meh, this is the recent psql change in foreman maintain packaging:
[2022-05-03T00:18:30.175Z] e[0;31m 2022-05-03 00:13:57 [ERROR ] [configure] Execution of '/bin/yum -d 0 -e 0 -y install rh-postgresql12-postgresql-syspaths' returned 1: Error: rh-postgresql12-postgresql-syspaths conflicts with postgresql-9.2.24-7.el7_9.x86_64e[0m
[2022-05-03T00:18:30.175Z] e[0;31m 2022-05-03 00:13:57 [ERROR ] [configure] You could try using --skip-broken to work around the probleme[0m
[2022-05-03T00:18:30.175Z] e[0;31m 2022-05-03 00:13:57 [ERROR ] [configure] You could try running: rpm -Va --nofiles --nodigeste[0m
[2022-05-03T00:18:30.175Z] e[0;31m 2022-05-03 00:13:57 [ERROR ] [configure] /Stage[main]/Postgresql::Client/Package[postgresql-client]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/yum -d 0 -e 0 -y install rh-postgresql12-postgresql-syspaths' returned 1: Error: rh-postgresql12-postgresql-syspaths conflicts with postgresql-9.2.24-7.el7_9.x86_64e[0m
