https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/821/
Processing '/var/lib/jenkins/jobs/foreman-katello-nightly-test/builds/382/tap-master-files/debug/n14.pufty/tmp/debug/pipeline-katello-nightly-centos7/root/bats_results/fb-proxy.bats.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/foreman-katello-nightly-test/builds/382/tap-master-files/debug/n14.pufty/tmp/debug/pipeline-katello-nightly-centos7/root/bats_results/fb-proxy.bats.tap].
1..4
ok 1 proxy is registered
ok 2 enable lifecycle environment for proxy
not ok 3 sync proxy
# (in test file fb-proxy.bats, line 26)
# `hammer capsule content synchronize --id=$PROXY_ID' failed with status 70
# Task e2413b5e-6c4c-437a-b8c1-bff9dcca5fcb running: 0.0/1, 0%, elapsed: 00:00:00
# Task e2413b5e-6c4c-437a-b8c1-bff9dcca5fcb running: 0.0594059405940594/1, 5%, 0.0/s, elapsed: 00:00:02, ETA: 00:00:34
# Task e2413b5e-6c4c-437a-b8c1-bff9dcca5fcb running: 0.0594059405940594/1, 5%, 0.0/s, elapsed: 00:00:04, ETA: 00:01:08
# Task e2413b5e-6c4c-437a-b8c1-bff9dcca5fcb running: 0.0594059405940594/1, 5%, 0.0/s, elapsed: 00:00:06, ETA: 00:01:43
# Task e2413b5e-6c4c-437a-b8c1-bff9dcca5fcb running: 0.0594059405940594/1, 5%, 0.0/s, elapsed: 00:00:08, ETA: 00:02:17
# Task e2413b5e-6c4c-437a-b8c1-bff9dcca5fcb running: 0.0594059405940594/1, 5%, 0.0/s, elapsed: 00:00:10, ETA: 00:02:51
# Task e2413b5e-6c4c-437a-b8c1-bff9dcca5fcb running: 0.28217821782178215/1, 28%, 0.0/s, elapsed: 00:00:13, ETA: 00:00:33
# Task e2413b5e-6c4c-437a-b8c1-bff9dcca5fcb running: 0.5544554455445545/1, 55%, 0.0/s, elapsed: 00:00:15, ETA: 00:00:11
# Task e2413b5e-6c4c-437a-b8c1-bff9dcca5fcb running: 0.7772277227722773/1, 77%, 0.1/s, elapsed: 00:00:17, ETA: 00:00:04
# Task e2413b5e-6c4c-437a-b8c1-bff9dcca5fcb warning: 1.0/1, 100%, 0.1/s, elapsed: 00:00:19
# Error: PLP0000: Importer indicated a failed response
ok 4 content is available from proxy
