: 12178)
Error from candlepin error log
2024-10-15 09:34:17,316 [thread=https-jsse-nio-127.0.0.1-23443-exec-7] [req=67e3b583-d712-415c-9ef8-7cad2453839f, org=isb, csid=f93fd3ca-8018-418b-b3a1-56e07d5c8e72] ERROR org.candlepin.exceptions.mappers.CandlepinExceptionMapper - Runtime Error Cannot invoke "java.lang.Boolean.booleanValue()" because "this.managed" is null at org.candlepin.model.Pool.isManaged:1,333
java.lang.NullPointerException: Cannot invoke "java.lang.Boolean.booleanValue()" because "this.managed" is null
        at org.candlepin.model.Pool.isManaged(Pool.java:1333)
        at org.candlepin.dto.api.v1.PoolTranslator.populate(PoolTranslator.java:109)
        at org.candlepin.dto.api.v1.PoolTranslator.translate(PoolTranslator.java:59)
        at org.candlepin.dto.api.v1.PoolTranslator.translate(PoolTranslator.java:44)
        at org.candlepin.dto.SimpleModelTranslator.translate(SimpleModelTranslator.java:311)
        at org.candlepin.resource.PoolResource.getPool(PoolResource.java:219)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
        at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.base/java.lang.reflect.Method.invoke(Method.java:569)
        at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:170)
        at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:130)
        at org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:660)
        at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:524)
        at org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$2(ResourceMethodInvoker.java:474)
        at org.jboss.resteasy.core.interception.jaxrs.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:364)
        at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:476)
        at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:434)
        at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:408)
        at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:69)
        at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:492)
        at org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:261)
        at org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:161)
        at org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:164)
        at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:247)
        at org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:249)
        at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:60)
        at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:55)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:623)
        at com.google.inject.servlet.ServletDefinition.doServiceImpl(ServletDefinition.java:293)
        at com.google.inject.servlet.ServletDefinition.doService(ServletDefinition.java:283)
        at com.google.inject.servlet.ServletDefinition.service(ServletDefinition.java:184)
        at com.google.inject.servlet.ManagedServletPipeline.service(ManagedServletPipeline.java:89)
        at com.google.inject.servlet.FilterChainInvocation.doFilter(FilterChainInvocation.java:85)
        at org.candlepin.servlet.filter.EventFilter.doFilter(EventFilter.java:65)
        at com.google.inject.servlet.FilterChainInvocation.doFilter(FilterChainInvocation.java:82)
        at org.candlepin.servlet.filter.logging.LoggingFilter.doFilter(LoggingFilter.java:123)
        at org.candlepin.servlet.filter.CandlepinPersistFilter.doFilter(CandlepinPersistFilter.java:48)
        at org.candlepin.servlet.filter.CandlepinScopeFilter.doFilter(CandlepinScopeFilter.java:67)
        at org.candlepin.servlet.filter.CandlepinContentTypeFilter.doFilter(CandlepinContentTypeFilter.java:56)
        at com.google.inject.servlet.ManagedFilterPipeline.dispatch(ManagedFilterPipeline.java:121)
        at com.google.inject.servlet.GuiceFilter.doFilter(GuiceFilter.java:133)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:179)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:154)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:168)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:90)
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:481)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:130)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:93)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:346)
        at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:390)
        at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:63)
        at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:928)
        at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1786)
        at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:52)
        at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
        at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
        at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:63)
        at java.base/java.lang.Thread.run(Thread.java:840)
Hi @birkirf
Was this Katello a fresh install or an upgrade from a previous version? On what version was the manifest originally created?
Can you try the following?
Go to console.redhat.com or the Customer Portal, and export or download the manifest again
Upload the manifest via hammer host subscription upload
cc @Ceiu @nikos_moum who may have more insights
i constantly forget that Hammer exists.
i uploaded through hammer, or tried to at least, it gave me an error - but by some magic the candlepin error is gone and i can see the old manifest in the interface now.
Going to see if i cant properly remove it now and import the new one.
This definitely looks like a bug. What is the exact version of Candlepin?
[root@foreman ~]# rpm -qa | grep candlepin
candlepin-4.4.16-1.el8.noarch
candlepin-selinux-4.4.16-1.el8.noarch
I was trying to delete the manifest yesterday, but the task hangs without ever moving
I’ve created 2319114 – Runtime Error Cannot invoke "java.lang.Boolean.booleanValue()" because "this.managed" is null at org.candlepin.model.Pool.isManaged to track this issue
Here is a “new” error from candlepin that comes up when trying to delete the existing manifest from Foreman.
2024-10-21 09:14:12,400 [thread=Thread-1118 (ActiveMQ-client-global-threads)] [job=8ae4609792a583810192ae5b000b0162, job_key=UndoImportsJob, org=isb, csid=e6b2d68f-b1d7-4e3a-b81a-4531de90d79f] ERROR org.candlepin.async.JobManager - Job "Undo Imports" failed in│
│java.lang.NullPointerException: Cannot invoke "java.lang.Boolean.booleanValue()" because "this.managed" is null        │
│       at org.candlepin.model.Pool.isManaged(Pool.java:1333)        │
│       at org.candlepin.async.tasks.UndoImportsJob.lambda$execute$0(UndoImportsJob.java:117)        │
│       at java.base/java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:178)        │
│       at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1625)        │
│       at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:509)        │
│       at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:499)        │
│       at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:575)        │
│       at java.base/java.util.stream.AbstractPipeline.evaluateToArrayNode(AbstractPipeline.java:260)        │
│       at java.base/java.util.stream.ReferencePipeline.toArray(ReferencePipeline.java:616)        │
│       at java.base/java.util.stream.ReferencePipeline.toArray(ReferencePipeline.java:622)        │
│       at java.base/java.util.stream.ReferencePipeline.toList(ReferencePipeline.java:627)        │
│       at org.candlepin.async.tasks.UndoImportsJob.execute(UndoImportsJob.java:119)        │
│       at com.google.inject.persist.jpa.JpaLocalTxnInterceptor.invoke(JpaLocalTxnInterceptor.java:66)        │
│       at org.candlepin.async.JobManager.executeJob(JobManager.java:1286)        │
│       at org.candlepin.async.JobMessageReceiver$MessageListener.handleMessage(JobMessageReceiver.java:350)        │
│       at org.candlepin.messaging.impl.artemis.ArtemisConsumer$ArtemisMessageForwarder.onMessage(ArtemisConsumer.java:59)        │
│       at org.apache.activemq.artemis.core.client.impl.ClientConsumerImpl.callOnMessage(ClientConsumerImpl.java:971)        │
│       at org.apache.activemq.artemis.core.client.impl.ClientConsumerImpl$Runner.run(ClientConsumerImpl.java:1128)        │
│       at org.apache.activemq.artemis.utils.actors.OrderedExecutor.doTask(OrderedExecutor.java:57)        │
│       at org.apache.activemq.artemis.utils.actors.OrderedExecutor.doTask(OrderedExecutor.java:32)        │
│       at org.apache.activemq.artemis.utils.actors.ProcessorBase.executePendingTasks(ProcessorBase.java:68)        │
│       at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)        │
│       at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)        │
│       at org.apache.activemq.artemis.utils.ActiveMQThreadFactory$1.run(ActiveMQThreadFactory.java:118)
Looks like it is the same error/root cause, but from a different source
Thanks for the very swift response and fix.
I can see the functions have been fixed and merged, do you have any idea how long until the updated/fixed package will be available for katello users?
If this fix/update will take a while to roll out to katello 4.14, is there some way to patch this locally? Manually setting the field somehow or anything really
i’ve now been without RHEL updates for 3-4 weeks (since i broke the manifest) and i need to update a few hosts soon
@nikos_moum Any ETA or side-loadable fix for this update?
I’m getting increased pressure for some rhel related things and am unable to update our rhel hosts at the moment.
If i can’t resolve this before end of next week then i’ll be forced to create a new Org in Foreman to import my new manifest, move all our rhel hosts to that org just so i can get os updates.
A lot of work to workaround this issue that i’d really like to avoid and will very likely bring other issues and will need to be undone when this finally gets fixed, again bringing even more work due to this bug on my end.
Any update at all would be appreciated and thanks again for at least getting the actual bug fixed in the product, even if the fix hasn’t trickled down to me yet.
Hi @birkirf . A Candlepin rpm with the fix already exists, but Katello folks are usually the ones tagging it into the relevant upstream repo. I’ll let them know about getting it added
hi, the candlepin release with the fix should be published now
