https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/615/
TASK [foreman_proxy_content : Generate Certs] **********************************
fatal: [pipeline-proxy-nightly-centos7 -> 192.168.121.227]: FAILED! => changed=true
cmd:
- foreman-proxy-certs-generate
- --foreman-proxy-fqdn
- pipeline-proxy-nightly-centos7.n60.example.com
- --certs-tar
- /root/pipeline-proxy-nightly-centos7.n60.example.com.tar.gz
delta: '0:00:09.111538'
end: '2018-12-26 00:11:21.105393'
msg: non-zero return code
rc: 21
start: '2018-12-26 00:11:11.993855'
stderr: |-
tput: unknown terminal "unknown"
Parameter parent-fqdn invalid: nil is not a valid string
stderr_lines:
- 'tput: unknown terminal "unknown"'
- 'Parameter parent-fqdn invalid: nil is not a valid string'
stdout: Error during configuration, exiting
stdout_lines: <omitted>
to retry, use: --limit @/root/.ansible/retry-files/katello_pipeline.retry
Likely related to https://github.com/theforeman/foreman-installer/pull/268 - @ekohl please take a look when you’re back from holidays
The issue is that for some reason Kafo can’t resolve $facts['fqdn']
instead of $::fqdn
. This is where the change was introduced:
I suspect it’s the way we dump defaults in kafo that doesn’t handle an array.
Any updates on this? katello nightlies are still failing
Looks like this has been resolved, nightlies are now green.
