[Katello 2.2.1] Pulp repository access over https not possible
Hi together,
I´m new to Katello and Foreman and am trying to access pulp repo content from one of my subscribed consumer hosts. But neither is it possible to access the content through the url in my web browser nor through yum.
I think there is an ssl issue and I currently can't pinpoint it. Can somebody maybe help me on this matter? The content is available through http but our security policy prohibits access to http content.
Kind regards,
Markus
Hi Markus,
The only way to see the repositories through a web browser that are served
over HTTPS is via a debug certificate that you can download for a given
organization on the organization page. Can you describe your setup and what
you are seeing on the client? Are there error messages? Does yum repolist
show the HTTPS based repositories?
Eric
··· On Tue, Jul 7, 2015 at 7:58 AM, wrote:
Hi together,
I think there is an ssl issue and I currently can’t pinpoint it. Can
Kind regards,
Markus
“Foreman users” group.
Eric D. Helms
Red Hat Engineering
Ph.D. Student - North Carolina State University
> Hi together,
What makes you think it's an SSL issue? Could we see what's logged when
you try to access the content through the url in your web browser or yum?
I'd recommend 'tail -f'-ing Pulp logs when you try to access this
content and see if the Pulp capsule is being reached at all.
··· On 07/07, Markus.Moj@mc.ingenico.com wrote: > > Kind regards, > Markus > > -- > You received this message because you are subscribed to the Google Groups "Foreman users" group. > To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.com. > To post to this group, send email to foreman-users@googlegroups.com. > Visit this group at http://groups.google.com/group/foreman-users. > For more options, visit https://groups.google.com/d/optout.
Daniel Lobato Garcia
@eLobatoss
blog.daniellobato.me
daniellobato.me
Keybase: https://keybase.io/elobato
Hi Eric,
Thanks for your reply. Here is a short description of our setup.
I´ve installed katello with necessary dependencies, configured the http proxy and setup an organizational SSL certificate for the webserver. I´ve also disabled SSLv2 v3 as well as TLSv1 and TLSv1.1.
I have created a repo for centos 7.1 and synced it without any issues. Furthermore I have created a composite content view for centos 7, which will in the future hold more repos, and published this content view. I have also registered a host to test if every things configured correctly and here the problems begin. I´ve install katello-agent registered with puppet and see the host as content host in foreman, I´ve also installed the consumer-ca but when I try to update the system I get the following error.
yum check-update
Loaded plugins: fastestmirror, package_upload, product-id, subscription-manager
https://vvvvvvvvvvvvv/pulp/repos/vvvvvv/Library/CentOS-7/custom/repo-centos-7_1-server/7_1_1503_centosplus_x86_64/repodata/repomd.xml: [Errno 14] curl#35 - "TCP connection reset by peer"
Cheers,
Markus
··· Von: foreman-users@googlegroups.com [mailto:foreman-users@googlegroups.com] Im Auftrag von Eric D Helms Gesendet: Dienstag, 7. Juli 2015 14:22 An: foreman-users@googlegroups.com Betreff: Re: [foreman-users] [Katello 2.2.1] Pulp repository access over https not possible
Hi Markus,
The only way to see the repositories through a web browser that are served over HTTPS is via a debug certificate that you can download for a given organization on the organization page. Can you describe your setup and what you are seeing on the client? Are there error messages? Does yum repolist show the HTTPS based repositories?
Eric
On Tue, Jul 7, 2015 at 7:58 AM, <Markus.Moj@mc.ingenico.commailto:Markus.Moj@mc.ingenico.com> wrote:
Hi together,
I think there is an ssl issue and I currently can’t pinpoint it. Can somebody maybe help me on this matter? The content is available through http but our security policy prohibits access to http content.
Kind regards,
Markus
To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.commailto:foreman-users+unsubscribe@googlegroups.com.
To post to this group, send email to foreman-users@googlegroups.commailto:foreman-users@googlegroups.com.
Eric D. Helms
Red Hat Engineering
Hi Daniel,
I don´t see a connect not even a try. But when I lookup curl#35 this is what I get.
CURLE_SSL_CONNECT_ERROR (35)
A problem occurred somewhere in the SSL/TLS handshake. You really want the error buffer and read the message there as it pinpoints the problem slightly more. Could be certificates (file formats, paths, permissions), passwords, and others.
Therefore I wrote that I looks to me like an SSL error.
··· -----Ursprüngliche Nachricht----- Von: foreman-users@googlegroups.com [mailto:foreman-users@googlegroups.com] Im Auftrag von Daniel Lobato Garcia Gesendet: Dienstag, 7. Juli 2015 14:55 An: foreman-users@googlegroups.com Betreff: Re: [foreman-users] [Katello 2.2.1] Pulp repository access over https not possible
Hi together,
What makes you think it’s an SSL issue? Could we see what’s logged when you try to access the content through the url in your web browser or yum?
I’d recommend ‘tail -f’-ing Pulp logs when you try to access this content and see if the Pulp capsule is being reached at all.
Kind regards,
Markus
@eLobatoss
Keybase: elobato (Daniel Lobato Garcia) | Keybase
Do you see errors in the Apache logs on the server from where it is trying
to connect?
··· On Tue, Jul 7, 2015 at 9:09 AM, wrote:
Hi Daniel,
what I get.
https not possible
Hi together,
Kind regards,
Markus
@eLobatoss
daniellobato.me
Eric D. Helms
Red Hat Engineering
Hi Eric,
sorry but I dont see any log entries neither in httpd logs nor in other logs.
The only thing I get now is the following error message with yum
[Errno 14] curl#35 - "Encountered end of file"
And in /var/log/messages I see this entry
[WARNING][Thread-2] qpid.messaging:462 - recoverable error[attempt 580]: [Errno 1] _ssl.c:504: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
i.A Markus MOJ
IT-Operations /
System-Administrator HP NonStop Servers - Tandem Computers /
Linux Engenieer /
Ingenico Payment Services GmbH
Am Gierath 20, 40885 Ratingen - Germany
(T) +49 2102 973 546 / (F) +49 2102 973 176
Markus.Moj@ingenico.com<mailto:Markus.Moj@ingenico.com>
www.payment-services.ingenico.com<http://www.payment-services.ingenico.com/&gt;
[cid:image001.png@01CF7A87.8F5B4250]
··· Von: foreman-users@googlegroups.com [mailto:foreman-users@googlegroups.com] Im Auftrag von Eric D Helms Gesendet: Dienstag, 7. Juli 2015 15:54 An: foreman-users@googlegroups.com Betreff: Re: [foreman-users] [Katello 2.2.1] Pulp repository access over https not possible
Do you see errors in the Apache logs on the server from where it is trying to connect?
On Tue, Jul 7, 2015 at 9:09 AM, <Markus.Moj@mc.ingenico.commailto:Markus.Moj@mc.ingenico.com> wrote:
Hi Daniel,
Von: foreman-users@googlegroups.commailto:foreman-users@googlegroups.com [mailto:foreman-users@googlegroups.commailto:foreman-users@googlegroups.com] Im Auftrag von Daniel Lobato Garcia
An: foreman-users@googlegroups.commailto:foreman-users@googlegroups.com
On 07/07, Markus.Moj@mc.ingenico.commailto:Markus.Moj@mc.ingenico.com wrote:
Hi together,
Kind regards,
Markus
To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.commailto:foreman-users%2Bunsubscribe@googlegroups.com.
@eLobatoss
blog.daniellobato.mehttp://blog.daniellobato.me
daniellobato.mehttp://daniellobato.me
Eric D. Helms
Red Hat Engineering
I also see the following in the rhsm logs
2015-07-08 08:18:08,066 [DEBUG] yum @connection.py:469 - Making request: GET /rhsm/consumers/fde488f5-fd73-47a9-85b0-08adc3297c06/content_overrides
2015-07-08 08:18:08,191 [DEBUG] yum @connection.py:492 - Response: status=200
2015-07-08 08:18:08,193 [DEBUG] yum @cache.py:272 - Started thread to write cache: /var/lib/rhsm/cache/content_overrides.json
2015-07-08 08:18:08,199 [DEBUG] yum @init.py:85 - Searching for content of type: yum
2015-07-08 08:18:08,221 [DEBUG] yum @cache.py:110 - Wrote cache: /var/lib/rhsm/cache/written_overrides.json
2015-07-08 08:18:08,222 [INFO] yum @repolib.py:270 - repos updated: Repo updates
Total repo updates: 8
Updated
[id: repo-centos-7_1-server_7_1_1503_os_x86_64 7.1.1503 os x86_64]
[id: repo-centos-7_1-server_7_1_1503_updates_x86_64 7.1.1503 updates x86_64]
[id: repo-centos-7_1-server_7_1_1503_extras_x86_64 7.1.1503 extras x86_64]
[id: repo-centos-7_1-server_7_1_1503_virt_x86_64_xen 7.1.1503 virt x86_64 xen]
[id: repo-centos-7_1-server_7_1_1503_cr_x86_64 7.1.1503 cr x86_64]
[id: repo-centos-7_1-server_7_1_1503_fasttrack_x86_64 7.1.1503 fasttrack x86_64]
[id: repo-centos-7_1-server_7_1_1503_centosplus_x86_64 7.1.1503 centosplus x86_64]
[id: repo-centos-7_1-server_7_1_1503_cloud_x86_64_openstack-kilo 7.1.1503 cloud x86_64 openstack-kilo]
Added (new)
<NONE>
Deleted
<NONE>
Cheers,
Markus
Hi Daniel,
Hi together,
Kind regards,
Markus
@eLobatoss
Eric D. Helms
Red Hat Engineering
I´ve tried to access the repo with curl and receive the following error.
curl -Iv https://vvvvvvvvvvvvvv/pulp/repos/vvvv/Library/repo-view-centos-7_1/custom/repo-centos-7_1-server/7_1_1503_centosplus_x86_64/repodata/repomd.xml
  • About to connect() to vvvvvvvvvvv port 443 (#0)
  • Trying xxx.xxx.xxx.xxx…
  • Connected to vvvvvvvvv (xxx.xxx.xxx.xxx) port 443 (#0)
  • Initializing NSS with certpath: sql:/etc/pki/nssdb
  • CAfile: /etc/pki/tls/certs/ca-bundle.crt
    CApath: none
  • NSS error -5938 (PR_END_OF_FILE_ERROR)
  • Encountered end of file
  • Closing connection 0
    curl: (35) Encountered end of file
··· Von: foreman-users@googlegroups.com [mailto:foreman-users@googlegroups.com] Im Auftrag von Moj, Markus Gesendet: Mittwoch, 8. Juli 2015 08:23 An: foreman-users@googlegroups.com Betreff: AW: [foreman-users] [Katello 2.2.1] Pulp repository access over https not possible
Updated
Added (new)
Deleted
Cheers,
Markus
Von: foreman-users@googlegroups.commailto:foreman-users@googlegroups.com [mailto:foreman-users@googlegroups.com] Im Auftrag von Eric D Helms
Hi Daniel,
Hi together,
Kind regards,
Markus
@eLobatoss
Eric D. Helms
Red Hat Engineering
Are you using custom server certificates?
curl -Iv
CApath: none
foreman-users@googlegroups.com] *Im Auftrag von *Moj, Markus
status=200
updates
Updated
x86_64]
x86_64]
x86_64 xen]
fasttrack x86_64]
centosplus x86_64]
Added (new)
<NONE>
Deleted
<NONE>
Cheers,
Markus
mailto:foreman-users@googlegroups.com foreman-users@googlegroups.com] *Im
Auftrag von *Eric D Helms
to connect?
On Tue, Jul 7, 2015 at 9:09 AM, Markus.Moj@mc.ingenico.com wrote:
Hi Daniel,
what I get.
https not possible
Hi together,
Kind regards,
Markus
@eLobatoss
daniellobato.me
Eric D. Helms
Red Hat Engineering
Hi Eric,
yes I have set custom server certificates with katello-installer but I can revise it to standard if necessary.
··· Von: foreman-users@googlegroups.com [mailto:foreman-users@googlegroups.com] Im Auftrag von Eric D Helms Gesendet: Mittwoch, 8. Juli 2015 13:24 An: foreman-users@googlegroups.com Betreff: Re: AW: [foreman-users] [Katello 2.2.1] Pulp repository access over https not possible
CApath: none
Updated
Added (new)
<NONE>
Deleted
<NONE>
Cheers,
Markus
Hi Daniel,
Hi together,
Kind regards,
Markus
To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.com mailto:foreman-users%2Bunsubscribe@googlegroups.com .
@eLobatoss
Eric D. Helms
Red Hat Engineering
Hi Eric,
I have disabled all necessary repos as well as the proxy and run katello-install --certs-update-all. After this I was able to contact my repo and receive updates and packages.
Thanks you all for your help.
··· Von: foreman-users@googlegroups.com [mailto:foreman-users@googlegroups.com] Im Auftrag von Moj, Markus Gesendet: Mittwoch, 8. Juli 2015 13:54 An: foreman-users@googlegroups.com Betreff: AW: AW: [foreman-users] [Katello 2.2.1] Pulp repository access over https not possible
  • PGP Bad Signature, Signed: 08.07.2015 at 13:54:18
Hi Eric,
CApath: none
Updated
Added (new)
<NONE>
Deleted
<NONE>
Cheers,
Markus
Hi Daniel,
Hi together,
Kind regards,
Markus
@eLobatoss
Eric D. Helms
Red Hat Engineering
