https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/664/
foreman-pipeline-katello-nightly-centos7-upgrade (failed)
foreman-pipeline-katello-nightly-centos7-install (passed)
Related:
17:16:58 [ERROR 2020-08-31T15:12:25 verbose] /Stage[main]/Foreman_proxy_content::Bootstrap_rpm/Bootstrap_rpm[katello-ca-consumer-pipeline-up-katello-nightly-centos7.n51.example.com]: Could not evaluate: no implicit conversion of nil into String
Probably due to:
Unrelated:
17:16:58 [ERROR 2020-08-31T15:11:37 verbose] foreman-maintain packages is-locked --assumeyes failed! Check the output for error!
That probably failed because foreman-maintain is not present, but that’s not even warning level. Info a best but IMHO debug.
Proposed fix here – https://github.com/theforeman/puppet-foreman_proxy_content/pull/280
After testing my fix for the above issue, I came across a Pulpcore related issue:
[DEBUG 2020-08-31T17:22:36 main] Exec[pulpcore-manager migrate --noinput](provider=posix): Executing check 'pulpcore-manager migrate --plan | grep "No planned migration operations"'
[DEBUG 2020-08-31T17:22:36 main] Executing with uid=pulp: 'pulpcore-manager migrate --plan | grep "No planned migration operations"'
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: Traceback (most recent call last):
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/bin/pulpcore-manager", line 11, in <module>
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: load_entry_point('pulpcore==3.4.1', 'console_scripts', 'pulpcore-manager')()
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/pulpcore/app/manage.py", line 11, in manage
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: execute_from_command_line(sys.argv)
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/django/core/management/__init__.py", line 381, in execute_from_command_line
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: utility.execute()
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/django/core/management/__init__.py", line 325, in execute
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: settings.INSTALLED_APPS
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/django/conf/__init__.py", line 79, in __getattr__
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: self._setup(name)
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/django/conf/__init__.py", line 66, in _setup
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: self._wrapped = Settings(settings_module)
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/django/conf/__init__.py", line 157, in __init__
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: mod = importlib.import_module(self.SETTINGS_MODULE)
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib64/python3.6/importlib/__init__.py", line 126, in import_module
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: return _bootstrap._gcd_import(name[level:], package, level)
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "<frozen importlib._bootstrap>", line 994, in _gcd_import
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "<frozen importlib._bootstrap>", line 971, in _find_and_load
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "<frozen importlib._bootstrap_external>", line 678, in exec_module
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/pulpcore/app/settings.py", line 225, in <module>
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: ENVVAR_FOR_DYNACONF="PULP_SETTINGS",
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/dynaconf/contrib/django_dynaconf_v2.py", line 70, in load
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: lazy_settings.populate_obj(django_settings_module)
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/dynaconf/utils/parse_conf.py", line 197, in evaluate
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: value = f(settings, *args, **kwargs)
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/dynaconf/base.py", line 98, in __getattr__
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: self._setup()
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/dynaconf/base.py", line 123, in _setup
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: default_settings.reload()
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/dynaconf/default_settings.py", line 75, in reload
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: start_dotenv(*args, **kwargs)
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/dynaconf/default_settings.py", line 62, in start_dotenv
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: or _find_file(".env", project_root=root_path)
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/dynaconf/utils/files.py", line 68, in find_file
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: search_tree.extend(_walk_to_root(work_dir))
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: File "/usr/lib/python3.6/site-packages/dynaconf/utils/files.py", line 17, in _walk_to_root
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: raise IOError("Starting path not found")
[DEBUG 2020-08-31T17:22:36 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/unless: OSError: Starting path not found
[DEBUG 2020-08-31T17:22:36 main] Exec[pulpcore-manager migrate --noinput](provider=posix): Executing 'pulpcore-manager migrate --noinput'
[DEBUG 2020-08-31T17:22:36 main] Executing with uid=pulp: 'pulpcore-manager migrate --noinput'
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: Traceback (most recent call last):
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/bin/pulpcore-manager", line 11, in <module>
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: load_entry_point('pulpcore==3.4.1', 'console_scripts', 'pulpcore-manager')()
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/pulpcore/app/manage.py", line 11, in manage
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: execute_from_command_line(sys.argv)
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/django/core/management/__init__.py", line 381, in execute_from_command_line
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: utility.execute()
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/django/core/management/__init__.py", line 325, in execute
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: settings.INSTALLED_APPS
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/django/conf/__init__.py", line 79, in __getattr__
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: self._setup(name)
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/django/conf/__init__.py", line 66, in _setup
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: self._wrapped = Settings(settings_module)
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/django/conf/__init__.py", line 157, in __init__
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: mod = importlib.import_module(self.SETTINGS_MODULE)
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib64/python3.6/importlib/__init__.py", line 126, in import_module
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: return _bootstrap._gcd_import(name[level:], package, level)
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "<frozen importlib._bootstrap>", line 994, in _gcd_import
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "<frozen importlib._bootstrap>", line 971, in _find_and_load
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "<frozen importlib._bootstrap_external>", line 678, in exec_module
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/pulpcore/app/settings.py", line 225, in <module>
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: ENVVAR_FOR_DYNACONF="PULP_SETTINGS",
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/contrib/django_dynaconf_v2.py", line 70, in load
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: lazy_settings.populate_obj(django_settings_module)
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/utils/parse_conf.py", line 197, in evaluate
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: value = f(settings, *args, **kwargs)
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/base.py", line 98, in __getattr__
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: self._setup()
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/base.py", line 123, in _setup
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: default_settings.reload()
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/default_settings.py", line 75, in reload
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: start_dotenv(*args, **kwargs)
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/default_settings.py", line 62, in start_dotenv
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: or _find_file(".env", project_root=root_path)
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/utils/files.py", line 68, in find_file
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: search_tree.extend(_walk_to_root(work_dir))
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/utils/files.py", line 17, in _walk_to_root
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: raise IOError("Starting path not found")
[ WARN 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: OSError: Starting path not found
[ERROR 2020-08-31T17:22:37 main] 'pulpcore-manager migrate --noinput' returned 1 instead of one of [0]
[ERROR 2020-08-31T17:22:37 main] /Stage[main]/Pulpcore::Database/Pulpcore::Admin[migrate --noinput]/Exec[pulpcore-manager migrate --noinput]/returns: change from 'notrun' to ['0'] failed: 'pulpcore-manager migrate --noinput' returned 1 instead of one of [0]
