https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/628/
foreman-pipeline-katello-nightly-centos7-upgrade (failed)
foreman-pipeline-katello-nightly-centos7-install (passed)
Looks like apipie cache is failing on some permissions issue in 3.15:
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: Apipie cache enabled but not present yet. Run apipie:cache rake task to speed up API calls.
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: rake aborted!
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: NoMethodError: undefined method `permissions' for nil:NilClass
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/models/role.rb:161:in `block (2 levels) in add_permissions'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/models/role.rb:160:in `each'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/models/role.rb:160:in `block in add_permissions'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/models/role.rb:157:in `each'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/models/role.rb:157:in `add_permissions'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/models/role.rb:207:in `add_permissions!'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/services/foreman/plugin/role_lock.rb:43:in `block in create_plugin_role'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/models/role.rb:86:in `ignore_locking'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/services/foreman/plugin/role_lock.rb:40:in `create_plugin_role'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/services/foreman/plugin/role_lock.rb:35:in `block in process_role'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.9.0/lib/audited/auditor.rb:376:in `without_auditing'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/services/foreman/plugin/role_lock.rb:33:in `process_role'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/services/foreman/plugin/role_lock.rb:12:in `block in register_role'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:108:in `as'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:114:in `as_anonymous_admin'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/services/foreman/plugin/role_lock.rb:11:in `register_role'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/registries/foreman/plugin.rb:294:in `block (2 levels) in role'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/registries/foreman/plugin.rb:293:in `block in role'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/registries/foreman/plugin.rb:292:in `role'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.15.3.1/lib/katello/plugin.rb:341:in `block in <top (required)>'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/registries/foreman/plugin.rb:76:in `instance_eval'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/app/registries/foreman/plugin.rb:76:in `register'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.15.3.1/lib/katello/plugin.rb:5:in `<top (required)>'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/polyglot-0.3.5/lib/polyglot.rb:65:in `require'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:287:in `block in require'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:253:in `load_dependency'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/dependencies.rb:287:in `require'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.15.3.1/lib/katello/engine.rb:67:in `block in <class:Engine>'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:32:in `instance_exec'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:32:in `run'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:61:in `block in run_initializers'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-5.2.1/lib/rails/initializable.rb:60:in `run_initializers'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-5.2.1/lib/rails/application.rb:361:in `initialize!'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-5.2.1/lib/rails/railtie.rb:190:in `public_send'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-5.2.1/lib/rails/railtie.rb:190:in `method_missing'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/config/environment.rb:5:in `<top (required)>'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-5.2.1/lib/rails/application.rb:337:in `require_environment!'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/theforeman/tfm/root/usr/share/gems/gems/railties-5.2.1/lib/rails/application.rb:520:in `block in run_tasks_blocks'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /usr/share/foreman/lib/tasks/apipie.rake:6:in `block (2 levels) in <top (required)>'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: /opt/rh/rh-ruby25/root/usr/share/gems/gems/rake-12.3.0/exe/rake:27:in `<top (required)>'
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: Tasks: TOP => apipie:cache => environment
[ WARN 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]/returns: (See full trace by running task with --trace)
[ERROR 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]: Failed to call refresh: '/usr/sbin/foreman-rake apipie:cache:index' returned 1 instead of one of [0]
[ERROR 2020-08-01T23:17:26 verbose] /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]: '/usr/sbin/foreman-rake apipie:cache:index' returned 1 instead of one of [0]
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/errors.rb:157:in `fail'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type/exec.rb:183:in `sync'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type/exec.rb:649:in `refresh'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:149:in `process_callback'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:34:in `block in process_events'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:121:in `block in queued_events'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:120:in `each'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:120:in `queued_events'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:33:in `process_events'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:288:in `eval_resource'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:191:in `call'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:191:in `block (2 levels) in evaluate'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:545:in `block in thinmark'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/2.5.0/benchmark.rb:308:in `realtime'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:544:in `thinmark'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:191:in `block in evaluate'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/graph/relationship_graph.rb:122:in `traverse'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:178:in `evaluate'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:240:in `block (2 levels) in apply'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:239:in `block in apply'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/log.rb:161:in `with_destination'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/report.rb:146:in `as_logging_destination'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:238:in `apply'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:185:in `block (2 levels) in apply_catalog'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:184:in `block in apply_catalog'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:232:in `block in benchmark'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:231:in `benchmark'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:183:in `apply_catalog'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:399:in `run_internal'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:227:in `block in run'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/context.rb:62:in `override'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:314:in `override'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:210:in `run'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:343:in `apply_catalog'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:260:in `block (2 levels) in main'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:243:in `block in main'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:207:in `main'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:177:in `run_command'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:382:in `block in run'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:734:in `exit_on_fail'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:382:in `run'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:143:in `run'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:77:in `execute'
[ERROR 2020-08-01T23:17:26 verbose] /opt/puppetlabs/puppet/bin/puppet:5:in `<main>'
The line triggering it seems to be:
