Upgrading Katello was a success, but I don’t use the foreman host for puppetserver, instead use smartproxy for this role.
When updating a smartproxy with puppetserver/pulp roles foreman-installer returned this error:
/opt/puppetlabs/puppet/lib/ruby/2.4.0/rubygems/core_ext/kernel_require.rb:55:in 'require': cannot load such file -- kafo (LoadError) from /opt/puppetlabs/puppet/lib/ruby/2.4.0/rubygems/core_ext/kernel_require.rb:55:in 'require' from /usr/sbin/foreman-installer:3:in <main>'
Upgrade would proceed without error.
We are still running an older puppet version but the docs for 3.14 mention puppet 5.5.10 is min req and we do meet that.
[root@foreman-puppet001 ~ #] rpm -qa | egrep ‘foreman|katello|puppet|kafo|ruby’ | sort
foreman-debug-1.23.2-1.el7.noarch
foreman-installer-1.23.2-1.el7.noarch
foreman-installer-katello-1.23.2-1.el7.noarch
foreman-proxy-1.23.2-1.el7.noarch
foreman-proxy-content-3.13.4-1.el7.noarch
foreman-puppet001.test.domain-apache-1.0-2.noarch
foreman-puppet001.test.domain-foreman-proxy-1.0-2.noarch
foreman-puppet001.test.domain-foreman-proxy-client-1.0-2.noarch
foreman-puppet001.test.domain-puppet-client-1.0-2.noarch
foreman-puppet001.test.domain-qpid-broker-1.0-2.noarch
foreman-puppet001.test.domain-qpid-client-cert-1.0-2.noarch
foreman-puppet001.test.domain-qpid-router-client-1.0-2.noarch
foreman-puppet001.test.domain-qpid-router-server-1.0-2.noarch
foreman-release-1.24.3-1.el7.noarch
foreman-selinux-1.23.2-1.el7.noarch
katello-agent-3.1.0-1.el7.noarch
katello-ca-consumer-foreman001.prod.domain-1.0-20.noarch
katello-certs-tools-2.5.3-1.el7.noarch
katello-client-bootstrap-1.7.4-1.el7.noarch
katello-common-3.13.4-1.el7.noarch
katello-debug-3.13.4-1.el7.noarch
katello-default-ca-1.0-1.noarch
katello-host-tools-3.1.0-1.el7.noarch
katello-host-tools-fact-plugin-3.1.0-1.el7.noarch
katello-repos-3.14.1-1.el7.noarch
katello-selinux-3.1.1-1.el7.noarch
katello-server-ca-1.0-12.noarch
katello-service-3.13.4-1.el7.noarch
pulp-puppet-plugins-2.20.1-2.el7.noarch
puppet-agent-5.5.22-1.el7.x86_64
puppet-agent-oauth-0.5.1-3.el7.noarch
puppetdb-termini-5.2.19-1.el7.noarch
puppetserver-5.3.16-1.el7.noarch
python-pulp-puppet-common-2.20.1-2.el7.noarch
ruby-2.0.0.648-36.el7.x86_64
rubygem-ansi-1.4.3-2.el7.noarch
rubygem-bigdecimal-1.2.0-36.el7.x86_64
rubygem-bundler-1.7.8-3.el7.noarch
rubygem-bundler_ext-0.4.1-3.el7.noarch
rubygem-clamp-1.1.2-4.el7.noarch
rubygem-concurrent-ruby-1.1.4-2.el7.noarch
rubygem-ffi-1.9.10-2.el7.x86_64
rubygem-foreman_maintain-0.4.5-1.el7.noarch
rubygem-gssapi-1.1.2-3.el7.noarch
rubygem-hashie-3.6.0-1.el7.noarch
rubygem-highline-1.7.8-4.el7.noarch
rubygem-io-console-0.4.2-36.el7.x86_64
rubygem-json-1.7.7-36.el7.x86_64
rubygem-jwt-1.2.1-1.el7.noarch
rubygem-kafo-3.0.0-1.el7.noarch
rubygem-kafo_parsers-1.0.0-1.el7.noarch
rubygem-kafo_wizards-0.0.1-2.el7.noarch
rubygem-little-plugger-1.1.4-1.el7.noarch
rubygem-logging-2.2.2-3.el7.noarch
rubygem-multi_json-1.12.2-3.el7.noarch
rubygem-net-http-persistent-2.8-5.el7.noarch
rubygem-powerbar-2.0.1-1.el7.noarch
rubygem-psych-2.0.0-36.el7.x86_64
rubygem-rack-1.6.12-1.el7.noarch
rubygem-rack-protection-1.5.3-3.el7.noarch
rubygem-rake-0.9.6-36.el7.noarch
rubygem-rb-inotify-0.9.7-2.el7.noarch
rubygem-rdoc-4.0.0-36.el7.noarch
rubygem-rkerberos-0.1.3-6.el7.x86_64
rubygem-rsec-0.4.3-1.el7.noarch
rubygem-rubyipmi-0.10.0-3.el7.noarch
rubygems-2.0.14.1-36.el7.noarch
rubygem-sinatra-1.4.8-2.el7.noarch
rubygem-smart_proxy_pulp-1.4.1-1.el7.noarch
rubygem-thor-0.19.1-1.el7.noarch
rubygem-tilt-2.0.7-1.el7.noarch
ruby-irb-2.0.0.648-36.el7.noarch
ruby-libs-2.0.0.648-36.el7.x86_64
[root@foreman-puppet001 ~ #] cat /etc/redhat-release CentOS Linux release 7.9.2009 (Core)
That’s weird, the error basically means that foreman-installer can’t find kafo library (rubygem). You seem to have it installed rubygem-kafo-3.0.0-1.el7.noarch
. Are you by any chance in some SCL context? What’s slightly confusing is you foreman-installer version, 1.23.2 look quite old as well as katello 3.14.
ekohl
July 2, 2021, 2:52pm
#3
Do you by any chance have the Ruby SCL enabled while running the installer? Current Kafo should have fixes for that, but I think those only landed after started to run the installer in a modern ruby (using Ruby SCL). That wasn’t in 1.23.
Using RVM can also trigger that.
No RVM or SCL loaded that I can see:
[root@foreman-puppet001 ~ #] rvm
-bash: rvm: command not found
[root@foreman-puppet001 rh #] echo $X_SCLS
The package versions I listed were from after I reverted the install, here are the correct versions after enabling the repos and updating:
foreman-debug-1.24.3-1.el7.noarch
foreman-installer-1.24.3-1.el7.noarch
foreman-installer-katello-1.24.3-1.el7.noarch
foreman-proxy-1.24.3-1.el7.noarch
foreman-proxy-content-3.14.1-1.el7.noarch
foreman-selinux-1.24.3-1.el7.noarch
katello-certs-tools-2.6.0-1.el7.noarch
katello-common-3.14.1-1.el7.noarch
katello-debug-3.14.1-1.el7.noarch
katello-service-3.14.1-1.el7.noarch
pulp-puppet-plugins-2.21.5-1.el7.noarch
python-pulp-puppet-common-2.21.5-1.el7.noarch
rubygem-foreman_maintain-0.5.4-1.el7.noarch
rubygem-kafo-4.0.0-1.el7.noarch
rubygem-rb-inotify-0.9.7-3.el7.noarch
rubygem-rsec-0.4.3-2.el7.noarch
rubygem-rubyipmi-0.10.0-4.el7.noarch
rubygem-smart_proxy_pulp-1.5.0-1.el7.noarch
And then running the installer:
[root@foreman-puppet001 ~ #] foreman-installer --scenario foreman-proxy-content --upgrade --certs-tar-file ~/-certs.tar --certs-update-all --certs-regenerate true --certs-deploy true/opt/puppetlabs/puppet/lib/ruby/2.4.0/rubygems/core_ext/kernel_require.rb:55:in require': cannot load such file -- kafo (LoadError) from /opt/puppetlabs/puppet/lib/ruby/2.4.0/rubygems/core_ext/kernel_require.rb:55:in
require’
from /usr/sbin/foreman-installer:3:in `’
ekohl
July 2, 2021, 3:50pm
#5
I am interested in the output of ENV
. It looks like it’s trying to use the Puppet Ruby environment rather than the system Ruby. Can you also check what /usr/bin/foreman-installer
uses as shebang? If it’s /usr/bin/env ruby
then it may be sufficient to change it to /usr/bin/ruby
to be sure the system Ruby is used.
Satellite upgrade 6.3 -> 6.4 fails with '/opt/puppetlabs/puppet/lib/ruby/2.1.0/rubygems/core_ext/kernel_require.rb:55:in `require': cannot load such file -- kafo (LoadError)' - Red Hat Customer Portal says to move the puppet paths to the end of $PATH.
I did also find that forum thread mentioning foreman-installer using the wrong shebang, and changed it to /usr/bin/ruby.
I then got the following error:
[root@foreman-puppet001 ~ #] foreman-installer --scenario foreman-proxy-content --upgrade --certs-tar-file ~/`hostname -f`-certs.tar --certs-update-all --certs-regenerate true --certs-deploy truePlease unset the following environment variables before running the installer: http_proxy, https_proxy, ssl_cert_file, HTTP_PROXY, HTTPS_PROXY, SSL_CERT_FILE
Your system does not meet configuration criteria
Only SSL_CERT_FILE was set:
[root@foreman-puppet001 ~ #] unset SSL_CERT_FILE
And it looks like the installer has completed now.
Thanks for pointing me in the right direction.
