https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/247/
foreman-katello-nightly-test (failed)
seems to be failing on qpid deps:
Error: Package: qpid-dispatch-router-1.9.0-1.el7.x86_64 (epel)
Requires: qpid-proton-c(x86-64) >= 0.29.0
Available: qpid-proton-c-0.14.0-2.el7.x86_64 (extras)
qpid-proton-c(x86-64) = 0.14.0-2.el7
Installing: qpid-proton-c-0.28.0-1.el7.x86_64 (epel)
qpid-proton-c(x86-64) = 0.28.0-1.el7
Requires: python2-qpid-proton >= 0.29.0
Available: python2-qpid-proton-0.28.0-1.el7.x86_64 (epel)
python2-qpid-proton = 0.28.0-1.el7
Available: qpid-proton-c-0.28.0-1.el7.x86_64 (epel)
I’ve pinged the qpid folks in seemingly the correct way & place: https://bodhi.fedoraproject.org/updates/FEDORA-EPEL-2019-2408fbd638
Could we pin our dependency on qpid-dispatch-router < 1.9.0 until EPEL fixes this?
I don’t think the previous version is in the repos anymore which means we’d need to copy them to our client repos. Is that what you were suggesting?
Ah, i guess EPEL only carries one version of each rpm, i was hoping 1.8 was still available but apparently not.
Irina has marked the necessary qpid-proton for release. It should be 1-2 days before it arrives.
