https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/836/
To support EL8, we built and added to the Katello repositories the qpid-cpp and qpid-proton packages. On EL7, we are relying on the packages in EPEL. However, we are encountering a divergence where EPEL has qpid-proton 0.33.0 but the rubygem that is currently released is only 0.32.0 at the time of writing this (qpid_proton | RubyGems.org | your community gem host). This leads to the current repoclosure failure and will lead to yum failures down the road, e.g.:
Error: Package: tfm-rubygem-qpid_proton-0.32.0-1.el7.x86_64 (katello-koji)
Requires: qpid-proton-cpp = 0.32.0
Removing: qpid-proton-cpp-0.32.0-2.el7.x86_64 (@/qpid-proton-cpp-0.32.0-2.el7.x86_64C_Y6rr)
qpid-proton-cpp = 0.32.0-2.el7
Updated By: qpid-proton-cpp-0.33.0-1.el7.x86_64 (epel)
qpid-proton-cpp = 0.33.0-1.el7
Available: qpid-proton-cpp-0.14.0-2.el7.x86_64 (extras)
qpid-proton-cpp = 0.14.0-2.el7
We could opt to carry the qpid-proton 0.32.0 package ourselves and align EL7 and EL8 within Katello repositories to the one we build. However, as you can see above we will run into issues with yum update.
Some options I could think of:
I think I’d prefer getting 0.33, under the expectation that this is also the that will be used by others as it’s in EPEL etc.
