I have upgraded from 2.5.4/4.1.4 through 3.0/4.2 to 3.1.1/4.3.0 without problems. Now I wanted to publish a new version of my content views. For two of them it worked, two others ended with an error. The two CVs (one for el7 and one for el8) which were published don’t have any filters set. The two which failed have a filter set to block out most of epel7 or epel8 expect a few rpms which we need. So my guess is it has to do with the filter.
The publish tasks get into pause state:
A paused task represents a process that has not finished properly. Any task in paused state can lead to potential inconsistency and needs to be resolved.
The recommended approach is to investigate the error messages below and in 'errors' tab, address the primary cause of the issue and resume the task.
Errors:
Error message: the server returns an error
HTTP status code: 400
Response headers: {"date"=>"Wed, 02 Feb 2022 02:54:16 GMT", "server"=>"gunicorn", "content-type"=>"application/json", "vary"=>"Accept,Cookie", "allow"=>"POST, OPTIONS", "x-frame-options"=>"DENY", "content-length"=>"279", "x-content-type-options"=>"nosniff", "referrer-policy"=>"same-origin", "correlation-id"=>"8617f7ea-4c84-4830-a7c7-ec2265dcb4b3", "access-control-expose-headers"=>"Correlation-ID", "via"=>"1.1 foreman.example.com", "connection"=>"close"}
Response body: ["Could not find the following content units: ['/pulp/api/v3/content/rpm/advisories/5b9c9a27-2452-4e80-b272-bfd5fef25e53/', '/pulp/api/v3/content/rpm/advisories/7ad18e86-ef79-4dc4-8969-66aa09d25ab3/', '/pulp/api/v3/content/rpm/advisories/60217268-3442-4d83-91c0-809a27ab7399/']"]
foreman 3.1.1
katello 4.3.0
foreman-tasks 5.2.0
foreman_remote_execution 5.0.1
CentOS Linux release 7.9.2009 (Core)
Action:
Actions::Pulp3::Repository::CopyContent
Input:
{"filter_ids"=>[25, 26, 27, 28, 29],
"solve_dependencies"=>false,
"rpm_filenames"=>nil,
"remove_all"=>true,
"source_repository_id"=>177,
"target_repository_id"=>72860,
"smart_proxy_id"=>1,
"remote_user"=>"admin",
"remote_cp_user"=>"admin",
"current_request_id"=>"8617f7ea-4c84-4830-a7c7-ec2265dcb4b3",
"current_timezone"=>"UTC",
"current_organization_id"=>nil,
"current_location_id"=>nil,
"current_user_id"=>4}
Output:
Exception:
PulpRpmClient::ApiError: Error message: the server returns an error
Backtrace:
/opt/theforeman/tfm/root/usr/share/gems/gems/pulp_rpm_client-3.16.1/lib/pulp_rpm_client/api_client.rb:83:in `call_api'
/opt/theforeman/tfm/root/usr/share/gems/gems/pulp_rpm_client-3.16.1/lib/pulp_rpm_client/api/repositories_rpm_api.rb:300:in `modify_with_http_info'
/opt/theforeman/tfm/root/usr/share/gems/gems/pulp_rpm_client-3.16.1/lib/pulp_rpm_client/api/repositories_rpm_api.rb:244:in `modify'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/services/katello/pulp3/repository.rb:490:in `add_content'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/services/katello/pulp3/repository/yum.rb:208:in `block in copy_units'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/services/katello/pulp3/repository/yum.rb:207:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/services/katello/pulp3/repository/yum.rb:207:in `each_slice'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/services/katello/pulp3/repository/yum.rb:207:in `copy_units'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/services/katello/pulp3/repository/yum.rb:362:in `copy_content_for_source'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/lib/actions/pulp3/repository/copy_content.rb:18:in `invoke_external_task'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/action/polling.rb:84:in `initiate_external_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/action/polling.rb:19:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/action/cancellable.rb:14:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/lib/actions/pulp3/abstract_async_task.rb:10:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/action.rb:582:in `block (3 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/middleware/stack.rb:27:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/middleware.rb:19:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/middleware.rb:32:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/middleware/stack.rb:23:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/lib/actions/middleware/remote_action.rb:16:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/lib/actions/middleware/remote_action.rb:40:in `block in as_remote_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/models/katello/concerns/user_extensions.rb:21:in `cp_config'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/lib/actions/middleware/remote_action.rb:27:in `as_cp_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/lib/actions/middleware/remote_action.rb:39:in `as_remote_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/lib/actions/middleware/remote_action.rb:16:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/rails_executor_wrap.rb:14:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/execution_wrapper.rb:88:in `wrap'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/rails_executor_wrap.rb:13:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/action/progress.rb:31:in `with_progress_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/action/progress.rb:17:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/load_setting_values.rb:20:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/keep_current_request_id.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/keep_current_request_id.rb:52:in `restore_current_request_id'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/keep_current_request_id.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/keep_current_timezone.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/keep_current_timezone.rb:44:in `restore_curent_timezone'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/keep_current_timezone.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/keep_current_taxonomies.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/keep_current_taxonomies.rb:45:in `restore_current_taxonomies'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/keep_current_taxonomies.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/keep_current_user.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/keep_current_user.rb:54:in `restore_curent_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-5.2.0/app/lib/actions/middleware/keep_current_user.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/middleware/world.rb:31:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/action.rb:581:in `block (2 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/action.rb:580:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/action.rb:580:in `block in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/action.rb:483:in `block in with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/action.rb:483:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/action.rb:483:in `with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/action.rb:575:in `execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/action.rb:296:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:18:in `block (2 levels) in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/execution_plan/steps/abstract.rb:167:in `with_meta_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:17:in `block in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:32:in `open_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:16:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/director.rb:69:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/executors/sidekiq/worker_jobs.rb:11:in `block (2 levels) in perform'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/executors.rb:18:in `run_user_code'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/executors/sidekiq/worker_jobs.rb:9:in `block in perform'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/executors/sidekiq/worker_jobs.rb:25:in `with_telemetry'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/executors/sidekiq/worker_jobs.rb:8:in `perform'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.3/lib/dynflow/executors/sidekiq/serialization.rb:27:in `perform'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:192:in `execute_job'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:165:in `block (2 levels) in process'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/middleware/chain.rb:128:in `block in invoke'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/middleware/chain.rb:133:in `invoke'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:164:in `block in process'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:137:in `block (6 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/job_retry.rb:109:in `local'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:136:in `block (5 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq.rb:37:in `block in <module:Sidekiq>'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:132:in `block (4 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:250:in `stats'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:127:in `block (3 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/job_logger.rb:8:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:126:in `block (2 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/job_retry.rb:74:in `global'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:125:in `block in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/logging.rb:48:in `with_context'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/logging.rb:42:in `with_job_hash_context'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:124:in `dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:163:in `process'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:83:in `process_one'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:71:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/util.rb:16:in `watchdog'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/util.rb:25:in `block in safe_thread'
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-2.3.0/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
