jenkins
1
ekohl
2
[2021-09-14T00:35:01.512Z] not ok 3 sync proxy
[2021-09-14T00:35:01.512Z] # (in test file fb-katello-proxy.bats, line 26)
[2021-09-14T00:35:01.512Z] # `hammer capsule content synchronize --id=$PROXY_ID' failed with status 70
[2021-09-14T00:35:01.512Z] # Task 4f046ffa-8d75-490a-a9fc-b942962721f3 running: 0.0/1, 0%, elapsed: 00:00:00
[2021-09-14T00:35:01.512Z] # Task 4f046ffa-8d75-490a-a9fc-b942962721f3 running: 0.1/1, 10%, 0.0/s, elapsed: 00:00:02, ETA: 00:00:20
[2021-09-14T00:35:01.512Z] # Task 4f046ffa-8d75-490a-a9fc-b942962721f3 running: 0.22/1, 22%, 0.0/s, elapsed: 00:00:04, ETA: 00:00:16
[2021-09-14T00:35:01.512Z] # Task 4f046ffa-8d75-490a-a9fc-b942962721f3 running: 0.65/1, 65%, 0.1/s, elapsed: 00:00:06, ETA: 00:00:03
[2021-09-14T00:35:01.512Z] # Task 4f046ffa-8d75-490a-a9fc-b942962721f3 running: 0.94/1, 94%, 0.1/s, elapsed: 00:00:09
[2021-09-14T00:35:01.512Z] # Task 4f046ffa-8d75-490a-a9fc-b942962721f3 warning: 1.0/1, 100%, 0.1/s, elapsed: 00:00:11
[2021-09-14T00:35:01.512Z] # Error: undefined method `params_encoder=' for #<PulpDebClient::Configuration:0x000000000fa4c338>
[2021-09-14T00:35:01.512Z] # Did you mean? params_encoding=
[2021-09-14T00:35:01.512Z] # params_encoding
[2021-09-14T00:35:01.512Z] # Missing the required parameter 'container_container_repository_href' when calling RepositoriesContainerApi.sync
[2021-09-14T00:35:01.512Z] # undefined method `latest_version_href' for nil:NilClass
[2021-09-14T00:35:01.512Z] # Missing the required parameter 'file_file_repository_href' when calling RepositoriesFileApi.sync
[2021-09-14T00:35:01.512Z] # Missing the required parameter 'rpm_rpm_repository_href' when calling RepositoriesRpmApi.sync
evgeni
3
cc @katello this is a legit error, outside of our current qpid woes.
system
Closed
5
