Since updating to the latest Katello it seems our Foreman instance has issues when running certain rake commands related to Katello or when remote execution tries to call back to the Foreman server. From the output below output when running “foreman-rake katello:correct_repositories” I’m assuming something has gone wrong with our SSL setup.
Though we have followed what is in the documentation, and only replaced the --certs-server related options with our certificates and keys. Our SSL setup has worked previously and passed the cert check tool.
So I’m not sure what has happened nor how to fix it (apart from setting SSLVerifyClient to optional_no_ca).
foreman-rake katello:correct_repositories output:
# foreman-rake katello:correct_repositories COMMIT=true --trace
** Invoke katello:correct_repositories (first_time)
** Execute environment
** Invoke katello:check_ping (first_time)
** Invoke dynflow:client (first_time)
** Execute dynflow:client
** Execute katello:check_ping
** Execute katello:correct_repositories
Processing Repository 1/496: EPEL 8 x86_64 (40)
rake aborted!
NoMethodError: undefined method `code' for #<Faraday::ConnectionFailed:0x0000560bc5f4c988>
/usr/share/gems/gems/katello-4.11.1/lib/katello/tasks/repository.rake:94:in `rescue in repo_exists?'
/usr/share/gems/gems/katello-4.11.1/lib/katello/tasks/repository.rake:84:in `repo_exists?'
/usr/share/gems/gems/katello-4.11.1/lib/katello/tasks/repository.rake:41:in `block (3 levels) in <top (required)>'
/usr/share/gems/gems/activerecord-6.1.7.6/lib/active_record/relation/batches.rb:71:in `block (2 levels) in find_each'
/usr/share/gems/gems/activerecord-6.1.7.6/lib/active_record/relation/batches.rb:71:in `each'
/usr/share/gems/gems/activerecord-6.1.7.6/lib/active_record/relation/batches.rb:71:in `block in find_each'
/usr/share/gems/gems/activerecord-6.1.7.6/lib/active_record/relation/batches.rb:138:in `block in find_in_batches'
/usr/share/gems/gems/activerecord-6.1.7.6/lib/active_record/relation/batches.rb:245:in `block in in_batches'
/usr/share/gems/gems/activerecord-6.1.7.6/lib/active_record/relation/batches.rb:229:in `loop'
/usr/share/gems/gems/activerecord-6.1.7.6/lib/active_record/relation/batches.rb:229:in `in_batches'
/usr/share/gems/gems/activerecord-6.1.7.6/lib/active_record/relation/batches.rb:137:in `find_in_batches'
/usr/share/gems/gems/activerecord-6.1.7.6/lib/active_record/relation/batches.rb:70:in `find_each'
/usr/share/gems/gems/katello-4.11.1/lib/katello/tasks/repository.rake:39:in `with_index'
/usr/share/gems/gems/katello-4.11.1/lib/katello/tasks/repository.rake:39:in `block (2 levels) in <top (required)>'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:281:in `block in execute'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:281:in `each'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:281:in `execute'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:199:in `synchronize'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/usr/share/gems/gems/rake-13.0.1/lib/rake/task.rb:188:in `invoke'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:160:in `invoke_task'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:116:in `each'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:116:in `block in top_level'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:125:in `run_with_threads'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:110:in `top_level'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:83:in `block in run'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:186:in `standard_exception_handling'
/usr/share/gems/gems/rake-13.0.1/lib/rake/application.rb:80:in `run'
/usr/share/gems/gems/rake-13.0.1/exe/rake:27:in `<top (required)>'
/usr/bin/rake:23:in `load'
/usr/bin/rake:23:in `<main>'
Caused by:
Faraday::ConnectionFailed: SSL_read: tlsv1 alert unknown ca (OpenSSL::SSL::SSLError)
/usr/share/ruby/openssl/buffering.rb:57:in `sysread'
/usr/share/ruby/openssl/buffering.rb:57:in `fill_rbuff'
/usr/share/ruby/openssl/buffering.rb:300:in `eof?'
/usr/share/ruby/openssl/buffering.rb:253:in `readline'
/usr/share/gems/gems/excon-0.104.0/lib/excon/socket.rb:85:in `block in readline'
/usr/share/ruby/timeout.rb:95:in `block in timeout'
/usr/share/ruby/timeout.rb:33:in `block in catch'
/usr/share/ruby/timeout.rb:33:in `catch'
/usr/share/ruby/timeout.rb:110:in `timeout'
/usr/share/gems/gems/excon-0.104.0/lib/excon/socket.rb:84:in `readline'
/usr/share/gems/gems/excon-0.104.0/lib/excon/response.rb:73:in `block in parse'
/usr/share/gems/gems/excon-0.104.0/lib/excon/response.rb:72:in `loop'
/usr/share/gems/gems/excon-0.104.0/lib/excon/response.rb:72:in `parse'
/usr/share/gems/gems/excon-0.104.0/lib/excon/middlewares/response_parser.rb:7:in `response_call'
/usr/share/gems/gems/excon-0.104.0/lib/excon/connection.rb:460:in `response'
/usr/share/gems/gems/excon-0.104.0/lib/excon/connection.rb:291:in `request'
/usr/share/foreman/lib/foreman/http_proxy/excon_connection_extension.rb:13:in `request'
/usr/share/gems/gems/faraday-excon-1.1.0/lib/faraday/adapter/excon.rb:31:in `block in call'
/usr/share/gems/gems/faraday-1.10.2/lib/faraday/adapter.rb:50:in `connection'
/usr/share/gems/gems/faraday-excon-1.1.0/lib/faraday/adapter/excon.rb:31:in `call'
/usr/share/gems/gems/faraday-1.10.2/lib/faraday/rack_builder.rb:154:in `build_response'
/usr/share/gems/gems/faraday-1.10.2/lib/faraday/connection.rb:516:in `run_request'
/usr/share/gems/gems/faraday-1.10.2/lib/faraday/connection.rb:202:in `get'
/usr/share/gems/gems/pulp_rpm_client-3.23.0/lib/pulp_rpm_client/api_client.rb:69:in `public_send'
/usr/share/gems/gems/pulp_rpm_client-3.23.0/lib/pulp_rpm_client/api_client.rb:69:in `call_api'
/usr/share/gems/gems/pulp_rpm_client-3.23.0/lib/pulp_rpm_client/api/repositories_rpm_api.rb:702:in `read_with_http_info'
/usr/share/gems/gems/pulp_rpm_client-3.23.0/lib/pulp_rpm_client/api/repositories_rpm_api.rb:649:in `read'
/usr/share/gems/gems/katello-4.11.1/lib/katello/tasks/repository.rake:88:in `repo_exists?'
Caused by:
Excon::Error::Socket: SSL_read: tlsv1 alert unknown ca (OpenSSL::SSL::SSLError)
Caused by:
OpenSSL::SSL::SSLError: SSL_read: tlsv1 alert unknown ca
Tasks: TOP => katello:correct_repositories
foreman-proxy log when running remote execution jobs
4be563a [E] <RuntimeError> Failed performing callback to Foreman server: 403 {
"error": {"message":"Access denied","details":"Missing one of the required permissions: ","missing_permissions":[]}
/usr/share/gems/gems/smart_proxy_dynflow-0.9.1/lib/smart_proxy_dynflow/callback.rb:18:in `callback'
/usr/share/gems/gems/smart_proxy_dynflow-0.9.1/lib/smart_proxy_dynflow/action/batch_callback.rb:16:in `run'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/action.rb:589:in `block (3 levels) in execute_run'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/middleware/stack.rb:27:in `pass'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/middleware.rb:19:in `pass'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/action/progress.rb:31:in `with_progress_calculation'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/action/progress.rb:17:in `run'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/middleware/stack.rb:23:in `call'
/usr/share/gems/gems/smart_proxy_dynflow-0.9.1/lib/smart_proxy_dynflow/middleware/keep_current_request_id.rb:17:in `block in run'
/usr/share/gems/gems/smart_proxy_dynflow-0.9.1/lib/smart_proxy_dynflow/middleware/keep_current_request_id.rb:51:in `restore_current_request_id'
/usr/share/gems/gems/smart_proxy_dynflow-0.9.1/lib/smart_proxy_dynflow/middleware/keep_current_request_id.rb:17:in `run'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/middleware.rb:32:in `run'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/middleware/world.rb:31:in `execute'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/action.rb:588:in `block (2 levels) in execute_run'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/action.rb:587:in `catch'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/action.rb:587:in `block in execute_run'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/action.rb:490:in `block in with_error_handling'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/action.rb:490:in `catch'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/action.rb:490:in `with_error_handling'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/action.rb:582:in `execute_run'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/action.rb:303:in `execute'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:18:in `block (2 levels) in execute'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/execution_plan/steps/abstract.rb:167:in `with_meta_calculation'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:17:in `block in execute'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:32:in `open_action'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:16:in `execute'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/director.rb:69:in `execute'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/executors/parallel/worker.rb:15:in `block in on_message'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/executors.rb:18:in `run_user_code'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/executors/parallel/worker.rb:14:in `on_message'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/context.rb:46:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/executes_context.rb:7:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/abstract.rb:25:in `pass'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/actor.rb:122:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/awaits.rb:15:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/sets_results.rb:14:in `on_envelope'
/usr/share/gems/gems/dynflow-1.8.2/lib/dynflow/actor.rb:56:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/buffer.rb:38:in `process_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/buffer.rb:31:in `process_envelopes?'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/buffer.rb:20:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/termination.rb:55:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/behaviour/removes_child.rb:10:in `on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:162:in `process_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:96:in `block in on_envelope'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:119:in `block (2 levels) in schedule_execution'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/synchronization/mutex_lockable_object.rb:47:in `block in synchronize'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/synchronization/mutex_lockable_object.rb:47:in `synchronize'
/usr/share/gems/gems/concurrent-ruby-edge-0.6.0/lib/concurrent-ruby-edge/concurrent/actor/core.rb:116:in `block in schedule_execution'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/serialized_execution.rb:18:in `call'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/serialized_execution.rb:96:in `work'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/serialized_execution.rb:77:in `block in call_job'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:352:in `run_task'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:343:in `block (3 levels) in create_worker'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:334:in `loop'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:334:in `block (2 levels) in create_worker'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:333:in `catch'
/usr/share/gems/gems/concurrent-ruby-1.1.10/lib/concurrent-ruby/concurrent/executor/ruby_thread_pool_executor.rb:333:in `block in create_worker'
/usr/share/gems/gems/logging-2.3.1/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
