Katello 2.3 on CentOS7 :
When I try to setup LDAPS, it allows me to configure the ldaps connection,
and shows a checkmark and says it was successfully configured.
Then when I try to create a group using the User Groups Administration
option, and try to link it to an external group, Foreman crashes with the
following error :
Errno::ECONNRESET
Connection reset by peer - SSL_connect
/opt/rh/ruby193/root/usr/share/gems/gems/net-ldap-0.11/lib/net/ldap/connection.rb:54:in
connect' /opt/rh/ruby193/root/usr/share/gems/gems/net-ldap-0.11/lib/net/ldap/connection.rb:54:in
wrap_with_ssl'
/opt/rh/ruby193/root/usr/share/gems/gems/net-ldap-0.11/lib/net/ldap/connection.rb:95:in
setup_encryption' /opt/rh/ruby193/root/usr/share/gems/gems/net-ldap-0.11/lib/net/ldap/connection.rb:25:in
initialize'
/opt/rh/ruby193/root/usr/share/gems/gems/net-ldap-0.11/lib/net/ldap.rb:1223:in
new' /opt/rh/ruby193/root/usr/share/gems/gems/net-ldap-0.11/lib/net/ldap.rb:1223:in
new_connection'
/opt/rh/ruby193/root/usr/share/gems/gems/net-ldap-0.11/lib/net/ldap.rb:825:in
block in bind' /opt/rh/ruby193/root/usr/share/gems/gems/net-ldap-0.11/lib/net/ldap/instrumentation.rb:16:in
block in instrument'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications.rb:123:in
block in instrument' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications/instrumenter.rb:20:in
instrument'
instrument' /opt/rh/ruby193/root/usr/share/gems/gems/net-ldap-0.11/lib/net/ldap/instrumentation.rb:15:in
instrument'
/opt/rh/ruby193/root/usr/share/gems/gems/net-ldap-0.11/lib/net/ldap.rb:819:in
bind' /opt/rh/ruby193/root/usr/share/gems/gems/ldap_fluff-0.3.7/lib/ldap_fluff/active_directory.rb:10:in
bind?'
/opt/rh/ruby193/root/usr/share/gems/gems/ldap_fluff-0.3.7/lib/ldap_fluff/generic.rb:59:in
service_bind' /opt/rh/ruby193/root/usr/share/gems/gems/ldap_fluff-0.3.7/lib/ldap_fluff/generic.rb:28:in
group_exists?'
/opt/rh/ruby193/root/usr/share/gems/gems/ldap_fluff-0.3.7/lib/ldap_fluff/ldap_fluff.rb:70:in
block in valid_group?' /opt/rh/ruby193/root/usr/share/gems/gems/ldap_fluff-0.3.7/lib/ldap_fluff/ldap_fluff.rb:94:in
instrument'
instrument' /opt/rh/ruby193/root/usr/share/gems/gems/ldap_fluff-0.3.7/lib/ldap_fluff/ldap_fluff.rb:93:in
instrument'
/opt/rh/ruby193/root/usr/share/gems/gems/ldap_fluff-0.3.7/lib/ldap_fluff/ldap_fluff.rb:69:in
valid_group?' /usr/share/foreman/app/models/auth_sources/auth_source_ldap.rb:126:in
valid_group?'
/usr/share/foreman/app/models/external_usergroup.rb:40:in in_auth_source?' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:462:in
_run__2854846482808317312__validate__1351777678488640924__callbacks'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:405:in
__run_callback' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:385:in
_run_validate_callbacks'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:81:in
run_callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/activemodel-3.2.8/lib/active_model/validations.rb:227:in
run_validations!'
/opt/rh/ruby193/root/usr/share/gems/gems/activemodel-3.2.8/lib/active_model/validations/callbacks.rb:53:in
block in run_validations!' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:414:in
_run__2854846482808317312__validation__1351777678488640924__callbacks'
_run_validation_callbacks'
run_callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/activemodel-3.2.8/lib/active_model/validations/callbacks.rb:53:in
run_validations!'
/opt/rh/ruby193/root/usr/share/gems/gems/activemodel-3.2.8/lib/active_model/validations.rb:194:in
valid?' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/validations.rb:69:in
valid?'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/autosave_association.rb:300:in
association_valid?' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/autosave_association.rb:289:in
block in validate_collection_association'
each' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/autosave_association.rb:289:in
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/autosave_association.rb:217:in
block in add_autosave_association_callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/autosave_association.rb:161:in
instance_eval'
block in define_non_cyclic_method' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:495:in
_run__1035949724549725380__validate__1351777678488640924__callbacks'
run_validations!'
_run__1035949724549725380__validation__1351777678488640924__callbacks'
run_validations!'
valid?'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/validations.rb:77:in
perform_validations' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/validations.rb:50:in
save'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/attribute_methods/dirty.rb:22:in
save' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:241:in
block (2 levels) in save'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:295:in
block in with_transaction_returning_status' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/abstract/database_statements.rb:192:in
transaction'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:208:in
transaction' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:293:in
block in save' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:252:in
rollback_active_record_state!'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:240:in
save' /usr/share/foreman/app/controllers/usergroups_controller.rb:17:in
create'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/implicit_render.rb:4:in
send_action' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/base.rb:167:in
process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rendering.rb:10:in
process_action' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/callbacks.rb:18:in
block in process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:627:in
block (4 levels) in _run__4094423121386615773__process_action__866632758898403570__callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:215:in
block in _conditional_callback_around_11564'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:326:in
around' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:310:in
_callback_around_2439'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:214:in
_conditional_callback_around_11564' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:626:in
block (3 levels) in
block in _conditional_callback_around_11563' /usr/share/foreman/app/controllers/concerns/application_shared.rb:13:in
set_timezone'
_conditional_callback_around_11563' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:625:in
block (2 levels) in
block in _conditional_callback_around_11562' /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in
clear_thread'
_conditional_callback_around_11562' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:448:in
block in
block in _conditional_callback_around_11561' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:326:in
around'
_callback_around_13' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:214:in
_run__4094423121386615773__process_action__866632758898403570__callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:405:in
__run_callback'
_run_process_action_callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:81:in
run_callbacks'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/callbacks.rb:17:in
process_action' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rescue.rb:29:in
process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:30:in
block in process_action' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications.rb:123:in
instrument' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications.rb:123:in
instrument'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:29:in
process_action' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/params_wrapper.rb:207:in
process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/railties/controller_runtime.rb:18:in
process_action' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/base.rb:121:in
process'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/rendering.rb:45:in
process' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal.rb:203:in
dispatch'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rack_delegation.rb:14:in
dispatch' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal.rb:246:in
block in action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:73:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:73:in
dispatch'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:36:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:68:in
block in call'
/opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:56:in
each' /opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:56:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:600:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/static.rb:62:in
call'
call' /opt/rh/ruby193/root/usr/share/gems/gems/apipie-rails-0.2.6/lib/apipie/extractor/recorder.rb:97:in
call'
call'
call' /opt/rh/ruby193/root/usr/share/gems/gems/apipie-rails-0.2.6/lib/apipie/middleware/checksum_in_headers.rb:27:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/best_standards_support.rb:17:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/etag.rb:23:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/conditionalget.rb:35:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/head.rb:14:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/params_parser.rb:21:in
call' /usr/share/foreman/lib/middleware/catch_json_parse_errors.rb:9:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/flash.rb:242:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/session/abstract/id.rb:205:in
context'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/session/abstract/id.rb:200:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/cookies.rb:339:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/query_cache.rb:64:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/abstract/connection_pool.rb:473:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/callbacks.rb:28:in
block in call' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:405:in
_run__1395703953567639544__call__1351777678488640924__callbacks'
_run_call_callbacks'
run_callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/callbacks.rb:27:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/remote_ip.rb:31:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/debug_exceptions.rb:16:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/show_exceptions.rb:56:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/rack/logger.rb:26:in
call_app'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/rack/logger.rb:16:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/request_id.rb:22:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/methodoverride.rb:21:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/runtime.rb:17:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/cache/strategy/local_cache.rb:72:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/lock.rb:15:in
call'
call' /opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:136:in
forward'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:143:in
pass' /opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:155:in
invalidate'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:71:in
call!' /opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:51:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:479:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/application.rb:223:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/railtie/configurable.rb:30:in
method_missing' /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/builder.rb:134:in
call'
