During the upgrade of 1.18.2, following the guide provided on Foreman :: Manual, I had 2 errors :
- SQLite was introduced, but package was not installed
- Syntax error on TRUNCATE during db:sessions:clear
The first issue I solved, but indicates a missing additional command in the upgrade guide.
The second issue was the reason to stop the upgrade to 1.19 and rollback to 1.18.2
A full overview of command given, errors seen can be found in the “Other relevant info”
The upgrade guide should be reviewed and additional things should be added.
Things missing as far as I can see :
- Installation of foreman-sqlite3
- Some magic to get around the message “API controllers newer than Apipie cache! Run apipie:cache rake task to regenerate cache.” (probably an additional foreman-rake command to run…
Started from foreman 1.18.2
The server on my side is running Ubuntu 16.04 and was once installed using the foreman-installer on foreman version 1.15.
Complete overview of steps taken for this upgrade :
- Updated /etc/apt/sources.list.d/foreman.list with new version numbers
- Stop apache2 service
- Run “sudo apt update”
- Run “sudo apt-get --only-upgrade install ruby* foreman*”
During this step a warning was given there is a difference between the installed version of /etc/foreman/database.yml and the version in the package :
— /etc/foreman/database.yml 2018-09-17 08:53:39.645978212 +0200
+++ /etc/foreman/database.yml.dpkg-new 2018-08-31 02:40:09.000000000 +0200
@@ -1,10 +1,22 @@
-### File managed with puppet ###
-## Module: ‘foreman’
+# SQLite version 3.x
+# gem install sqlite3
+development:
- adapter: sqlite3
- database: db/development.sqlite3
- pool: 10
- timeout: 5000
+# Warning: The database defined as “test” will be erased and
+# re-generated from your development database when you run “rake”.
+# Do not set this db to the same as development or production.
+test:
- adapter: sqlite3
- database: db/test.sqlite3
- pool: 10
- timeout: 5000
-# Database is managed by foreman::database::postgresql
production:
- adapter: postgresql
- database: foreman
- username: foreman
- password: “XkNykU934UwtbappwTtjnyDrjUA2TC88”
- pool: 5
- adapter: sqlite3
- database: db/production.sqlite3
- pool: 10
- timeout: 5000
- Run “sudo foreman-rake db:migrate”
At this step, the following error occured :
rake aborted!
Gem::LoadError: Specified ‘sqlite3’ for database adapter, but the gem is not loaded. Addgem 'sqlite3'to your Gemfile (and ensure its version is at the minimum required by ActiveRecord).
/usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/connection_adapters/connection_specification.rb:188:inrescue in spec' /usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/connection_adapters/connection_specification.rb:185:inspec’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/connection_adapters/abstract/connection_pool.rb:880:inestablish_connection' /usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/connection_handling.rb:58:inestablish_connection’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/railtie.rb:124:inblock (2 levels) in <class:Railtie>' /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/lazy_load_hooks.rb:69:ininstance_eval’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/lazy_load_hooks.rb:69:inblock in execute_hook' /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/lazy_load_hooks.rb:60:inwith_execution_control’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/lazy_load_hooks.rb:65:inexecute_hook' /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/lazy_load_hooks.rb:41:inblock in on_load’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/lazy_load_hooks.rb:40:ineach' /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/lazy_load_hooks.rb:40:inon_load’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/railtie.rb:120:inblock in <class:Railtie>' /usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.6/lib/rails/initializable.rb:30:ininstance_exec’
/usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.6/lib/rails/initializable.rb:30:inrun' /usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.6/lib/rails/initializable.rb:59:inblock in run_initializers’
/usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.6/lib/rails/initializable.rb:58:inrun_initializers' /usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.6/lib/rails/application.rb:353:ininitialize!’
/usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.6/lib/rails/railtie.rb:185:inpublic_send' /usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.6/lib/rails/railtie.rb:185:inmethod_missing’
/usr/share/foreman/config/environment.rb:5:in<top (required)>' /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/dependencies.rb:292:inrequire’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/dependencies.rb:292:inblock in require' /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/dependencies.rb:258:inload_dependency’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/dependencies.rb:292:inrequire' /usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.6/lib/rails/application.rb:329:inrequire_environment!’
/usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.6/lib/rails/application.rb:445:in `block in run_tasks_blocks’Caused by:
Gem::LoadError: sqlite3 is not part of the bundle. Add it to Gemfile.
/usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/connection_adapters/sqlite3_adapter.rb:10:in<top (required)>' /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/dependencies.rb:292:inrequire’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/dependencies.rb:292:inrequire' /usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/connection_adapters/connection_specification.rb:186:inspec’
Tasks: TOP => db:migrate => environment
This was solved by taking an additional step, which is not documented in the upgrade guide :
6. sudo apt install foreman-sqlite3
7. Rerun db:migrate
Now the following messages shows up :
This message was ignored for the moment.
8. Running “sudo foreman-rake db:seed”, this showed the same warning on the API controllers, also ignored in this case.
9. Running “sudo foreman-rake tmp:cache:clear”
10. Running “sudo foreman-rake db:sessions:clear”
This resulted in the following error :
rake aborted!
ActiveRecord::StatementInvalid: SQLite3::SQLException: near “TRUNCATE”: syntax error: TRUNCATE TABLE sessions
/usr/share/foreman/vendor/ruby/2.3.0/gems/sqlite3-1.3.13/lib/sqlite3/database.rb:91:ininitialize' /usr/share/foreman/vendor/ruby/2.3.0/gems/sqlite3-1.3.13/lib/sqlite3/database.rb:91:innew’
/usr/share/foreman/vendor/ruby/2.3.0/gems/sqlite3-1.3.13/lib/sqlite3/database.rb:91:inprepare' /usr/share/foreman/vendor/ruby/2.3.0/gems/sqlite3-1.3.13/lib/sqlite3/database.rb:137:inexecute’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/connection_adapters/sqlite3_adapter.rb:251:inblock (2 levels) in execute' /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/dependencies/interlock.rb:46:inblock in permit_concurrent_loads’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/concurrency/share_lock.rb:185:inyield_shares' /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/dependencies/interlock.rb:45:inpermit_concurrent_loads’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/connection_adapters/sqlite3_adapter.rb:250:inblock in execute' /usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/connection_adapters/abstract_adapter.rb:613:inblock (2 levels) in log’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/connection_adapters/abstract_adapter.rb:612:inblock in log' /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/notifications/instrumenter.rb:21:ininstrument’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/connection_adapters/abstract_adapter.rb:604:inlog' /usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/connection_adapters/sqlite3_adapter.rb:249:inexecute’
/usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-session_store-1.1.1/lib/tasks/database.rake:12:in `block (2 levels) in <top (required)>’Caused by:
Tasks: TOP => db:sessions:clear
At this point I decided to rollback the snapshot I created and stop the upgrade…
