I’ve two organizations in Foreman. One with a working Red Hat Virtualization Subscription where the Nodes can get packages from Foreman.
Recently I’ve configured a second organization for colleagues from another department who want to update their SAP Hana servers (on RHEL 7 and 8). I’ve managed to register one test host to foreman. First I’ve copied manually the certs to the regarding directory (/etc/rhsm/ca) - and additionally to /etc/pki/ca-trust/source/anchors. Then I adopted the rhsm.conf to the same content as the working RHV hosts.
A “yum update” returns following:
[root@lxli03-044 yum.repos.d]# yum update
Loaded plugins: product-id, search-disabled-repos, subscription-manager
ST6_Icinga_icinga_stable_el7        | 1.8 kB
00:00:00
ST6_salt_salt_el7        | 2.1 kB
00:00:00
https://lxli03-q03.res01.ads.ooe.local/pulp/repos/ST6/Library/CCV_RHEL7_SAP_Hana/content/e4s/rhel/server/7/7Server/x86_64/os/repodata/repomd.xml: [Errno 14] HTTPS Error 404 - Not Found
Trying other mirror.
To address this issue please refer to the below knowledge base article
https://access.redhat.com/articles/1320623
failure: repodata/repomd.xml from rhel-7-server-e4s-rpms: [Errno 256] No more mirrors to try.
https://lxli03- q03.res01.ads.ooe.local/pulp/repos/ST6/Library/CCV_RHEL7_SAP_Hana/content/e4s/rhel/server/7/7Server/x86_64/os/repodata/repomd.xml: [Errno 14] HTTPS Error 404 - Not Found
I ensured that the certs are valid - and as already mentioned - another Red Hat product (in the main organization) works fine.
I already tried to install the package from foreman which includes the certs and rhsm.conf but had no luck - still same error. Also I cleaned the yum cache, … etc.
Logs on the host - eg. /var/log/rhsm/rhsm.log or on foreman, /var/log/foreman/production.log contain no helpful errors.
“yum update” from RHEL 7 for SAP Hana Hosts succeed
Foreman 1.24.2
Katello 3.14.1
[root@lxli03-044 rhsm]# cat /etc/redhat-release
Red Hat Enterprise Linux Server release 7.7 (Maipo)
