Foreman Katello repo not presenting packages to clients Expected outcome:
Katello repo is useable by clients Foreman and Proxy versions:
3.7 Foreman and Proxy plugin versions:
??? Distribution and version:
Rocky Linux 8.9 Other relevant data:
Foreman-3.7 & Katello-4.9 installed without issue on Rocky Linux 8.9. CentOS6/7 and Rocky Linux 8/9 repos successfully setup and useable by clients. Foreman-client and Foreman-3.7 repos setup, client repo visible and available to all. Foreman-3.7 visible and available to the Foreman server and the Smart Proxy server I am attempting to setup. Katello-4.9 repo is visible to the Smart Proxy server I want to setup but searching for any packages on the local Katello repo shows no results found. I have verified that yum is pulling down the repodata from all configured repos, only the local Katello repo has issue. Please let me know what other info I can provide.
@evgeni Thank you! I was following the guide here: Installing a Smart Proxy Server 3.7 on CentOS/RHEL and at no point between the start of the document and section 2.2 command #2 does it mention about enabling the modules for Smart Proxy, I found it referenced in an appendix of the above site though.
