I make a fresh install to get the new foreman 1.8.2 but when i create the
Activation key and i want to force into the product content the repos the
only i get is the loading message and is in a loop nothing happen.
Looking into the production log is looks like ok is connected to the
database and suppose is give the result but nothing happen in the gui
2015-07-08 05:02:23 [D] Cache read: https://172.25.176.121/katello/api/v2/activation_keys/1/products?enabled=true&full_result=true&include_available_content=true&organization_id=1
2015-07-08 05:02:23 [I] Processing by
Katello::Api::V2::ProductsController#index as JSON
2015-07-08 05:02:23 [I] Parameters: {"enabled"=>"true",
"full_result"=>"true", "include_available_content"=>"true",
"organization_id"=>"1", "api_version"=>"v2", "activation_key_id"=>"1"}
2015-07-08 05:02:23 [D] User Load (0.3ms) SELECT "users".* FROM "users"
WHERE "users"."id" = $1 LIMIT 1 [["id", 3]]
2015-07-08 05:02:23 [D] Setting current user thread-local variable to Admin
User
2015-07-08 05:02:23 [D] Cache read: idle_timeout
2015-07-08 05:02:23 [D] Katello::ActivationKey Load (0.4ms) SELECT
"katello_activation_keys".* FROM "katello_activation_keys" WHERE
"katello_activation_keys"."id" = 1 LIMIT 1
2015-07-08 05:02:23 [D] Organization Load (0.3ms) SELECT "taxonomies".*
FROM "taxonomies" WHERE "taxonomies"."type" IN ('Organization') AND
"taxonomies"."id" = 1 ORDER BY title LIMIT 1
2015-07-08 05:02:23 [D] CACHE (0.0ms) SELECT "taxonomies".* FROM
2015-07-08 05:02:23 [D] (0.2ms) SELECT id FROM "katello_products" WHERE
"katello_products"."organization_id" = 1
2015-07-08 05:02:23 [D] Katello::MarketingProduct Load (0.3ms) SELECT
"katello_products".* FROM "katello_products" WHERE
"katello_products"."type" IN ('Katello::MarketingProduct') AND
"katello_products"."cp_id" IN ('1436273363624', '1436273648779',
'1436273768622')
2015-07-08 05:02:23 [D] Katello::Product Load (0.2ms) SELECT
'1436273768622') AND (type != 'Katello::MarketingProduct')
2015-07-08 05:02:23 [D] Katello::Product Load (0.5ms) SELECT
"katello_products".* FROM "katello_products" WHERE "katello_products"."id"
IN (1, 2, 3) ORDER BY id = 1 DESC, id = 2 DESC, id = 3 DESC
2015-07-08 05:02:23 [D] Katello::Provider Load (0.2ms) SELECT
"katello_providers".* FROM "katello_providers" WHERE
"katello_providers"."id" IN (1)
2015-07-08 05:02:23 [D] Katello::KTEnvironment Load (0.4ms) SELECT
"katello_environments".* FROM "katello_environments" WHERE
"katello_environments"."organization_id" = 1 AND
"katello_environments"."library" = 't' LIMIT 1
2015-07-08 05:02:23 [D] Katello::ContentView Load (0.3ms) SELECT
"katello_content_views".* FROM "katello_content_views" WHERE
"katello_content_views"."default" = 't' AND
"katello_content_views"."organization_id" = 1 LIMIT 1
2015-07-08 05:02:23 [D] CACHE (0.0ms) SELECT "katello_content_views".*
FROM "katello_content_views" WHERE "katello_content_views"."default" = 't'
AND "katello_content_views"."organization_id" = 1 LIMIT 1
2015-07-08 05:02:23 [D] Katello::ContentViewVersion Load (0.4ms) SELECT
"katello_content_view_versions".* FROM "katello_content_view_versions"
INNER JOIN "katello_content_view_environments" ON
"katello_content_view_environments"."content_view_version_id" =
"katello_content_view_versions"."id" WHERE
"katello_content_view_versions"."content_view_id" = 1 AND
"katello_content_view_environments"."environment_id" = 1 ORDER BY
katello_content_view_environments.environment_id DESC,
katello_content_view_versions.id DESC LIMIT 1
2015-07-08 05:02:23 [D] Katello::ContentView Load (0.2ms) SELECT
"katello_content_views"."id" = 1 LIMIT 1
2015-07-08 05:02:23 [D] Katello::Repository Load (0.4ms) SELECT
"katello_repositories".* FROM "katello_repositories" WHERE
"katello_repositories"."content_view_version_id" = 1 AND
"katello_repositories"."environment_id" = 1 AND
"katello_repositories"."product_id" = 1 AND (url IS NOT NULL) ORDER BY
katello_repositories.name ASC
2015-07-08 05:02:23 [D] Katello::PulpSyncStatus Load (0.4ms) SELECT
"katello_task_statuses".* FROM "katello_task_statuses" WHERE
"katello_task_statuses"."type" IN ('Katello::PulpSyncStatus') AND
"katello_task_statuses"."uuid" = '559bcba8433d3414df4a9169' LIMIT 1
2015-07-08 05:02:23 [D] Katello::PulpSyncStatus Load (0.5ms) SELECT
"katello_task_statuses"."uuid" = '559bcba8433d3414df4a9172' LIMIT 1
FROM "katello_content_views" WHERE "katello_content_views"."id" = 1 LIMIT 1
2015-07-08 05:02:23 [D] Katello::Repository Load (0.5ms) SELECT
"katello_repositories"."product_id" = 1 ORDER BY katello_repositories.name
ASC
2015-07-08 05:02:23 [D] ForemanTasks::Task::DynflowTask Load (0.6ms)
SELECT "foreman_tasks_tasks".* FROM "foreman_tasks_tasks" INNER JOIN
"foreman_tasks_locks" ON "foreman_tasks_locks"."task_id" =
"foreman_tasks_tasks"."id" WHERE "foreman_tasks_tasks"."type" IN
('ForemanTasks::Task::DynflowTask') AND "foreman_tasks_tasks"."label" =
'Actions::Katello::Repository::Sync' AND
"foreman_tasks_locks"."resource_id" = 1 AND
"foreman_tasks_locks"."resource_type" = 'Katello::Repository' ORDER BY
started_at DESC LIMIT 1
"foreman_tasks_locks"."resource_id" = 2 AND
2015-07-08 05:02:23 [D] CACHE (0.0ms) SELECT "foreman_tasks_tasks".*
FROM "foreman_tasks_tasks" INNER JOIN "foreman_tasks_locks" ON
"foreman_tasks_locks"."task_id" = "foreman_tasks_tasks"."id" WHERE
"foreman_tasks_tasks"."type" IN ('ForemanTasks::Task::DynflowTask') AND
"foreman_tasks_tasks"."label" = 'Actions::Katello::Repository::Sync' AND
2015-07-08 05:02:23 [D] (0.7ms) SELECT COUNT() FROM
"katello_repositories" INNER JOIN "katello_content_view_versions" ON
"katello_content_view_versions"."id" =
"katello_repositories"."content_view_version_id" INNER JOIN
"katello_content_views" ON "katello_content_views"."id" =
"katello_content_view_versions"."content_view_id" WHERE
"katello_repositories"."product_id" = 2 AND (url IS NOT NULL) ORDER BY
"katello_repositories"."product_id" = 2 ORDER BY katello_repositories.name
ASC
2015-07-08 05:02:23 [D] ForemanTasks::Task::DynflowTask Load (0.4ms)
"foreman_tasks_locks"."resource_id" = 3 AND
Can you check the browsers web console for errors when you access that tab?
We had a previously reported error that was fixed for 2.2.2. What version
of ruby193-rubygem-katello are you running?
On Jul 8, 2015 1:05 AM, "Mario Gamboa" wrote:
this what happen when click product contents
2015-07-08 05:02:23 [I] Parameters: {“enabled”=>“true”,
“full_result”=>“true”, “include_available_content”=>“true”,
“organization_id”=>“1”, “api_version”=>“v2”, “activation_key_id”=>“1”}
2015-07-08 05:02:23 [D] User Load (0.3ms) SELECT “users”.* FROM “users"
WHERE “users”.“id” = $1 LIMIT 1 [[“id”, 3]]
Admin User
"katello_activation_keys”.* FROM “katello_activation_keys” WHERE
"katello_activation_keys".“id” = 1 LIMIT 1
2015-07-08 05:02:23 [D] Organization Load (0.3ms) SELECT “taxonomies”.*
FROM “taxonomies” WHERE “taxonomies”.“type” IN (‘Organization’) AND
"taxonomies".“id” = 1 ORDER BY title LIMIT 1
2015-07-08 05:02:23 [D] CACHE (0.0ms) SELECT “taxonomies”.* FROM
"taxonomies" WHERE “taxonomies”.“type” IN (‘Organization’) AND
2015-07-08 05:02:23 [D] (0.2ms) SELECT id FROM “katello_products"
WHERE “katello_products”.“organization_id” = 1
"katello_products”.* FROM “katello_products” WHERE
"katello_products".“type” IN (‘Katello::MarketingProduct’) AND
"katello_products".“cp_id” IN (‘1436273363624’, ‘1436273648779’,
‘1436273768622’)
"katello_products".* FROM “katello_products” WHERE
‘1436273768622’) AND (type != ‘Katello::MarketingProduct’)
"katello_products".* FROM “katello_products” WHERE “katello_products”.“id"
"katello_providers”.* FROM “katello_providers” WHERE
"katello_providers".“id” IN (1)
"katello_environments".* FROM “katello_environments” WHERE
"katello_environments".“organization_id” = 1 AND
"katello_environments".“library” = ‘t’ LIMIT 1
"katello_content_views".* FROM “katello_content_views” WHERE
"katello_content_views".“default” = ‘t’ AND
"katello_content_views".“organization_id” = 1 LIMIT 1
2015-07-08 05:02:23 [D] CACHE (0.0ms) SELECT “katello_content_views”.*
FROM “katello_content_views” WHERE “katello_content_views”.“default” = 't’
AND “katello_content_views”.“organization_id” = 1 LIMIT 1
"katello_content_view_versions".* FROM “katello_content_view_versions"
INNER JOIN “katello_content_view_environments” ON
"katello_content_view_environments”.“content_view_version_id” =
“katello_content_view_versions”.“id” WHERE
"katello_content_view_versions".“content_view_id” = 1 AND
"katello_content_view_environments".“environment_id” = 1 ORDER BY
"katello_content_views".“id” = 1 LIMIT 1
"katello_repositories".* FROM “katello_repositories” WHERE
"katello_repositories".“content_view_version_id” = 1 AND
"katello_repositories".“environment_id” = 1 AND
"katello_repositories".“product_id” = 1 AND (url IS NOT NULL) ORDER BY
"katello_task_statuses".* FROM “katello_task_statuses” WHERE
"katello_task_statuses".“type” IN (‘Katello::PulpSyncStatus’) AND
"katello_task_statuses".“uuid” = ‘559bcba8433d3414df4a9169’ LIMIT 1
"katello_task_statuses".“uuid” = ‘559bcba8433d3414df4a9172’ LIMIT 1
FROM “katello_content_views” WHERE “katello_content_views”.“id” = 1 LIMIT 1
"katello_repositories".“product_id” = 1 ORDER BY katello_repositories.name
ASC
SELECT “foreman_tasks_tasks”.* FROM “foreman_tasks_tasks” INNER JOIN
"foreman_tasks_locks" ON “foreman_tasks_locks”.“task_id” =
“foreman_tasks_tasks”.“id” WHERE “foreman_tasks_tasks”.“type” IN
(‘ForemanTasks::Task::DynflowTask’) AND “foreman_tasks_tasks”.“label” =
‘Actions::Katello::Repository::Sync’ AND
"foreman_tasks_locks".“resource_id” = 1 AND
"foreman_tasks_locks".“resource_type” = ‘Katello::Repository’ ORDER BY
"foreman_tasks_locks".“resource_id” = 2 AND
2015-07-08 05:02:23 [D] CACHE (0.0ms) SELECT “foreman_tasks_tasks”.*
FROM “foreman_tasks_tasks” INNER JOIN “foreman_tasks_locks” ON
"foreman_tasks_locks".“task_id” = “foreman_tasks_tasks”.“id” WHERE
"foreman_tasks_tasks".“type” IN (‘ForemanTasks::Task::DynflowTask’) AND
"foreman_tasks_tasks".“label” = ‘Actions::Katello::Repository::Sync’ AND
"katello_repositories" INNER JOIN “katello_content_view_versions” ON
"katello_content_view_versions".“id” =
“katello_repositories”.“content_view_version_id” INNER JOIN
"katello_content_views" ON “katello_content_views”.“id” =
“katello_content_view_versions”.“content_view_id” WHERE
"katello_content_views".“default” = 't’
I looking already in the bug gabriel and i already have patch the version
is 2.2.2 but i still now i create a new machine now with centos 7 instead
of centos 6 but when i try to looking again into the activation key the
product content still same issue is only just show loading and in the web
console i get this
This site makes use of a SHA-1 Certificate; it's recommended you use
certificates with signature algorithms that use hash functions stronger
than SHA-1.[Learn More] products
Empty string passed to getElementById().
application-6ce5ef9cee5ab43827e0aff41052e468.js:16:0
