14:18:34 <@Zhenech> ewoud: katello-nightly-rpm-pipeline [Jenkins] is running again, wish us luck?
14:18:47 <@Zhenech> (I am confident el8 will bomb out, but el7… maybe)
Looks like at least EL7 passed so that’s good progress. EL8 fails with:
15:34:16 TASK [update_os_packages : RedHat | Update packages] ***************************
15:34:16 e[0;31mfatal: [pipe-up-katello-nightly-centos8]: FAILED! => changed=false e[0m
15:34:16 e[0;31m failures: []e[0m
15:34:16 e[0;31m msg: |-e[0m
15:34:16 e[0;31m Depsolve Error occured:e[0m
15:34:16 e[0;31m Problem 1: cannot install both createrepo_c-libs-0.17.6-3.el8.x86_64 and createrepo_c-libs-0.17.6-1.el8.x86_64e[0m
15:34:16 e[0;31m - package python3-createrepo_c-0.17.6-1.el8.x86_64 requires createrepo_c-libs = 0.17.6-1.el8, but none of the providers can be installede[0m
15:34:16 e[0;31m - cannot install the best update candidate for package createrepo_c-libs-0.17.6-1.el8.x86_64e[0m
15:34:16 e[0;31m - problem with installed package python3-createrepo_c-0.17.6-1.el8.x86_64e[0m
15:34:16 e[0;31m Problem 2: cannot install both libsolv-0.7.20-3.el8.x86_64 and libsolv-0.7.20-1.el8.x86_64e[0m
15:34:16 e[0;31m - package python3-solv-0.7.20-1.el8.x86_64 requires libsolv(x86-64) = 0.7.20-1.el8, but none of the providers can be installede[0m
15:34:16 e[0;31m - cannot install the best update candidate for package libsolv-0.7.20-1.el8.x86_64e[0m
15:34:16 e[0;31m - problem with installed package python3-solv-0.7.20-1.el8.x86_64e[0m
15:34:16 e[0;31m Problem 3: package python38-pulp-rpm-3.15.0-2.el8.noarch requires python38-createrepo_c >= 0.17.0, but none of the providers can be installede[0m
15:34:16 e[0;31m - package python38-createrepo_c-0.17.6-2.el8.x86_64 requires createrepo_c-libs = 0.17.6-2.el8, but none of the providers can be installede[0m
15:34:16 e[0;31m - package python38-createrepo_c-0.17.6-3.el8.x86_64 requires createrepo_c-libs = 0.17.6-3.el8, but none of the providers can be installede[0m
15:34:16 e[0;31m - cannot install both createrepo_c-libs-0.17.6-2.el8.x86_64 and createrepo_c-libs-0.17.6-1.el8.x86_64e[0m
15:34:16 e[0;31m - cannot install both createrepo_c-libs-0.17.6-3.el8.x86_64 and createrepo_c-libs-0.17.6-1.el8.x86_64e[0m
15:34:16 e[0;31m - cannot install the best update candidate for package python3-pulp-rpm-3.14.6-2.el8.noarche[0m
15:34:16 e[0;31m - cannot install the best update candidate for package python3-createrepo_c-0.17.6-1.el8.x86_64e[0m
15:34:16 e[0;31m Problem 4: package python38-pulp-rpm-3.15.0-2.el8.noarch requires python38-solv >= 0.7.17, but none of the providers can be installede[0m
15:34:16 e[0;31m - package python38-solv-0.7.20-2.el8.x86_64 requires libsolv(x86-64) = 0.7.20-2.el8, but none of the providers can be installede[0m
15:34:16 e[0;31m - package python38-solv-0.7.20-3.el8.x86_64 requires libsolv(x86-64) = 0.7.20-3.el8, but none of the providers can be installede[0m
15:34:16 e[0;31m - problem with installed package python3-pulp-rpm-3.14.6-2.el8.noarche[0m
15:34:16 e[0;31m - cannot install both libsolv-0.7.20-2.el8.x86_64 and libsolv-0.7.20-1.el8.x86_64e[0m
15:34:16 e[0;31m - cannot install both libsolv-0.7.20-3.el8.x86_64 and libsolv-0.7.20-1.el8.x86_64e[0m
15:34:16 e[0;31m - package python3-pulp-rpm-3.14.6-2.el8.noarch requires python3-django-readonly-field, but none of the providers can be installede[0m
15:34:16 e[0;31m - package python38-django-readonly-field-1.0.5-3.el8.noarch obsoletes python3-django-readonly-field < 1.0.5-3.el8 provided by python3-django-readonly-field-1.0.5-1.el8.noarche[0m
15:34:16 e[0;31m - cannot install the best update candidate for package python3-solv-0.7.20-1.el8.x86_64e[0m
15:34:16 e[0;31m - cannot install the best update candidate for package python3-django-readonly-field-1.0.5-1.el8.noarche[0m
15:34:16 e[0;31m rc: 1e[0m
15:34:16 e[0;31m results: []e[0m
