All jobs that talk to Koji to perform an RPM build appear to be currently
failing with the following:
16:47:04 Command output: Kerberos authentication failed: No
credentials cache found (-1765328189)
Fixed by 5b73303 in foreman-infra.
Dominic Cleal
dominic@cleal.org
Thanks!
currently failing with the following:16:47:04 Command output: Kerberos authentication failed: No
credentials cache found (-1765328189)Fixed by 5b73303 in foreman-infra.
Dominic Cleal
dominic@cleal.org–
“foreman-dev” group.
Eric D. Helms
Red Hat Engineering
Ph.D. Student - North Carolina State University
