This procedure was generated from procedures/katello/release.md.erb at baf48515033781dbc041cf13bbeac56c96ef4180
Make this post a wiki (help)
Roles
- Release Owner: @qcjames53
- Release Engineer: @pcreech
When Ready to Release
Release Owner
Request Hammer CLI Katello release from maintainers
Request Virt Who Configure release from maintainers
Request any other releases as needed from the release owners (consult the
:repos:section ofconfigs/katello/4.16.yaml) -
Do Cherry-picks: Clone tool_belt
- If any minor versions of Katello have been added to Redmine since the last cherry-pick, make sure to include them in
prior_releasesin configs/katello/4.16.yaml - Run
./tools.rb setup-environment configs/katello/4.16.yaml - Run
GITHUB_ACCESS_TOKEN=<secret> ./tools.rb cherry-picks --version 4.16.0 configs/katello/4.16.yaml - Open a PR in Katello release branch. Make sure the PR name starts with [CP] to prevent our automations from adding it to Redmine issues.
- Using
git cherry-pick -xas needed, verify tickets in the cherry_picks_4.16.0 file are accounted for, or additionally cherry-pick them. Recommended: Do this in tool_belt’s checkout of Katello, inrepos/katello/4.16.0/katello. This way when you run cherry-picks again, tool_belt will be aware of any picks already completed. - For any cherry-picks that are not needed (including Redmine trackers) you can add them to the
:ignores:section oftool_beltinconfigs/katello/4.16.yaml
Change Redmine version 4.16.0 state to Closed using close_redmine_version:
PROJECT=katello VERSION=4.16 ./close_redmine_versionand enter your Redmine API Key when prompted. -
Check for outdated deprecation warnings in the current and next release with
./tools check-deprecation-warnings configs/katello/4.16.yaml. Follow the instructions in the output of the command. Don’t forget to create any Redmine issues needed! -
Update the
3.14branch in foreman-documentation- Ensure release notes are correct
- Headline features: important features with a few sentences description each
- Upgrade notes: all important notices that users must be aware of before upgrading
- Deprecations: features that will be removed or changed in a future version
- Using redmine_release_notes (see README as well):
./guides/doc-Release_Notes/redmine_release_notes katello 4.16.0 > ./guides/doc-Release_Notes/topics/katello-4.16.0.adoc - Add
topics/katello-4.16.0.adoctoguides/doc-Release_Notes/master.adoc:sed '/x.y.z releases here/a include::topics/katello-4.16.0.adoc[leveloffset=+1]' master.adoc - Update katello-contributors.adoc with the list of contributors using
git log --since="<YYYY-MM-DD of previous major release branching>" --format="%an" | sort | uniq. Manually clean up any erroneous entries. - Submit this as a PR
Open a PR (or use cherry-pick PR) against the release branch which updates
lib/katello/version.rbto 4.16.0:-
git pullto make sure you have the latest changes -
sed '/VERSION/ s/".\+"/"4.16.0"/' lib/katello/version.rb - Update/add the CHANGELOG.md file:
GITHUB_ACCESS_TOKEN=<secret> ./tools changelog --version 4.16.0 configs/katello/4.16.yaml - Commit:
git commit -m "Release 4.16.0" - Ensure that the commit above is the last commit and there are no commits after it. This is the commit that will get tagged. (Rearrange commits with
git rebase -iif needed.)
Once the PR is merged, perform the following in the Katello release branch (the real one, not your fork):
- Create upstream remote:
git remote add upstream https://github.com/Katello/katello.git - Fetch upstream remote:
git fetch upstream - Checkout upstream release branch:
git checkout upstream/KATELLO-4.16 - Tag:
git tag -s -m "Release 4.16.0" 4.16.0 - Push:
git push --follow-tags(Must be pushed directly to the release branch, as pull request merges will not preserve tags.) - Generate .mo translation files:
make -C locale all-moin the katello directory - Generate source gem:
gem build katello.gemspec - Ensure you have a working login and password at rubygems.org
- Push gem:
gem push katello-4.16.0.gem
Inform the delivery team that the gem is published
Once Source is Available
Note it is considered good practice to release on a day when the next day is a working day. This means no releases on Fridays or on the day before a holiday.
Release Engineer
- Wait for Foreman 3.14.0 GA to be packaged and built before proceeding
- Update release version similar to here
- Update
katello,katello-reposandrubygem-katello- Use bump_rpm_packaging:
PROJECT=katello VERSION=4.16 ./bump_rpm_packaging
- Merge packaging PR once job is green
- Use wait_packaging to wait for Jenkins to build the packages
- Sign the RPMs in the release
- Use release_pipeline to kick off the release pipeline
Once release is out
Release Owner
- Wait for Foreman 3.14.0 GA to be announced before proceeding
- Confirm response that the build succeeded (or if necessary, do more cherry-picks and version bumps repeating the steps above)
- Test the install and upgrade documentation for both the Katello server and smart proxy
- Post a release announcement
- Create and upload release specific developer stable box
- Remove references to the oldest Katello version from testKatello.groovy and katello-pipelines.yml.
