So following some issues I ran into with UEFI hosts, I decided to follow some advice lzap posted on the forum some time back on ditching TFTP and configuring iPXE.
But I noticed that it requires manually adding some config to /etc/dhcp/dhcpd.conf to enable iPXE.
However, every time foreman-installer runs, it will restore the dhcpd.conf to it’s known last default config.
Is there any way to make changes like that stick? Can I use a flag in foreman-installer to put it there? Or can I stick it in some other file/somewhere in hiera?
Expected outcome: foreman-installer not automagically removing my config for iPXE.
Foreman 2.1
Katello 3.16
I see, well, the thing is, I was looking for a idempotent solution that would still manage all the other aspects for DHCP (so I could incorporate it in my role).
So I noticed that the default config includes ‘/etc/dhcp/dhcpd.hosts’. It’s a bit hacky, but I stuck it in there
Well scratch that, it seems dhcpd.hosts is also overwritten
I’ll just set the config as the last thing in the role then, that’ll make sure it’s there each time the role completes it’s run (as it will enable that flag each time to make sure the Foreman server is prepared for deployment)
