Make sure you have the puppet-foreman_scap_client package installed on host, where you run the foreman proxy with puppet master/server. If you have all in one setup, it’s the foreman host itself. Then import puppet classes from that foreman proxy. Once you see the foreman_scap_client class in your UI, you’ll be able to continue.
you can see the list of imported classes in UI under Configure -> Classes. To import additional classes click the “Import environments from $my_proxy” button on that page. This will fetch list of Puppet classes that are on $my_proxy but not yet in Foreman. You just select what you want to import and confirm.
Hi Ondrej,
Thanks.
I tried to import classes as you told me. The interface recognizes that foreman_scap_client and stdlib have to be update, but after clicking update following error is returned:
Oops, we’re sorry but something went wrong Validation failed: Name has already been taken
Did you define the module anywhere else (site.pp etc?) before you attempted to import the module in the foreman UI? Do you have any other modules defined or imported in the production environment?
