Issue with upgrade to Foreman 3.9 & Katello 4.11
Hello everyone I was upgrading my Foreman+Katello instance from version 3.6/4.8 to latest, it was ok until the upgrade from 3.8 to 3.9 which make me struggle. First I had this error :
2024-08-21 16:25:25 [NOTICE] [root] Loading installer configuration. This will take some time.
2024-08-21 16:25:27 [NOTICE] [root] Running installer with log based terminal output at level NOTICE.
2024-08-21 16:25:27 [NOTICE] [root] Use -l to set the terminal output log level to ERROR, WARN, NOTICE, INFO, or DEBUG. See --full-help for definitions.
2024-08-21 16:25:31 [NOTICE] [configure] Starting system configuration.
2024-08-21 16:25:38 [NOTICE] [configure] 250 configuration steps out of 1571 steps complete.
2024-08-21 16:25:39 [NOTICE] [configure] 500 configuration steps out of 1573 steps complete.
2024-08-21 16:25:41 [NOTICE] [configure] 750 configuration steps out of 1576 steps complete.
2024-08-21 16:25:41 [NOTICE] [configure] 1000 configuration steps out of 1582 steps complete.
2024-08-21 16:25:42 [NOTICE] [configure] 1250 configuration steps out of 1582 steps complete.
2024-08-21 16:25:56 [ERROR ] [configure] '/usr/sbin/foreman-rake db:migrate' returned 1 instead of one of [0]
2024-08-21 16:25:56 [ERROR ] [configure] /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]/returns: change from 'notrun' to ['0'] failed: '/usr/sbin/foreman-rake db:migrate' returned 1 instead of one of [0]
2024-08-21 16:26:08 [NOTICE] [configure] 1500 configuration steps out of 1582 steps complete.
2024-08-21 16:26:18 [NOTICE] [configure] System configuration has finished.
Error 1: Puppet Exec resource 'foreman-rake-db:migrate' failed. Logs:
    Adding autorequire relationship with User[foreman]
    Starting to evaluate the resource (1331 of 1582)
    Evaluated in 13.56 seconds
  Exec[foreman-rake-db:migrate](provider=posix)
    Executing check '/usr/sbin/foreman-rake db:abort_if_pending_migrations'
    Executing '/usr/sbin/foreman-rake db:migrate'
  /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]/unless
    rake aborted!
    **Errno::EAFNOSUPPORT: Address family not supported by protocol - socket(2)**
    /usr/share/gems/gems/redis-4.5.1/lib/redis/connection/ruby.rb:21:in `initialize'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/connection/ruby.rb:151:in `new'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/connection/ruby.rb:151:in `connect_addrinfo'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/connection/ruby.rb:193:in `block in connect'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/connection/ruby.rb:191:in `each'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/connection/ruby.rb:191:in `each_with_index'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/connection/ruby.rb:191:in `connect'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/connection/ruby.rb:305:in `connect'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/client.rb:385:in `establish_connection'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/client.rb:117:in `block in connect'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/client.rb:344:in `with_reconnect'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/client.rb:116:in `connect'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/client.rb:417:in `ensure_connected'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/client.rb:269:in `block in process'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/client.rb:356:in `logging'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/client.rb:268:in `process'
    /usr/share/gems/gems/redis-4.5.1/lib/redis/client.rb:162:in `call'
    /usr/share/gems/gems/redis-4.5.1/lib/redis.rb:564:in `block in del'
    /usr/share/gems/gems/redis-4.5.1/lib/redis.rb:72:in `block in synchronize'
    /usr/share/gems/gems/redis-4.5.1/lib/redis.rb:72:in `synchronize'
    /usr/share/gems/gems/redis-4.5.1/lib/redis.rb:563:in `del'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/cache/redis_cache_store.rb:418:in `block (2 levels) in delete_entry'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/cache/redis_cache_store.rb:25:in `with'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/cache/redis_cache_store.rb:418:in `block in delete_entry'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/cache/redis_cache_store.rb:478:in `failsafe'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/cache/redis_cache_store.rb:417:in `delete_entry'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/cache/strategy/local_cache.rb:170:in `delete_entry'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/cache.rb:487:in `block in delete'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/cache.rb:726:in `block in instrument'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/notifications.rb:205:in `instrument'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/cache.rb:726:in `instrument'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/cache.rb:486:in `delete'
    /usr/share/foreman/app/services/topbar_sweeper.rb:18:in `block in expire_cache_all_users'
    /usr/share/foreman/app/services/topbar_sweeper.rb:17:in `each'
    /usr/share/foreman/app/services/topbar_sweeper.rb:17:in `expire_cache_all_users'
    /usr/share/foreman/config/initializers/foreman.rb:35:in `block in <top (required)>'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/callbacks.rb:427:in `instance_exec'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/callbacks.rb:427:in `block in make_lambda'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/callbacks.rb:198:in `block (2 levels) in halting'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/callbacks.rb:604:in `block (2 levels) in default_terminator'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/callbacks.rb:603:in `catch'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/callbacks.rb:603:in `block in default_terminator'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/callbacks.rb:199:in `block in halting'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/callbacks.rb:512:in `block in invoke_before'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/callbacks.rb:512:in `each'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/callbacks.rb:512:in `invoke_before'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/callbacks.rb:105:in `run_callbacks'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/reloader.rb:88:in `prepare!'
    /usr/share/gems/gems/railties-6.1.7.7/lib/rails/application/finisher.rb:124:in `block in <module:Finisher>'
    /usr/share/gems/gems/railties-6.1.7.7/lib/rails/initializable.rb:32:in `instance_exec'
    /usr/share/gems/gems/railties-6.1.7.7/lib/rails/initializable.rb:32:in `run'
    /usr/share/foreman/config/initializers/0_print_time_spent.rb:45:in `block in run'
    /usr/share/foreman/config/initializers/0_print_time_spent.rb:17:in `benchmark'
    /usr/share/foreman/config/initializers/0_print_time_spent.rb:45:in `run'
    /usr/share/gems/gems/railties-6.1.7.7/lib/rails/initializable.rb:61:in `block in run_initializers'
    /usr/share/gems/gems/railties-6.1.7.7/lib/rails/initializable.rb:60:in `run_initializers'
    /usr/share/gems/gems/railties-6.1.7.7/lib/rails/application.rb:391:in `initialize!'
    /usr/share/gems/gems/railties-6.1.7.7/lib/rails/railtie.rb:207:in `public_send'
    /usr/share/gems/gems/railties-6.1.7.7/lib/rails/railtie.rb:207:in `method_missing'
    /usr/share/foreman/config/environment.rb:5:in `<top (required)>'
    /usr/share/gems/gems/polyglot-0.3.5/lib/polyglot.rb:65:in `require'
    /usr/share/gems/gems/zeitwerk-2.6.12/lib/zeitwerk/kernel.rb:38:in `require'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/dependencies.rb:332:in `block in require'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/dependencies.rb:299:in `load_dependency'
    /usr/share/gems/gems/activesupport-6.1.7.7/lib/active_support/dependencies.rb:332:in `require'
    /usr/share/gems/gems/railties-6.1.7.7/lib/rails/application.rb:367:in `require_environment!'
    /usr/share/gems/gems/railties-6.1.7.7/lib/rails/application.rb:533:in `block in run_tasks_blocks'
    /usr/share/gems/gems/rake-13.0.1/exe/rake:27:in `<top (required)>'
    Tasks: TOP => db:abort_if_pending_migrations => db:load_config => environment
    rake aborted!
    Tasks: TOP => db:migrate => db:load_config => environment
1 error was detected during installation.
Which I immediately linked to disabled IPV6 on my server NIC, it seems to be more of a warning than an error, postgresql start correctly even with this error.
If I try to run manually a db:migrate it seems OK :
** Invoke db:migrate (first_time)
** Invoke db:load_config (first_time)
** Execute environment
** Execute db:load_config
** Invoke plugin:refresh_migrations (first_time)
** Execute plugin:refresh_migrations
** Execute db:migrate
** Invoke db:_dump (first_time)
** Execute db:_dump
** Invoke dynflow:migrate (first_time)
** Execute dynflow:migrate
If I try to stop/start foreman services after this, I get this error :
Running Start Services
Check if command is run as root user:                                 [OK]
Start applicable services:
Starting the following service(s):
redis, postgresql, pulpcore-api, pulpcore-content, pulpcore-worker@1.service, pulpcore-worker@2.service, pulpcore-worker@3.service, pulpcore-worker@4.service, tomcat, dynflow-sidekiq@orchestrator, foreman, httpd, dynflow-sidekiq@worker-1, dynflow-sidekiq@worker-hosts-queue-1, foreman-proxy
/ starting httpd
Job for dynflow-sidekiq@orchestrator.service failed because the control process exited with error code.
See "systemctl status dynflow-sidekiq@orchestrator.service" and "journalctl -xe" for details.
Job for foreman.service failed because the control process exited with error code.
See "systemctl status foreman.service" and "journalctl -xe" for details.
- starting dynflow-sidekiq@worker-hosts-queue-1
Job for dynflow-sidekiq@worker-1.service failed because the control process exited with error code.
See "systemctl status dynflow-sidekiq@worker-1.service" and "journalctl -xe" for details.
Job for dynflow-sidekiq@worker-hosts-queue-1.service failed because the control process exited with error code.
See "systemctl status dynflow-sidekiq@worker-hosts-queue-1.service" and "journalctl -xe" for details.
/ All services started                                                [OK]
I saw this error in journalctl :
ERF73-0602 [Foreman::PermissionMissingException]: some permissions were not found: [:view_lookup_values, :create_lookup_values, :edit_lookup_values, :destroy_lookup_values] (Foreman::PermissionMissingException)
And I’m stuck here, I saw another post that was talking about downgrading python jinja2 package which I tried but I don’t get better results with it.
Working upgrade to 3.9/4.11
Foreman 3.8 Katello 4.10
Rocky Linux 8.10
Thank you for your help
according to this other thread that encountered the same problem, enabling IPv6 should be the solution to your initial error: Upgrade to 3.9 failed - foreman-rake db:migrate returned 1 instead of one of [0]
For the other errors, I would assume this is because foreman-installer never went through. Afaik, there are a few additional steps performed afterwards, so enabling IPv6 and then re-running foreman-installer should fix your issue.
I have no idea though why Foreman 3.9 suddenly requires IPv6 to enabled, though.
Oh I didn’t saw this thread, it does solve the first error, thank you :slight_smile: but I still have the missing permission error, I found an RH KB for other missing permissions in Satellite 6.8 upgrade and they fix it by adding them directly in the database :
## Create missing permission ##
# cat <<FIX | foreman-rake console
["view_foreman_rh_cloud", "generate_foreman_rh_cloud"].each do |per|
Permission.find_or_create_by(:name => per)
end
FIX
## Delete duplicate permissions if any ##
if Permission.where(:name => per).count > 1
Permission.where(:name => per).last.destroy
end
end
FIX
Is it OK if I do the same with the permissions I am missing ?
Oh, actually it worked after another retry, weird. It’s seems to be all good, thanks for the help !
