katello-nightly-rpm-pipeline 983 failed
https://ci.theforeman.org/job/katello-nightly-rpm-pipeline/983/
foreman-pipeline-katello-nightly-centos8-install (failed) (remote job)
foreman-pipeline-katello-nightly-centos8-stream-install (failed) (remote job)
foreman-pipeline-katello-nightly-centos7-install (failed) (remote job)
foreman-pipeline-katello-nightly-centos8-upgrade (failed) (remote job)
foreman-pipeline-katello-nightly-centos7-upgrade (failed) (remote job)
Yo @katello, nightlies are failing during proxy sync with # Error: undefined methodpulp_href’ for nil:NilClass`
Can someone please have a look?
Could this be related to Fixes #32624 - use correct ca for content guard by jlsherrill · Pull Request #9381 · Katello/katello · GitHub, which was merged in the “started to fail” timeframe (last green pipe was june 6th)?
apologies about that, fix is here:
Thanks for the quick fix!
This seems to have fixed it, but nightlies remain broken :frowning:
katello-nightly-rpm-pipeline 984 failed has more details
