https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/683/
foreman-pipeline-katello-nightly-centos7-install (failed)
foreman-pipeline-katello-nightly-centos7-upgrade (failed)
this seems now to have working pulp_rpm and pulp_container integration, but is still failing some bats tests:
from content-katello:
01:29:25 not ok 53 ensure component cv 1 version 1.1 has proper environments
01:29:25 # (in test file fb-content-katello.bats, line 413)
01:29:25 # `echo $envs_found | grep -q "Name: Library"' failed
01:29:25 not ok 54 ensure composite cv version 1.1 has proper environments
01:29:25 # (in test file fb-content-katello.bats, line 423)
01:29:25 # `echo $envs_found | grep -q "Name: Library Name: ${LIFECYCLE_ENVIRONMENT}"' failed`
and from proxy:
01:29:25 not ok 3 sync proxy
01:29:25 # (in test file fb-proxy.bats, line 26)
01:29:25 # `hammer capsule content synchronize --id=$PROXY_ID' failed with status 70
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.0/1, 0%, elapsed: 00:00:00
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.01/1, 1%, 0.0/s, elapsed: 00:00:02, ETA: 00:03:36
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.1/1, 10%, 0.0/s, elapsed: 00:00:04, ETA: 00:00:41
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.1/1, 10%, 0.0/s, elapsed: 00:00:06, ETA: 00:01:01
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.1/1, 10%, 0.0/s, elapsed: 00:00:08, ETA: 00:01:22
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.1/1, 10%, 0.0/s, elapsed: 00:00:11, ETA: 00:01:43
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.1/1, 10%, 0.0/s, elapsed: 00:00:13, ETA: 00:02:03
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.1/1, 10%, 0.0/s, elapsed: 00:00:15, ETA: 00:02:18
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.1/1, 10%, 0.0/s, elapsed: 00:00:17
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.1/1, 10%, 0.0/s, elapsed: 00:00:19
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.1/1, 10%, 0.0/s, elapsed: 00:00:22
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.1/1, 10%, 0.0/s, elapsed: 00:00:24
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.1/1, 10%, 0.0/s, elapsed: 00:00:26
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.1/1, 10%, 0.0/s, elapsed: 00:00:28
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.16/1, 16%, 0.0/s, elapsed: 00:00:30, ETA: 00:03:02
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.16/1, 16%, 0.0/s, elapsed: 00:00:32, ETA: 00:03:02
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.16/1, 16%, 0.0/s, elapsed: 00:00:35, ETA: 00:03:02
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.16/1, 16%, 0.0/s, elapsed: 00:00:37, ETA: 00:03:02
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.16/1, 16%, 0.0/s, elapsed: 00:00:39, ETA: 00:03:02
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.16/1, 16%, 0.0/s, elapsed: 00:00:41, ETA: 00:03:02
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.16/1, 16%, 0.0/s, elapsed: 00:00:44
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.16/1, 16%, 0.0/s, elapsed: 00:00:49
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.16/1, 16%, 0.0/s, elapsed: 00:00:52
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.16/1, 16%, 0.0/s, elapsed: 00:00:54
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.16/1, 16%, 0.0/s, elapsed: 00:00:57
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.84/1, 84%, 0.0/s, elapsed: 00:00:59
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 running: 0.95/1, 95%, 0.0/s, elapsed: 00:01:01, ETA: 00:00:01
01:29:25 # Task c1db6d42-a5ac-4bd8-a40e-707a18e85449 warning: 1.0/1, 100%, 0.0/s, elapsed: 00:01:03
01:29:25 # Error: RPM1004: Error retrieving metadata: Error 'Proxy Error' for https://pipeline-katello-server-nightly-centos7.n6.example.com/pulp/repos/Test_Organization/Library/Component_1/custom/Test_Product/modules-rpms/repodata/4628932d54fe4d5d95bcd81c6178915ba66b02471410c538a28f4f241f95d7a0-primary.xml.gz.
https://ci.centos.org/job/foreman-pipeline-katello-nightly-centos7-install/102/ has the sosreports from all related machines
@Justin_Sherrill enjoy
the environment ones might actually be errors in the bats test itself?
I looked at the output of hammer, and I think it’s a bad test, proposed some changes in https://github.com/theforeman/forklift/pull/1202
