jenkins
#1
evgeni
#2
EL8 upgrade again failed with Puppet…
2022-02-04T01:49:24 [I|app|069608ea] Started POST "/api/hosts/facts" for 192.168.121.181 at 2022-02-04 01:49:24 +0000
2022-02-04T01:49:24 [I|app|069608ea] Processing by Api::V2::HostsController#facts as JSON
2022-02-04T01:49:24 [I|app|069608ea] Parameters: {"facts"=>"[FILTERED]", "name"=>"pipe-up-katello-nightly-centos8-stream.n18.example.com", "certname"=>"pipe-up-katello-nightly-centos8-stream.n18.example.com", "apiv"=>"v2", "host"
=>{"certname"=>"pipe-up-katello-nightly-centos8-stream.n18.example.com", "name"=>"pipe-up-katello-nightly-centos8-stream.n18.example.com"}}
2022-02-04T01:49:25 [I|app|069608ea] Import facts for 'pipe-up-katello-nightly-centos8-stream.n18.example.com' completed. Added: 7, Updated: 6, Deleted 0 facts
2022-02-04T01:49:25 [W|app|069608ea] Action failed
2022-02-04T01:49:25 [I|app|069608ea] Backtrace for 'Action failed' error (ActiveRecord::RecordInvalid): Validation failed: Description has already been taken, Title has already been taken
069608ea | /usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/validations.rb:80:in `raise_validation_error'
069608ea | /usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/validations.rb:53:in `save!'
069608ea | /usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/transactions.rb:318:in `block in save!'
069608ea | /usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/transactions.rb:375:in `block in with_transaction_returning_status'
069608ea | /usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/database_statements.rb:280:in `block in transaction'
069608ea | /usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/transaction.rb:280:in `block in within_new_transaction'
069608ea | /usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
069608ea | /usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
069608ea | /usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
069608ea | /usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
069608ea | /usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
069608ea | /usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/transaction.rb:278:in `within_new_transaction'
069608ea | /usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/connection_adapters/abstract/database_statements.rb:280:in `transaction'
069608ea | /usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/transactions.rb:212:in `transaction'
069608ea | /usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/transactions.rb:366:in `with_transaction_returning_status'
069608ea | /usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/transactions.rb:318:in `save!'
069608ea | /usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/suppressor.rb:48:in `save!'
069608ea | /usr/share/foreman/app/services/puppet_fact_parser.rb:38:in `operatingsystem'
Which is the same thing we’ve seen in Katello-nightly-rpm-pipeline 1220 failed
CC @Marek_Hulan @ekohl
system
Closed
#3
