at first start i get:
System check identified some issues:
WARNINGS:
?: (guardian.W001) Guardian authentication backend is not hooked. You can add this in settings as eg: AUTHENTICATION_BACKENDS = ('django.contrib.auth.backen ds.ModelBackend', 'guardian.backends.ObjectPermissionBackend')
Operations to perform:
Apply all migrations: admin, auth, certguard, container, contenttypes, core, deb, file, guardian, pulp_2to3_migration, rpm, sessions
Running migrations:
Applying deb.0013_aptremote_ignore_missing_package_indices… OK
Then i started it again and getting:
WARNINGS:
?: (guardian.W001) Guardian authentication backend is not hooked. You can add this in settings as eg: AUTHENTICATION_BACKENDS = ('django.contrib.auth.backends.ModelBackend', 'guardian.backends.ObjectPermissionBackend')
Running migrations:
No migrations to apply.
Your models have changes that are not yet reflected in a migration, and so won’t be applied.
Run ‘manage.py makemigrations’ to make new migrations, and then re-run ‘manage.py migrate’ to apply them.
