Problem: I am following the guide located at Upgrading and Updating Foreman but running into issues with packages
Expected outcome: Using Leapp, it would resolve the needed packages
Foreman and Proxy versions: 3.3.1
Distribution and version: Centos 7.9
STDERR:
Failed to create directory /var/lib/leapp/el8userspace//sys/fs/selinux: Read-only file system
No matches found for the following disable plugin patterns: subscription-manager
Warning: Package marked by Leapp to install not found in repositories metadata: rubygem-foreman_ansible_core python38-pulp-python rubygem-hammer_cli_katello rubygem-foreman-tasks-core rubygem-katello python38-pulp-certguard postgresql-evr python3-javapackages python38-pulpcore python38-pulp-cli ivy-local python38-pulp-container python38-pulp-ansible rubygem-foreman_remote_execution_core python38-pulp-rpm log4j12 python38-pulp-deb python38-pulp-file
Warning: Package marked by Leapp to upgrade not found in repositories metadata: gpg-pubkey
Transaction check:
Problem 1: package katello-4.5.1-1.el7.noarch requires candlepin >= 2.0, but none of the providers can be installed
- package candlepin-4.1.11-1.el7.noarch requires /usr/bin/python, but none of the providers can be installed
- conflicting requests
Problem 2: package tfm-pulpcore-python3-createrepo_c-0.20.1-1.el7.x86_64 requires createrepo_c-libs = 0.20.1-1.el7, but none of the providers can be installed
- cannot install the best candidate for the job
- createrepo_c-libs-0.20.1-1.el7.x86_64 does not belong to a distupgrade repository
Problem 3: package foreman-3.3.1-1.el8.noarch requires rubygem(facter), but none of the providers can be installed
- package rubygem-foreman_remote_execution-7.2.2-1.fm3_3.el8.noarch requires foreman >= 3.3.1, but none of the providers can be installed
- package rubygem-facter-4.0.51-2.el8.x86_64 requires rubygem(thor) < 2.0, but none of the providers can be installed
- foreman-3.3.1-1.el7.noarch does not belong to a distupgrade repository
END OF ERRORS
I do see in the documentation that I may come across package dependency issues, however should I really remove katello and foreman packages?
