foreman-pipeline-katello-nightly-centos7-upgrade (failed)
foreman-pipeline-katello-nightly-centos7-install (failed)
foreman-pipeline-katello-nightly-centos8-install (passed)
Next one is running, but upgrade already failed:
17:25:57 TASK [foreman_installer : Join options] ****************************************
17:25:57 e[0;31mfatal: [pipe-up-katello-proxy-nightly-centos7]: FAILED! => e[0m
17:25:57 e[0;31m msg: 'An unhandled exception occurred while templating ''[u''--certs-tar-file {{ foreman_proxy_content_certs_tar }}'', u''--foreman-proxy-trusted-hosts {{ server_fqdn }}'', u''--foreman-proxy-trusted-hosts {{ ansible_nodename }}'', u''--foreman-proxy-foreman-base-url https://{{ server_fqdn }}'', u''--foreman-proxy-oauth-consumer-key {{ oauth_consumer_key.stdout }}'', u''--foreman-proxy-oauth-consumer-secret {{ oauth_consumer_secret.stdout }}'', u"{{ '''' if (2.3 is version(forklift_upgrade_version_start, ''>'') else (''--foreman-proxy-content-parent-fqdn %s'' % server_fqdn) }}", u''--puppet-server-foreman-url https://{{ server_fqdn }}'', u''--puppet-server-max-active-instances 1'', u''--puppet-server-jvm-min-heap-size 1G'', u''--puppet-server-jvm-max-heap-size 1G'']''. Error was a <class ''ansible.errors.AnsibleError''>, original message: template error while templating string: expected token '')'', got ''else''. String: {{ '''' if (2.3 is version(forklift_upgrade_version_start, ''>'') elsee[0m
17:25:57 e[0;31m (''--foreman-proxy-content-parent-fqdn %s'' % server_fqdn) }}'e[0m
Introduced here:
cc @ehelms
