https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/213/
foreman-katello-nightly-test (passed)
Seems this is still the candlepin issue from katello-nightly-rpm-pipeline 204 failed, but now it’s the 3.11 to 3.12 upgrade that’s failing – the upgrade is using released bits, not staging ones.
@Jonathon_Turel what’s left to make the fix available in 3.12 proper?
https://ci.theforeman.org/job/katello-3.12-rpm-pipeline/12/ ran but the upgrade test failed. This is because it also affects katello 3.10 (which is in the upgrade pipeline). That ships candlepin 2.5.7 (same as 3.9). Looks like 3.11 ships 2.5.9 while the fix should be in candlepin 2.5.17.
This does hit users who want to upgrade and for upgrade blockers we’ve always made an exception.
@Jonathon_Turel could you share your thoughts on this?
2.5.17 works well with Katello 3.10, so I’ve built and tagged it in: http://koji.katello.org/koji/buildinfo?buildID=48582
Can one of ya’ll start the 3.10 pipeline?
I’ll test it also for 3.11
