Hello everyone,
I am receiving an error when running the foreman-installer command attempting to upgrade from 3.16. to 3.17.
Error: Could not autoload puppet/feature/npm: cannot load such file – puppet/util/npm
A successful upgrade; The instructions make the upgrade seem incredibly easy.
- foreman-2.1.4-1.el7.noarch
- foreman-proxy-2.2.3-1.el7.noarch
Oracle Linux Server release 7.9
I am following the instruction step by step at https://www.theforeman.org/plugins/katello/3.17/upgrade/index.html
I also tried jumping a version to see if something might have been fixed in the next version and followed the guide at https://www.theforeman.org/plugins/katello/3.18/upgrade/index.html
The error below occurs when running the foreman-installer command. The screen output comes from the 3.18 attempt because it is more verbose but the error is the same in both versions.
2022-01-27 15:00:22 [NOTICE] [pre] Executing hooks in group pre
Failed to ensure rh-postgresql12-postgresql-server, rh-redis5-redis, foreman-selinux, katello-selinux, candlepin-selinux, pulpcore-selinux, crane-selinux, pulp-selinux are installed
2022-01-27 15:00:28 [ERROR ] [root] Failed to ensure rh-postgresql12-postgresql-server, rh-redis5-redis, foreman-selinux, katello-selinux, candlepin-selinux, pulpcore-selinux, crane-selinux, pulp-selinux are installed
Error: Could not autoload puppet/feature/npm: cannot load such file -- puppet/util/npm
Error: Facter: error while resolving custom fact "package_provider": Could not autoload puppet/feature/npm: cannot load such file -- puppet/util/npm
2022-01-27 15:00:28 [ERROR ] [root] Error: Could not autoload puppet/feature/npm: cannot load such file -- puppet/util/npm
The package verification error I don’t expect to occur because I verified that those packages are installed on the host.
[foreman-installer]# rpm -q rh-postgresql12-postgresql-server rh-redis5-redis foreman-selinux katello-selinux candlepin-selinux pulpcore-selinux crane-selinux pulp-selinux
rh-postgresql12-postgresql-server-12.7-1.el7.x86_64
rh-redis5-redis-5.0.5-3.el7.x86_64
foreman-selinux-2.3.5-1.el7.noarch
katello-selinux-3.5.0.1-1.el7.noarch
candlepin-selinux-3.1.22-1.el7.noarch
pulpcore-selinux-1.2.3-2.el7.x86_64
crane-selinux-3.5.0.1-1.el7.noarch
pulp-selinux-2.21.5-1.el7.noarch
I was not expecting the install to have npm issues as this system has been in production for years updated from previous versions. As a precaution I also re-attempted the upgrade after installing npm packages on the host with the same failure even though I think this error is related to the foreman-installer itself.
Thanks for your time,
Brad
