Hi all,
I’ve installed Katello 3.4 and had to change qdrouterd.conf file according to
The changes are merged, I’m not sure if we’ll get it backported to 3.4. You can probably take a copy of a working dispatch router configuration for 1.0 and drop it into 3.4 in /etc/qpid-dispatch, and things will run. I haven’t tested this, please report back if you get it working.
You’ll at least need to change the hostname in the router id, I think everything else is the same.
Note - The installer will overwrite it when it runs again, however.
Now I’ve installed a proxy, and everything’s working besides qdrouterd. Looking at the .conf file and don’t know what I need to change on the proxy without broken anything.
Has anybody had this issue? How can I fix this?
Bruno
I believe you can follow the steps outlined here to resolve the issue. Let us know how it goes.
Hi, thanks for the quick answer.
This configuration seens to be for the server, right? My server is ok, the proxy it’s the one that doesn’t start qdrouterd.
Bruno
Hi all,
Seens like downgrade qpid packages works also for proxy.
Bruno
