Katello Pipeline Bats Failures
The Katello pipeline failed with the following bats tests errors:
not ok 18 create lifecycle environment
(in test file fb-content-katello.bats, line 43)
`–prior="Library" --name="Test" | grep -q "Environment created"' failed
Could not create environment:
Validation failed: Locations you cannot remove locations that are
used by hosts or inherited., Environments you cannot remove
environments that are used by hosts or inherited., Domains you cannot
remove domains that are used by hosts or inherited.
ok 19 create content view
ok 20 add repo to content view
not ok 21 add puppet module to content view
(in test file fb-content-katello.bats, line 63)
`–content-view="Test CV" --id=$module_id | grep -q "Puppet module
added to content view"' failed
Could not add the puppet module:
Couldn't find Puppet Module with id '1'
I suspect the latter might be related to my puppet module conversion work
and I will look into it. If anyone has ideas on the former error, it would
be much appreciated.
··· -- Eric D. Helms Red Hat Engineering Ph.D. Student - North Carolina State University
> # (in test file fb-content-katello.bats, line 43)
> # `–prior="Library" --name="Test" | grep -q "Environment created"' failed
> # Could not create environment:
> # Validation failed: Locations you cannot remove locations that are used by hosts or inherited., Environments you cannot remove environments that are used by hosts or inherited., Domains you cannot remove domains that are used by hosts or inherited.
I'll take a look at this.
-Justin
`–content-view=“Test CV” --id=$module_id | grep -q “Puppet module added to content view”’ failed
Couldn’t find Puppet Module with id ‘1’
work and I will look into it. If anyone has ideas on the former error,
it would be much appreciated.
Eric D. Helms
Red Hat Engineering
Groups “foreman-dev” group.
an email to foreman-dev+unsubscribe@googlegroups.com
mailto:foreman-dev+unsubscribe@googlegroups.com.
