https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/385/
foreman-katello-nightly-test (passed)
TASK [foreman_proxy_content : Detect certs generate] ***************************
fatal: [pipeline-upgrade-katello-proxy-nightly-centos7 -> 192.168.121.83]: FAILED! => changed=true
cmd:
- which
- foreman-proxy-certs-generate
delta: '0:00:00.005387'
end: '2020-02-04 22:45:43.932201'
msg: non-zero return code
rc: 1
start: '2020-02-04 22:45:43.926814'
stderr: 'which: no foreman-proxy-certs-generate in (/sbin:/bin:/usr/sbin:/usr/bin)'
stderr_lines: <omitted>
stdout: ''
stdout_lines: <omitted>
...ignoring
Tuesday 04 February 2020 22:45:44 +0000 (0:00:00.807) 0:09:12.996 ******
Tuesday 04 February 2020 22:45:44 +0000 (0:00:00.171) 0:09:13.168 ******
TASK [foreman_proxy_content : Generate Certs] **********************************
fatal: [pipeline-upgrade-katello-proxy-nightly-centos7 -> 192.168.121.83]: FAILED! => changed=false
cmd: capsule-certs-generate --capsule-fqdn pipeline-upgrade-katello-proxy-nightly-centos7.n1.example.com --certs-tar /root/pipeline-upgrade-katello-proxy-nightly-centos7.n1.example.com.tar.gz
msg: '[Errno 2] No such file or directory'
rc: 2
So the chain of events causing this is:
Now why is the ‘katello’ package not being installed? I was not able to
figure it out, it worked for both eric and I when we tried it. Will dig
some more…
huh, this is very odd… looks like 386 passed, so maybe it was in fact due to the issue in epel that somehow broke some dependency resolution or something?
very strange, i guess that could have been it?
