For three days (since May 16, 2023 02:34:23 +0200) all my syncs of almalinux repositories fail with errors like
Request timed out for https://repo.almalinux.org/almalinux/8/BaseOS/x86_64/os/repodata/repomd.xml. Increasing the total_timeout value on the remote might help.
The problems seems to be that the https connection on the IPv6 address isn’t working:
# host repo.almalinux.org
repo.almalinux.org has address 67.222.0.50
repo.almalinux.org has IPv6 address 2600:4c00:400::2
# curl -v 'https://repo.almalinux.org/almalinux/8/BaseOS/x86_64/os/repodata/repomd.xml'
* Trying 2600:4c00:400::2...
* TCP_NODELAY set
* Trying 67.222.0.50...
* TCP_NODELAY set
* Connected to repo.almalinux.org (67.222.0.50) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
# curl -6 -v 'https://repo.almalinux.org/almalinux/8/BaseOS/x86_64/os/repodata/repomd.xml'
* TCP_NODELAY set
* connect to 2600:4c00:400::2 port 443 failed: Connection timed out
* Failed to connect to repo.almalinux.org port 443: Connection timed out
* Closing connection 0
curl: (7) Failed to connect to repo.almalinux.org port 443: Connection timed out
Now while curl switches to IPv4 quickly, it seems pulp-rpm doesn’t, but sticks with IPv6 until it times out.
foreman-3.5.3-1.el8.noarch
katello-4.7.5-1.el8.noarch
