https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/2128/
[2024-09-11T23:16:41.495Z] TASK [update_os_packages : RedHat | Update packages] ***************************
[2024-09-11T23:16:41.495Z] fatal: [pipe-up-katello-nightly-almalinux8]: FAILED! => changed=false
[2024-09-11T23:16:41.495Z] failures: []
[2024-09-11T23:16:41.495Z] msg: |-
[2024-09-11T23:16:41.495Z] Depsolve Error occurred:
[2024-09-11T23:16:41.495Z] Problem: package python3.11-requests-2.31.0-5.el8.noarch from @System requires python3.11-charset-normalizer < 3, but none of the providers can be installed
[2024-09-11T23:16:41.495Z] - cannot install both python3.11-charset-normalizer-3.3.2-1.el8.noarch from pulpcore-repository and python3.11-charset-normalizer-2.1.1-5.el8.noarch from @System
[2024-09-11T23:16:41.495Z] - cannot install both python3.11-charset-normalizer-3.3.2-1.el8.noarch from pulpcore-repository and python3.11-charset-normalizer-2.1.0-1.el8.noarch from appstream
[2024-09-11T23:16:41.495Z] - cannot install the best update candidate for package python3.11-requests-2.31.0-5.el8.noarch
[2024-09-11T23:16:41.495Z] - cannot install the best update candidate for package python3.11-charset-normalizer-2.1.1-5.el8.noarch
[2024-09-11T23:16:41.495Z] rc: 1
[2024-09-11T23:16:41.495Z] results: []
This seems to be some breakage in Pulpcore nightly (
@Odilhao)
But installs were green! With Zeitwerk!
Looks like we had some old requirements, here the PR to fix it.
[2024-09-12T12:17:02.916Z] Problem: package python3.11-aiohttp-3.9.5-1.el8.x86_64 from pulpcore-repository requires python3.11-charset-normalizer < 3.0, but none of the providers can be installed
NEEEEEEEXT
Why isn’t the pulpcore pipeline catching these issues?
It’s not doing “dnf upgrade”, only “install”, and that takes “whatever fits”.
