https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/778/
This is still failing due to the pulp dependency change. can someone from @Pulp team please work with @infra to fix this asap? this is blocking katello releases currently.
---> Package pulp-server.noarch 0:2.19.0-0.1.alpha.201902240514git8f968b5.el7 will be installed
--> Processing Dependency: python-pulp-repoauth = 2.19.0 for package: pulp-server-2.19.0-0.1.alpha.201902240514git8f968b5.el7.noarch
--> Processing Dependency: python2-celery < 4.1 for package: pulp-server-2.19.0-0.1.alpha.201902240514git8f968b5.el7.noarch
--> Processing Dependency: python2-celery >= 4.0.0 for package: pulp-server-2.19.0-0.1.alpha.201902240514git8f968b5.el7.noarch
fatal: [pipeline-proxy-nightly-centos7]: FAILED! => changed=true
msg: |-
File "/bin/yum", line 29, in <module>
yummain.user_main(sys.argv[1:], exit_code=True)
File "/usr/share/yum-cli/yummain.py", line 375, in user_main
errcode = main(args)
File "/usr/share/yum-cli/yummain.py", line 239, in main
(result, resultmsgs) = base.buildTransaction()
File "/usr/lib/python2.7/site-packages/yum/__init__.py", line 1198, in buildTransaction
(rescode, restring) = self.resolveDeps()
File "/usr/lib/python2.7/site-packages/yum/depsolve.py", line 893, in resolveDeps
CheckDeps, checkinstalls, checkremoves, missing = self._resolveRequires(errors)
File "/usr/lib/python2.7/site-packages/yum/depsolve.py", line 1025, in _resolveRequires
(checkdep, missing, errormsgs) = self._processReq(po, dep)
File "/usr/lib/python2.7/site-packages/yum/depsolve.py", line 350, in _processReq
CheckDeps, missingdep = self._requiringFromTransaction(po, requirement, errormsgs)
File "/usr/lib/python2.7/site-packages/yum/depsolve.py", line 703, in _requiringFromTransaction
pkgresults = self._compare_providers(pkgs, requiringPo,req=needname)
File "/usr/lib/python2.7/site-packages/yum/depsolve.py", line 1618, in _compare_providers
bestnum = max(pkgresults.values())
ValueError: max() arg is an empty sequence
rc: 1
@tbrisker This appears to be an issue with me not propagating the entire fix from 2.18 to the master branch of pulp-packaging, as we were more focused on fixing the 2.18 stale repos.
This should be resolved now for nightly as well, and apologies for the hiccups.
