[katello] pulp 2.8.0 is in katello nightly
The Pulp 2.8.0 GA release has been tagged into Katello nightly repos. If
you update your dev environment, it should get pulled in. Please ensure
you are on the GA version if you are experiencing issues with the
nightly, some of the beta versions of Pulp had bugs that have since been
fixed.
