I been running into problem for the last week.
I have install the new Katello 2.1.
And in two or my katello installation both install have the same problem.
I has to with after creating the Product Centos Server Linux.
The process never completes.
Add new repo it just sitting there waiting.
Below is the set that has been waiting.
4cup
12 GB ram
500GB storage.
I have create a foreman-debug for you to see.
foreman-debug-gTdPL.tar.xz
I am having the same problem in my new AWS installation Katello doing the
same thing.
Thanks
Al Johnson
{"pulp_tasks"=>
[{"exception"=>nil,
"task_type"=>"pulp.server.managers.repo.publish.publish",
"_href"=>"/pulp/api/v2/tasks/2bc0fd08-37e2-4848-bdd2-661df86843d4/",
"task_id"=>"2bc0fd08-37e2-4848-bdd2-661df86843d4",
"tags"=>
["pulp:repository:AIRCELL_PROD-Centos_Server_Linux-centos66_os_x86_64",
"pulp:action:publish"],
"finish_time"=>nil,
"start_time"=>nil,
"traceback"=>nil,
"spawned_tasks"=>[],
"progress_report"=>{},
"queue"=>"reserved_resource_worker-3@til-vm-swk6-11.aircell.prod.dq",
"state"=>"waiting",
"result"=>nil,
"error"=>nil,
"_id"=>{"$oid"=>"54e396e0ee55e9d6f4ba0d3c"},
"id"=>"54e396e0e4fd8505f8aa665d"}],
"poll_attempts"=>{"total"=>739, "failed"=>0}}
